    Hide Wikipost
Old 10-10-2017, 01:54 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC SCT410.3 Thread
Last edit by: DirkW
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8702 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree84Likes
Old 12-29-2016, 05:06 PM   #4561
EbbTide's Avatar
Trader Rating: 35 (100%+)
Originally Posted by weedsnager View Post
Will there be additional set up sheets coming out soon ? Just find it odd that the newest set up sheet is supposed to be for indoor and outdoor....how can it work for both conditions ?
Well it could be that the outdoor track uses similar dirt as the indoor track they tested on. I know our old local track had both outdoor and indoor 1/10 scale tracks and the grip was about equal on both. So I could setup my car with the same tires and drive on either track without worry.
EbbTide is online now   Reply With Quote
Old 12-29-2016, 06:15 PM   #4562
lowspark's Avatar
Chickened out for now, back to my standard set-up for tomorrow night racing LOL..
I want to try the new set-up, but I will wait until I have the new front steering parts.
(already have the rear hubs)
There is a very fine line between "hobby" and "mental illness".
Tekno SCT410.3 / Tekin RX8 Gen3 / Tekin Pro-4 HD 4300 / Savox 1268 servo / Spectrum DX5R
lowspark is offline   Reply With Quote
Old 12-29-2016, 08:00 PM   #4563
Tech Legend
Cain's Avatar
Trader Rating: 235 (100%+)
I am thinking it may be a better "base" setup what they posted. You will still tune from there, but having a great base really helps.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL | Yokomo YZ-2 DTM x 2>
Cain is online now   Reply With Quote
Old 12-30-2016, 02:22 AM   #4564
Weedsnager,
We have extensively tested this setup at our local indoor (SDRC Raceway) and outdoor track (heritage RC park) and we're surprised to find it worked well at both locations. Neither track is anything alike, SDRC is a medium size clay track and Heritage is a huge outdoor nitro track.
Only real change was to lower ride height to 19mm for indoor. Highly recommend this to be used as a base setup as it's easy to drive and jumps well.
Matt Wolter
Tekno RC - National Team Manager
MattDub is offline   Reply With Quote
Old 12-30-2016, 05:14 AM   #4565
Originally Posted by MattDub View Post
Weedsnager,
Matt, did you try this setup on the 48SL?
Losi 22 3.0 / Hot Bodies D413 / Xray XB4 '16 / Tekno SCT410.3 / Tekno EB48SL / Losi SCTE 3.0
Troyster is offline   Reply With Quote
Old 12-30-2016, 05:54 AM   #4566
Weedsnager,
Great info thank you
weedsnager is offline   Reply With Quote
Old 12-30-2016, 07:55 AM   #4567
Tech Legend
Cain's Avatar
Weedsnager,
Matt, this is the setup I put on to use for our carpet:
http://www.teknorc.com/wp-content/up...0Astroturf.pdf
From your general experience what would you lift from that setup specifically and use on the new recommended setup for carpet / astro / ultra high traction? Basically looking to hybrid the two and maybe have a nice new carpet setup.
Looked out at tower hobbies but saw no mention of the new steering parts that were used on the new base setup and it appears the plate is out of stock at Tekno too. Any ideas on when that will come back in and we will see it over at tower?
Old 12-30-2016, 08:24 AM   #4568
Cain,
I would try a few things, not sure if any of the changes I will recommend would make a difference since we have not run on carpet/Astro but we have found them to make a significant difference on dirt. We have found that changing the wheelbase to 5f 0r has provided more on power steering, reducing the antisquat to 0 (going up on the D block) helps the truck jump more nose down and going to the shortest link on the front has made the steering less aggressive.
Not sure I would recommend the HRC rear hubs as they provide more rear grip, probably not necessary on carpet/Astro.
Not sure when we will receive more tkr8100, should be within the next few weeks. If tower doesn't even have them listed then they will get them a couple weeks after we do. Looks like amain has limited quantities in stock. Recommend purchasing from them asap as they might be one of the few who have them.
Matt Wolter
Old 12-30-2016, 08:28 AM   #4569
Troyster,
Haven't tried this on the EB48SL, they behave very differently on the track so but I would try the wheel base, lower ride height (probably 23mm) and link positions. Not sure the 0 antisquat is necessary on this vehicle.
Matt Wolter
Old 12-30-2016, 11:34 AM   #4570
Tech Legend
Cain's Avatar
Cain,
Thanks I appreciate any help. The Tekno is pretty much like the "spec" car at the track lol. Main reason I went away from the tekno was the nose down issue so looking forward to seeing the changes affecting that.
Am I correct that this link will be the right size we also need for the whole "50mm" turnbuckle length?
tkr5550
http://www.teknorc.com/shop/tkr5550-...rontrear-2pcs/
Looks like went out of stock as soon as I went to buy it.
Old 12-30-2016, 10:11 PM   #4571
Weedsnager,
What ride height would you use for larger outdoor tracks with 1/8 jumps?
qstorm777 is offline   Reply With Quote
Old 12-31-2016, 12:04 PM   #4572
lowspark's Avatar
Cain, the 5550 part is for the buggy, you need #5123 for the SCT steering link.
Note, I made the same mistake when I read you had to cut the steering link down 6mm and I wanted to have an extra one in case I wanted to put it back to my stock set-up.
Hopefully I won't have to... next Friday will tell....
Old 12-31-2016, 12:05 PM   #4573
mxrcracer23's Avatar
Fairly new to short couse, do most cut a lot of vent holes in their bodies to get them to fly better? I had a jc raptor body that flew ok but then I cut several vent holes in it and made it almost uncontrollable in the air. I now have a jc f250 body, but have not cut any holes in it yet, any suggestions or is driver and vehicle specific? This is on a large 8th scale track with several big jumps
mxrcracer23 is offline   Reply With Quote
Old 12-31-2016, 12:12 PM   #4574
lowspark's Avatar
the modification note wrongly list the camber link #5550 as the part needed to be cut instead of the steering link #5123
"In order to obtain positive static toe, both left and right steering turnbuckles for the EB/NB48 (TKR5050) and SCT410/EB48SL (TKR5550) will need to be shortened by approx 6mm (3mm on each side of both turnbuckles)."
Old 12-31-2016, 01:01 PM   #4575
EbbTide's Avatar
In general I would stick with whatever cutouts they outlined from the factory. The only extra cutouts I've made were just to help cool components and didn't effect the flight much
Tags
sct410, sct410.3, short course, short course 4x4, tekno
