    Hide Wikipost
Old 10-10-2017, 01:54 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC SCT410.3 Thread
Last edit by: DirkW
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8702 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree86Likes
Old 04-20-2015, 02:43 PM   #436
Originally Posted by Jordan Anderson View Post
Both of these 1654X or 5571A fit the .3 stub axles?
They should both fit. I used TKR5571A
Our indoor track has a triple with a steep takeoff that lots of trucks scrub on launch and then nose dive on (my old truck nosedived less after switching to Fioroni pistons + green front / red rear springs). I didn't have any issues with nosediving at all on the SCT410.3 with 10x1.2 pistons and the light stock oil/spring combo, and didn't require much throttle input to maintain a neutral landing. That was one of my biggest takeaways of changing to the new truck
-Matthew Strong
Tekno RC / Dialed-RC Hobbies
Tekno NB48 / Tekno EB48 / Tekno SCT410
mstrong is offline   Reply With Quote
Old 04-20-2015, 03:02 PM   #437
Tech Legend
Cain's Avatar
Trader Rating: 239 (100%+)
Just what I wanted to hear!
< HB Racing D413 | Tekno EB48SL / SCT410.3 | Tekno EB410 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Cain is online now   Reply With Quote
Old 04-20-2015, 03:13 PM   #438
Ahhh man...u killin me...lol. I guess I need to inventory to old truck and spare parts. Take all my lightened stuff off of it and place my order.
qstorm777 is offline   Reply With Quote
Old 04-20-2015, 03:37 PM   #439
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Has anyony tried narrowing the truck using the new hinge pin adjusters? It looks like you could narrow the truck by 2mm. This would increase traction from my past racing experience.
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 04-20-2015, 04:06 PM   #440
Has anyone weighed the truck RTR with or without the battery?
MaX-D is offline   Reply With Quote
Old 04-20-2015, 04:58 PM   #441
Originally Posted by ezlight View Post
Don't let that stop you, I've ran composite pins in my xray for over a year, never had one break, I am building mine with them. As far as I'm concerned, less rotating mass, the better. I weighed one last night .6g I'll take that.
You are all probably right but I ordered them already so I will wait. They will be hear soon. Also does anyone run the aluminum center diff and motor mounts?
4s losi is offline   Reply With Quote
Old 04-20-2015, 05:21 PM   #442
Default Body
I have version 1. Will the body mounting holes for version 1 be the same as the body mounts on the 410.3?
Old 04-20-2015, 05:33 PM   #443
yes
The off-road Tekno 3some-> EB48.4 - ET48.3 - SCT410.3 ---Soon eb410
The oval 3some -> Tekno SCT410.3 - Tekno SCT210.3 - Blitz
Sponsors: Fiercercsolutions.com, AKA, jtbearingco.com, CowRC, Walden Designs, Leadfinger Racing, And BoomRC.net
ezlight is offline   Reply With Quote
Old 04-20-2015, 08:04 PM   #444
Trader Rating: 19 (100%+)
Does the .3 come with polished metal shock shafts or Ti coated gold ones?
Brandon Powell is offline   Reply With Quote
Old 04-20-2015, 08:09 PM   #445
FastPete's Avatar
Trader Rating: 44 (100%+)
Non TI
Authorized Dealer for /Agama / Tekno / Team Associated / Schelle / Hobbywing / PT Racing Shock & Diff oil / Serpent / Tekin / JConcepts / AKA / Proline / Savox / M2C / Picco / Raceform Jigs/ Proamps Servos-Lipos www.fiercercsolutions.com Like us on facebook www.facebook.com/FierceRCSolutions
FastPete is offline   Reply With Quote
Old 04-20-2015, 08:10 PM   #446
Originally Posted by FastPete View Post
Non TI
Thx Pete.
Old 04-21-2015, 07:40 AM   #447
Any chance of a .3 upgrade kit being offered for current sct410 owners?
Old 04-21-2015, 07:43 AM   #448
you are probably better off selling your current truck and buying a new .3
TEKNO SCT410.3; Hobbywing Sct-pro; Hobbywing 3656 4000kv; Protek 130S; SPC 70C 7200mAh 2s
TEKNO EB48.3; Hobbywing Xerun 150a; SMC 1900kv; Savox 2274SG; ECO Power 35c 4100mAh 4s
Associated B5R; Trackstar 120a turbo; Trackstar 8.5t; Solar D771; Reedy 65C 5800mAh 2s square
kyleman7 is offline   Reply With Quote
Old 04-21-2015, 08:11 AM   #449
FAO
FAO's Avatar
Location: Germany near famous clay track of RCRT Duisburg
Got my kit 30 minutes ago. Tks to Ruddog, Germany Jippiayeah....
Next Race: 2./3. of may, carpet outside
...have to change my signature.....later..., now i am on the way to the workbench
The former seastar:
Tekno SC 410.3, Serpent Spyder SCT, dust, loomy, slippery, dirt
FAO is offline   Reply With Quote
Old 04-21-2015, 08:31 AM   #450
Tech Legend
Cain's Avatar
congrats!
Anyone who ordered from tower get one from the Illinois site (or whatever that other one is more in the midwest)
Tags
sct410, sct410.3, short course, short course 4x4, tekno
Currently Active Users Viewing This Thread: 6 (1 members and 5 guests)
daddyo
