    Hide Wikipost
Old 10-10-2017, 01:54 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC SCT410.3 Thread
Last edit by: DirkW
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8702 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree87Likes
Old 01-17-2017, 08:17 AM   #4666
Tech Legend
Cain's Avatar
Trader Rating: 239 (100%+)
Originally Posted by [email protected] View Post
My beast! Easy build. Awesome quality
Yeah they are definitely lighter than 1/8 buggies.
We will suggest we all be running 2s and no limitation on motor. Also no 1/8 size wheels which I currently run. The thing is a hoot to drive on 1/8 wheels!
Do you know if any other non sct bodies fit the sct410?
I would suggest limiting your motors to say a 550 can size max and I agree on the no 1/8 buggy wheel thing. Vehicles should look like an SCT.
Not sure what brand lipos you can get out there, but I picked up some DualSky Track and Field 7000mah lipos and have been impressed with them. Very low IR numbers and they run great with 5mm pass thru plugs.
As for non-sct bodies, I guess I am not following is there something in particular you are wanting for a body? Out here I think the big thing we look at for legal bodies is that it doesnt' run a rear wing.
So technically though no one has run it, I think the jconcepts Nissan Armada body that has that built in wing would be illegal here, but you can pull it no prob:
Originally Posted by Lowe's48 View Post
Here you go Cain.
Please remember this is a very high traction clay setup. I think this will work on turf as well.
Lol gotta love how where I am at right now blocks photobucket ... I'll give it a lookk and compare when I get home. On our carpet its always good to have setups to compare to.
One of these days this week I'll look into throwing the truck on my setup station and do some changes, I recall picking up some 17mm hex adapters from kyosho that slide over (or are supposed to slide over) a 12mm hex so will see how well they work for setup usage as I think that is what I picked them up for before.
< HB Racing D413 | Tekno EB48SL / SCT410.3 | Tekno EB410 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 01-18-2017, 01:01 AM   #4667
Default Pinion
Can I use tlr mod1 pinion on tekno 410.3? Thanks
stinger84 is offline   Reply With Quote
Old 01-18-2017, 12:34 PM   #4668
Mod1 is the same no matter who makes it.
The off-road Tekno 3some-> EB48.4 - ET48.3 - SCT410.3 ---Soon eb410
The oval 3some -> Tekno SCT410.3 - Tekno SCT210.3 - Blitz
Sponsors: Fiercercsolutions.com, AKA, jtbearingco.com, CowRC, Walden Designs, Leadfinger Racing, And BoomRC.net
ezlight is offline   Reply With Quote
Old 01-19-2017, 06:59 AM   #4669
jurejurman's Avatar
Are they any updates planned for this car in near future?
People who think they know everything are a great annoyance to those of us who do.
jurejurman is offline   Reply With Quote
Old 01-19-2017, 10:36 AM   #4670
Tech Legend
Cain's Avatar
hoping to see if an SCT410.4 incorporates some of the changes the EB48.4 has on the rear end.
Old 01-19-2017, 10:44 AM   #4671
The new setup sheets are using updated parts
weedsnager is offline   Reply With Quote
Old 01-19-2017, 07:21 PM   #4672
I wanna thank all you guys for putting all this info together...Im extremely new to RC and purchased my first SCT which was the SCT 410.3. Im working on fine tuning the setup for Carpet racing....im have major issues with sliding in and out of turns...truck doesn't really seem to stick like it should..over rotating coming in and out of turns....still got a lot of learning to do i suppose.
HW XR8 SCT
HW 3656 4000kv motor
Savox 1258tg servo
running pin-points (outer 2 rows and 1st inner row removed)
Using the Shaun Brown Setup as posted
hiofficr87 is offline   Reply With Quote
Old 01-20-2017, 05:30 PM   #4673
Tech Legend
Cain's Avatar
For your track, what are common tires that people who don't have this issue are running?
to me at least, it sounds like your tires could be a hair down on traction assuming you are using ghosted MC compound tires. Are you saucing them?
Also, are you using any steering stops (they don't show up on that setup sheet but later ones)
Old 01-21-2017, 12:15 AM   #4674
Nollarolla78's Avatar
Default 410 to 410.3 upgrade
Originally Posted by trplcrwn5 View Post
I picked up a very nice 410.2. Question: Can I upgrade with parts to a .3? If so what parts and how expensive?
they don't make a 410.2but you can upgrade the 410 to the 410.3 here fiercercsolutions.com/Tekno-SCT410-Basic-Upgrade-kit-to-4103
Nollarolla78 is offline   Reply With Quote
Old 01-21-2017, 11:56 AM   #4675
Not using any steering stops, just learned about them within the last few days, going to be installing them today and just bought a brand new set of pinpoints and Dboot Terrabytes
Everyone seems to really enjoy the pinpoints at the local track
Old 01-21-2017, 11:59 AM   #4676
Tech Legend
Cain's Avatar
Cool. Starting with the right tires is probably the biggest part to your setup. If you don't have that you can be chasing your setup all the time.
I'll be confirming what steering stop settings are present to here as not sure they are being used.
Old 01-21-2017, 12:21 PM   #4677
currently have 2 washers on each side of the steering stops..looks like most people are running 4
Old 01-21-2017, 12:37 PM   #4678
Tech Legend
Cain's Avatar
could even play with dual rate a bit too.
Old 01-24-2017, 12:26 PM   #4679
Trader Rating: 16 (100%+)
Just purchased a Proline Extended Body Mount Kit for SCT410.
Does anyone run a different style body on SCT410?
For example, rally body or parma mustang body?
Min. K
Fight on-
TEKNO EB48.35 / EB48.3
kms7852 is offline   Reply With Quote
Old 01-25-2017, 11:53 PM   #4680
Josh L's Avatar
Josh L is offline   Reply With Quote
Tags
sct410, sct410.3, short course, short course 4x4, tekno
