    Hide Wikipost
Old 10-10-2017, 01:54 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC SCT410.3 Thread
Last edit by: DirkW
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8702 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree83Likes
Old 12-12-2016, 07:54 PM   #4471
JoeRC123's Avatar
Originally Posted by [email protected] View Post
Also another few quick questions.
Am i better off setting up shocks emulsion or vented?
Outdoor Track surface will vary from hard packed smooth to rough/bumpy. Also jumps involved.
Mark
Vent is what what the fastest guys are running at the local track so I went that way.
JoeRC123 is offline   Reply With Quote
Old 12-13-2016, 06:42 AM   #4472
Ok thanks guys. I just want to use the 160amp esc from my 1/10 buggy without having to buy a new one.
Lastly we dont have a class of racing for 4wd sct locally here because there is not enough numbers. However there are now probably enough of us now to start one. I am going to run 1/8 wheels on mine. For you guys that race- do they allow the use of 1/8 wheels in the same race as those using 1/10 wheels?
Does it handle/jump better with 1/10 wheels or 1/8 wheels?
Cheers
Mark
I recently switched to emulsion style shocks. I like them better, and finally remembered that's how I built the shocks on my V1 sct.
For those just building the kit, if you drill the vent hole through where the screw goes in the cap, you can use the same shock caps to swap between the styles. If you drill the hole where the instructions say to for the vent, you'll need another cap set to try emulsion.
The off-road Tekno 3some-> EB48.4 - ET48.3 - SCT410.3 ---Soon eb410
The oval 3some -> Tekno SCT410.3 - Tekno SCT210.3 - Blitz
Sponsors: Fiercercsolutions.com, AKA, jtbearingco.com, CowRC, Walden Designs, Leadfinger Racing, And BoomRC.net
ezlight is offline   Reply With Quote
Old 12-13-2016, 06:51 AM   #4473
Matt1970's Avatar
Originally Posted by qstorm777 View Post
Question, on both the c and d blocks, the setup is on the bottom holes. Can't you move those up to raise the roll center to get a little more? Which adjustment affects roll center more, the shock towers or the blocks?
Good questions? anybody have answer on these?
Mugen XB7R Eco Tekin RX8 Gen 2 / Tekin 2050kv
Tekno SCT410.3 Tekin RX8 Gen 2/ 4300HD/BCE Chassis
Future additions: Whatever I can get without my wife seeing it!!!
"When in doubt, FULL THROTTLE. It may not be the best solution, but it ends the suspense."
Matt1970 is offline   Reply With Quote
Old 12-13-2016, 06:58 AM   #4474
Tech Legend
Cain's Avatar
Trader Rating: 235 (100%+)
I remember back in my V1 days the car my daughter was using had the same setup as i was using except had emulsion shocks. I was using the "big" vent style setup (the Emulsion hold drilled and left open) and the way her truck handled it landed jumps more "dead" than mine. By that I mean, it felt like it just hit the ground and stayed down. It was easier to get on power again with her setup than with mine.
I am thinking of trying that here unless someone knows where vents would be better than the emulsion setup that I could take advantage of. Carpet high traction, slightly bumpy.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL | Yokomo YZ-2 DTM x 2>
Old 12-13-2016, 07:03 AM   #4475
I would say your better off running emulsion. You don't want any bounce on carpet/turf. You want to get down and on power.
A trick I was told for turf to avoid traction rolls, to stay on power through turns, that if you let off throttle your going over. (I've never raced 4wd on carpet, only dirt\clay\turf) Last time out I was told to put one strip of electrical tape on the outside of the front wheels, that you can push a little more into the turns. This helped me a lot where I tend to overdrive corners and traction roll on turf.
Old 12-13-2016, 12:23 PM   #4476
Tech Legend
Cain's Avatar
yeah i was tempted to glue the outer side wall of my tires like my old carpet touring foam tire days lol. we all pretty much run clay slicks or something harder.
