Tekno RC SCT410.3 Thread
#4516
When mine did this it was the shock body actually was slightly bent. I couldn't tell from just looking at it. When I put a new one on it didn't do it anymore.
#4517
on the .3, has anyone tried running the old rear shocktower on the rear to help with the rear end sliding? I left but came back LOL...I purchased a brand new .3 sct. I didn't drill the holes but had the old rear shock tower. I put the HRC hubs on and am going to run the longest link I can.
#4518
#4519
15-15-10 diffs
425-375 shocks
425-375 shocks
#4521
#4522
Ok. i know there is alot of discussion on this in the thread. my head is spinning..so if I want the least anti-squat possible, which is what 1 or 0 degrees?, what pills do i need in the stock C and D blocks? Center dot down on the C and Center dot up on the D? what's the math there if that's it?
#4523
#4524
Howdy guys...
understanding the how the dots on the pills is pretty simple once you grasp the concept. I will use the rear toe as an example.
Start with the C-block having one dot in the center. And the D-block having one dot in the center. That is the stock setting of 3 degrees of rear toe-in.
Now just changing the D-block pill. Keeping the pill on the center line, but the dot is now on the outside. You have changed the angle of the hinge pin 1 degree. You will now have 4 degrees of read toe-in.
If you use a pill with two dots (still on the center line) to the outside, 2-dots is only a half of degree of change. You would then have 3.5 degrees of toe-in.
This would work the same if you moved the dots to the inside instead of the outside. You would end up with 2.5 degrees using the 2-dot pill or 2 degrees if you used the 1-dot pill.
So single dots equal a 1-degree of angle on the hinge pin.
and two dots equal a .5-degree of angle on the hinge pin.
This works the same in each block.
If you move the center line dot on the C-block to the outside (single dot) and the center line dots on the D-block to the outside (single dot). You will still have the same 3 degrees you started with because you moved them both the same amount.
On the other hand if you move the C-block to the inside (single dot) and the D-block to the outside (single dot) you will now have 5 degrees of rear toe in...
the same applies for anti-squat in the rear.
In the front it is termed sweep and kick-up.
#4525
Anyone using game changer VRP pistons.
#4526
has anyone tried using the old rear shock tower to help calm the rear down and keep it from sliding out?
#4529
How much importance do you guys think a body has to do with handling ? Not talking about jumps...just how the truck handles at speed on straightaways and no grip in the corners.
When I first started with this truck it seemed to handle a lot better then It does now, I was thinking it all could have something to do with the body, these are the first two bodies I used
This is the last body I was using (I never put the number plate on)
Ive made other changes to the truck besides the body, but it seemed like whatever diff fluid, tires, pills, etc I tried the truck handled terrible with the body in the last picture...Could the body play that much of a roll ?
#4530
Hey Guys,
Wanted to post our new recommended setup for the SCT410.3. This works on most track conditions, indoor and out. Please give it a try and let us know! Thanks!
http://www.teknorc.com/wp-content/up...oor%20Dirt.pdf
