    Hide Wikipost
Old 10-10-2017, 01:54 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC SCT410.3 Thread
Last edit by: DirkW
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8702 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree83Likes
Old 01-07-2017, 10:06 AM   #4621
I figured it out, thanks
weedsnager is offline   Reply With Quote
Old 01-07-2017, 11:41 AM   #4622
Matthew_Armeni's Avatar
Trader Rating: 31 (100%+)
Originally Posted by TAW View Post
Has anyone had an issue getting good gear mesh with a HW 4700 and a 14 or 15t pinion. Seems I can only get it good with a 16t. Running on a small indoor track and really wanted to go down to 14 but the teeth barely touch.
The mount will accommodate down to a 14 tooth pinion but you'll have to either remove or sand down the center brace for the motor to fit. A 15 should fit without modifications.
Tekno RC
Matthew_Armeni is offline   Reply With Quote
Old 01-07-2017, 12:16 PM   #4623
delete
Old 01-07-2017, 02:20 PM   #4624
JoeRC123's Avatar
For the stock setup it has 4 washers on the bottom. I don't see that this does anything. Is it just a place to store them?
[IMG][/IMG]
Originally Posted by justpoet View Post
This is referring to the ball studs on the spindle. You can adjust the amount of bump steer by moving washers to/from below the ball stud, or flipping the ball stud over to get the ball portion even lower.
JoeRC123 is offline   Reply With Quote
Old 01-07-2017, 04:20 PM   #4625
justpoet's Avatar
Trader Rating: 16 (100%+)
[IMG][/IMG]
Yes and no. You can remove the washers entirely if they're not between the ball stud and the item in question (steering rack or spindle), and it won't change setup. However, without them, you may find the end of the screw rubbing on things, so you'd want to use a shorter screw then too. Leaving them stacked up makes this not needed, though I personally do it anyway and switch to a button head for the spindle side so that wheel flex doesn't let the wheel hit the top of the screw.
"We do not act rightly because we have virtue or excellence, but we rather have those because we have acted rightly. We are what we repeatedly do. Excellence, then, is not an act but a habit." -Aristotle
My wallet supports: TeknoRC.com, NorCalHobbies.com, SMC, Tekin, and several tire/servo companies.
justpoet is offline   Reply With Quote
Old 01-07-2017, 07:48 PM   #4626
JoeRC123's Avatar
Thanks for the explanation. I just thought it was weird to put 4 washers that do nothing but it makes sense after you explained it.
Old 01-07-2017, 07:48 PM   #4627
Update...I installed 2 of the steering stop washers (new setup sheet calls for 3) and that took care of the loose end on power coming out of corners.
qstorm777 is offline   Reply With Quote
Old 01-07-2017, 07:51 PM   #4628
Update...I installed 2 of the steering stop washers (new setup sheet calls for 3) and that took care of the loose end on power coming out of corners. The setup was pretty good.
Old 01-08-2017, 09:45 AM   #4629
jason07's Avatar
tell it again....haha
Agama A215E Hobbywing 1900KV and Xerun XR8
Agama A215 Bullitt B221
jason07 is offline   Reply With Quote
Old 01-08-2017, 11:02 AM   #4630
Just saw that...lol. My bad.
Old 01-08-2017, 11:47 AM   #4631
Tech Legend
Cain's Avatar
Trader Rating: 235 (100%+)
Ran my SCT410.3 using the Jesse Munn setup with a few changes:
- Xray Gray Progressive springs (lower ride height and they worked well on my heavier Durango DESC10 so figured give them a try, especially as i don't have yellow springs lol) Range on these are
#358174 FRONT C = 0.7 to 0.8 lbs/in = 3.997 to 4.568
#358274 BACK C = 0.5 to 0.6 lbs/in = 2.855 to 3.426
- PT racing oil 700 Front, 600 rear
- Camber -2 all around
- Emulsion shocks
- Proline Ion tires and Proline Primes, both MC compound (tried as sets front and rear)
- chassis braces front, middle, rear
My impressions are that this is a very good base setup for the carpet we run here. We are limited to non hard pin tires which the carpet tires would fit, so that is why we run clay compounds as described. Basically ran ions as they were cheap and wanted to burn down the pins. I tried a set of primes from a buddy at the track to see if it would take away a bit of the bite I was experiencing causing traction rolling.