You guys see this info on the new steering parts:
Originally Posted by Matthew_Armeni View Post
It's different geometry that alters the ackermann. The best way to describe it is that it makes the steering feel smoother. It transitions better on and off power as well as beginning, middle, and end of a turn. The old geometry was pretty aggressive and once you started the turn the car could really start to come around on you. So if you had an increasing radius turn you often time would be turning too much, then counter steering to correct, then turning more to get back in line, etc. The new geometry fixes that. You can still get a lot of steering out of the car, but it is so much more usable than before. I really like the new steering setup in my SC truck, really helps calm it down.
Ok, you'll have to cut the sc turnbuckles down as well. 3mm per side, which is what the buggy should be as well (I updated my earlier post).
Associated appears to have the right size turnbuckle too as well as lunford, with AE being cheaper. This is assuming its 4 x 50mm turnbuckle needed.
I remember that weird steering issue on my old SCT410.1 I had on long sweepers. Maybe this would help.
Old 12-13-2016, 12:25 PM   #4477
Back to your old Self Cain....That didn't take you long!
Old 12-13-2016, 12:36 PM   #4478
Tech Legend
Cain's Avatar
lol you know I can't help it
So, did a bit of searching but didn't see anything specific, on average if you did the 1 to 1 swap of lunsford turnbuckles for the stock SCT410.3 turnbuckles (NOT the SCT410 Lunsford kit) how much weight savings was seen?
Another option, assuming if you cut these you still have enough thread left:
TD310215 Team Durango Aluminum Turnbuckle 4x60mm
Old 12-13-2016, 01:14 PM   #4479
I doubt the benefits are worth the expense. Not too sure I would want titanium buckles anyhow.
Old 12-15-2016, 09:33 PM   #4480
Tech Legend
Cain's Avatar
if any of you guys who are doing cut mudguards or basically don't need the parts seen in this part # TKR5065, shoot me a pm as I am interested in purchasing.
Old 12-16-2016, 02:05 PM   #4481
im having an issue where my top cover does not line up, its about a half screw diameter off center and i have to pull the front end towards the back to be able to get it to line up to get the screw started. the problem with this is i get binding in my steering when the front end is pulled back like that, the binding starts when im turning to the left, just a little bit past center i feel it hit something, and then when i continue to turn to the left i can feel it dragging a decent bit but i cant see what its hitting on, however if i undo the front 2 bolts on the front of the cover then theres no binding and it feels fine. im unsure what the issue is here.
you can see the holes not being aligned here(i unbolted the 4 bolts holding the front of the car to the chassis)
[/url]
heres how i have to pull the front to the rear to get them to align just to get the screws in
[/url]
and heres about how far left i need to steer before i feel it start to rub against something, i have not driven this car yet this is still being built
[/url]
gokitty199 is offline   Reply With Quote
Old 12-16-2016, 03:20 PM   #4482
Josh L's Avatar
It seems more likely you have a bent or faulty milled chassis than it would to have a defective top brace in my opinion that would be more likely if it is infact a fitment issue.
Can you take some measurements of the chassis holes. And you might want to remove the front and rear to get the pan fully exposed to have a better look at.
Josh L is offline   Reply With Quote
Old 12-16-2016, 03:23 PM   #4483
do you want me to measure the from the front of the chassis to the holes?
Old 12-16-2016, 03:37 PM   #4484
Josh L's Avatar
You prolly need to measure it that way as well as from the back holes to the front holes to see if you have square. Also examine the bend in the chassis plate real well and make sure there isn't even the slightest twist to it. It certainly shouldn't be as tight to the point of binding as you're explaining so it's going to be a process of elimination unfortunately.
Old 12-16-2016, 03:57 PM   #4485
from back left to front left the holes are about 1/16th shorter than from the back right to the front right holes, i see no twisting or bend in the chassis at all, looks straight as an arrow visually.
Tags
sct410, sct410.3, short course, short course 4x4, tekno
Currently Active Users Viewing This Thread: 8 (0 members and 8 guests)
