Tekno RC SCT410.3 Thread
#4743
Moderator
Finally!!!! Got to the track and made some major adjustments....Carbon fiber Front and rear shock towers, updated front bumper, Diffs are 7K, 10K, 5K and i am running brand new Dboot Terabytes on DE wheels with proline foams,and have 4 washers on the steering stops....and i am STILL traction rolling coming hard into a turn..on carpet....my shock collars are as low as they can go in the front, and 4.0mm from the top...ride height is at 21....yellow springs in the front...stock box springs in the front....getting very very frustrated.......im running on carpet so i assume thats a high traction track....any and all help is welcomed....
#4745
Try reducing droop, increasing camber, increase front diff fluid, and make sure you are prepping the front tires correctly. A lot of folks trim the outer row of knobs, CA glue the outer sidewall of the front tires, and sacrifice a garden gnome with 4 drops of dragon tears to get these things to not traction role on carpet.
#4746
Tech Legend
good info given by all.
You didn't mention your droop you are using hiofficr87 . that can be a big factor.
You may also want to cut your springs if you need lower right height. Personally using xray gray progressives here as that is what I used on my desc10 and it was money, feels about right on my Tekno.
Just need to wait on the ESC to make a return here, but I may setup my youngest's sct410.3 with the carpet setup I was thinking of going with, all tekno parts, and see how it goes too.
#4747
#4749
#4750
I have been hearing about people who are cutting down the springs a lot lately.
Oddly enough, several of the pros advise against this, saying it messes up the rates of the springs and what not, but that doesn't seem to stop them from doing it.
One guy I know on the 410 group on facebook is cutting hit rear springs only and seems to be doing really well, even winning some major events to prove it works well for him.
He said to cut off one coil, and he also run the ESC behind the battery.
#4751
Tech Legend
yeah that is what I am seeing even on some of the setup sheets like the one I am using. Instead of doing that, I decided to go with with some springs that are already short I have here that worked great on my Durango DESC10. They are progressives, but I can darn near run the vehicle to touch the ground and they work quite well. Not cheap, as they are xray springs thats for sure.
One of the top drivers here uses the ESC behind the battery too. I'd be curious to see what his scale balance is when he does that.
My ESC I am hoping will be back this week. Really want to try the vehicle with some changes and some tires I picked up.
#4752
#4753
Tech Legend
for the carpet conditions I would say yes. This is the setup that basically i am running:
http://www.teknorc.com/wp-content/up...0Astroturf.pdf
I have a few tweaks to this like running emulsion, PT Racing oils, and Xray progressive rate gray springs, but most of the settings are the same.
I may go with the diff change that was mentioned as a better base setup for the diffs from that new starting setup. Not sure on the pistons though.
#4754
410.3 pinion
Just only tekno mod1 they have the biggest set screws that dont strip out and I have a pro4hd tekin 4300kv I run 16t to 19t depends on track
#4755
Same here tekno pinions have bigger set screws less chance of stripping out pro4hd 4300kv 16t for small 19t for fast track