I have thought more about it after the race that I am not sure what the settings are on my steering range stops, however, when I initially had the vehicle going, I had my radio settings changed to fit my daughters driving style better and forgot to change it back initially, so it had the dual rate turned really down. I am assuming the steering stops are in essence doing the same thing.
If that is the case, I am wondering if the traction rolling I experienced could be partially due to that. As pins would most likely bite more than what I am seeing with a slick style tire, I am thinking the setup would handle the roll issues.
Anyway, my next course of action outside of another set of tires I am thinking would be:
- going to yellow springs (or equivalent rates) after comparing the rates to what the xrays offer. I hate to cut some springs though, maybe hot bodies springs like the old days would be an option at least for the fronts as they are already short and close in rates I think to some of the teknos.
- Adjusting roll center at the rear hingepin level
Based on this:
Raising Roll Center
Lower inside camber link position at brace/tower
Raise outside camber link position at hub/caster block
Lower hub/caster block mounting hole at arm
Raise the inside arm mounting location
Shorten camber link
I am thinking of going with:
* going with HRC rear hubs
* shorter link (this is what my previous carpet setup had going on)
* Raising the insert arm location by:
1. Raising position on C-Block and D-Block (Will probably start with C-Block)
How does all that sound?
outside of that vehicle is very close
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL | Yokomo YZ-2 DTM x 2>
Cain is online now   Reply With Quote
Old 01-09-2017, 06:21 PM   #4632
suzukipro's Avatar
Trader Rating: 22 (100%+)
I ran the updated EB48.4 Ackerman parts using most of the indoor/outdoor setup on the Tekno page http://www.teknorc.com/wp-content/up...oor%20Dirt.pdf (I ran with different pistons and fluid than mentioned) and was pretty happy with how consistent it was.
I have struggled with my 410.3 in the past as it would work great and then the next time out with no changes it would drive totally different. It stayed very consistent and the handling was improved this past weekend, hopefully I'll be able to dial it in even more and it will remain consistent with the new .4 ackerman parts.
Eric
________________________________________________________________________
Tekno, XRAY, Team Associated & Traxxas Powered by SMC.
Innovative Hobbies Raceway, Flyin-High RC Track
suzukipro is offline   Reply With Quote
Old 01-10-2017, 06:50 AM   #4633
Tech Legend
Cain's Avatar
thats good. Its nice to see tekno offering improvements that improves consistency and keep moving forward with setups etc. Nice change from what I was used to on another platform where you were on your own basically.
Old 01-10-2017, 07:31 AM   #4634
DriveItLikeYSIT's Avatar
Trader Rating: 92 (100%+)
- Emulsion shocks
This is great info cause a indoor off road turf track just opened up. I have been debating about getting PL carpet pin tires; one of my racing buddies prefers PL ions (MC).
Usually when my sct is traction rolling I take away some droop in the FR and RR. Do you remember your droop setting or did you try adjusting it?
What was your ride height the shock oil you were using?
TEAM DRIVER==> BocaBearings|Pro-Line Racing|HWNA|Gens ACE|
EBSL - HW XR8 SCT PRO ESC & HW G2 4300kv motor
EXOTEK 22 SCT 2.0 - HW XR10 PRO ESC & HW Bandit 10.5t
EXOTEK 22T 2.0 - HW XR10 PRO ESC & HW G2 7.5T
DriveItLikeYSIT is offline   Reply With Quote
Old 01-10-2017, 07:48 AM   #4635
The PL pinpoints take a beating and get good use on turf. Have you guys tried the electrical tape trick on the front tires?
The off-road Tekno 3some-> EB48.4 - ET48.3 - SCT410.3 ---Soon eb410
The oval 3some -> Tekno SCT410.3 - Tekno SCT210.3 - Blitz
Sponsors: Fiercercsolutions.com, AKA, jtbearingco.com, CowRC, Walden Designs, Leadfinger Racing, And BoomRC.net
ezlight is offline   Reply With Quote
Tags
sct410, sct410.3, short course, short course 4x4, tekno
