Tekno RC SCT410.3 Thread
#5266
And once shredded, it's a PITA to get off in any decent size pieces.
#5267
Tech Legend
This is what I use:
2 in. x 50 ft. 20 Mil Pipe Wrap Tape-53550 - The Home Depot
If someone can find one that is more like 4 in wide you could do chassis I think in one shot and trim. I heat this up after applying with a lighter and it helps it stick better.
As its pretty cheap I don't feel bad if i need to pull and replace and its is pretty durable.
#5268
i like protectors but i'm kind of spoiled now that they are often available with screw holes, or at least some screw holes. but with this one, it looks like i may be back to the old days of cutting them manually.
#5269
Tech Legend
thanks for the reply, but i have to admit that all protectors aren't the same, especially with so many options out now. i don't know what you had, but i've never had an experience like that with any of the protectors i've used, die cut or manually cut.
I did find some 4 inch width tape like i mentioned, however they are $$$. if I find one cheaper may try it.
#5270
#5271
I used this chassis protector and it lasted 4 outdoor races before I removed it to get to some screws. I know it costs more than the mil pipe tape idea, which is great by the way, but it looks cool and it got a few laughs from the corner marshals as they flipped my truck back on it's wheels.
ONE RC CAR 1:10 Chassis Skin 12mil- OR ONE 18MIL OUTDOOR skin-Flipped 2.0 | eBay
What issues were people having with the nerf bar covers?
#5272
Whaaat? How? I use at MOST a total of 150ml (~5oz?) for a two-color short course body, but may even be half that if it's just black If I had to use 20+ oz I'd rather drive with an unpainted body
#5273
Also I use at least 4 colors for whatever reason, then promptly destroy the outside of the body's looks.
There's currently 9 cans (black, metallic red & white) I'm looking at under my tv for the next one I do. Luckily I can get paint cheaper, but it's still pricey @ $4 per can for Tamiya colors. Duratrax seems to cover way better. Going a bit simpler w/ colors but a bit crazy w/ masking. Used to paint graffiti as a yoot so I don't bat an eye at way-too complex schemes w/ limited palette.
Airbrush seems like a good idea but I was looking at setups in the $300 range. I'm really into paint again & the thought of spraying on liquid mask makes me smile inside.
I've spent easily $130 on rattle cans this year. Crikey!
#5274
i had always cut my own holes for certain holes when using associated sheets or whatever was out at a given time, but i have two from rcdecals with all holes cut and then one from another company that has SOME holes cut - i can't remember where i got it though.
that's why i was thinking maybe someone did one like that for the 410.3 but i haven't found one yet.
i agree on the tbone bumpers helping as skids since the chassis areas they protect often get worn out the fastest. i have a couple trucks with tbone stuff on them and it has worked out well, but, i still prefer combining with a nice quality protector.
i guess it's back to cutting my own holes! life goes on.
#5275
I cut chassis protectors out of a sheet of carbon fiber looking vinyl from AutoZone. It's 5 or 6 in wide and the adhesive is weatherproof. Its easy enough to trace out the screw holes with an xacto once you have it stuck on. I usually put it on over the screws, and just cut them out as I need them.
It's easy enough to do that I make my daughters make their own.
#5276
thanks for the recommendation.
#5277
Is it just on my side or is the petitrc site , set up sheet page down? I see about 20 listings , but they all have blank set up sheets.
Edit, just my side, ipad. Checked the site on my phone and the site is fine.
#5279
There is an app for the icrap's that you have to download, I think it's a acrobat reader or something to that effect.
