    Hide Wikipost
Old 10-10-2017, 01:54 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC SCT410.3 Thread
Last edit by: DirkW
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8702 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree83Likes
Old 12-10-2016, 06:51 AM   #4456
Tech Legend
Cain's Avatar
Trader Rating: 235 (100%+)
Originally Posted by celt View Post
Welcome back Cain!
Thanks!
did a quick go through of what I got here and for used it looks pretty good for what counts. Will give it the full teardown treatment, chassis of course has the good used look but I figured that would be the case lol.
As for carpet setup, in general the raising the rear link helped with freeing up the rear end on rotation. For the tight tracks here it really helped a lot.
One thing I noticed is that the astro turf setup runs pretty stiff sway bars. I ordered them to try the setup out as here you can traction roll unsauced clay slicks on the carpet.
I also did a test fit of the xray "wundersprings" progressive greys that were used on the durango desc10 I had as recommended by a guy in europe who modified his vehicle specifically for carpet, including a custom graphite chassis.
Anyway, I figure if they work well with alittle more roll on the desc10 stock, they could work well on the tekno and be worth a try. I put them on and they fit the cups well, little more room from the shock body so need to confirm they dont' hit anything suspension wise but I think they will be fine. Another benefit is that they are very short. This will allow some really low ride heights for sure.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL | Yokomo YZ-2 DTM x 2>
Cain is online now   Reply With Quote
Old 12-10-2016, 02:26 PM   #4457
Originally Posted by jnyrcr View Post
I'm going to try a 3400kv hobbywing on 2S, has anyone run this and if so do you remember what pinion gear you were running? thank you in advance, I've tried searching but can only find a few that ran it but no specifics.
jnyrcr is offline   Reply With Quote
Old 12-10-2016, 02:51 PM   #4458
Matthew_Armeni's Avatar
Trader Rating: 31 (100%+)
Haven't ran that myself but if I wanted it to be the same top speed as my Tekin 4600 I would run a 20 tooth pinion. I currently run a 15 pinion with the 4600.
Tekno RC
Matthew_Armeni is offline   Reply With Quote
Old 12-10-2016, 03:13 PM   #4459
Tech Legend
Cain's Avatar
One way to find what gear to start with is find the gearing someone else is using at your track, punch in the numbers into a speed calculator, then, use your gear and target the same theorectical top speed. Watch temps, but that can get you into the ball park.
so, what is the current word on chassis to use if you plan to replace it? stick with stock SCT410.3 or spring for what, the eb48.3 one, the M2C, etc?
Old 12-10-2016, 03:36 PM   #4460
Thank you, appreciate the help
Old 12-10-2016, 08:25 PM   #4461
Default Tekno sct 410.3 and 160amp xr10pro
Hi guys. Just purchased one of these fine kits. My first sct (i run 1/10 buggies) and was impressed after driving a friends one.
Can anyone tell me is it okay to run a hobbywing xr10 pro 160 amp esc running 2s with a 2 pole 550 motor. I think its 3150kv. Its then king turnigy sct motor.
Cheers
Mark from down under.
crowie03@gmail. is offline   Reply With Quote
Old 12-11-2016, 07:44 AM   #4462
Tech Legend
Cain's Avatar
Cheers
well, I can say this. Back when the first SCT410 came out we ran the Speed Passion GT2.0 Pro with the 2 Pole 550 and 4 Pole 540 and "545" motors without issue. This is basically the hobbywing ESC V2.0 or whatever.
I would personally think the XR10 pro is even more powerful, however, I would say they have an ESC right now that will do the job and is made specifically for it, and is cheaper too the XR8 SCT Pro Esc. I would go with that.
For motor, if you don't have to use say a 540 4 pole / 550 2 pole, The Hobbywing 4000Kv 3656SD is a great motor and I really like the Maclan 4150kv motor (I use this now).
Alright so I did my teardowns, the vehicle I picked up used came with a lot of parts and some cut springs. Other than the usual checking of bearings, etc. What do you guys look for as to determining to get a new chassis?
Old 12-11-2016, 07:46 AM   #4463
Cheers
I'm pretty sure you can, but I would check this thread first Hobbywing xr10 pro , Page 9, post 126 of that thread should help.
Old 12-11-2016, 12:29 PM   #4464
Ok thanks guys. I just want to use the 160amp esc from my 1/10 buggy without having to buy a new one.
Also another few quick questions.
Am i better off setting up shocks emulsion or vented?
Outdoor Track surface will vary from hard packed smooth to rough/bumpy. Also jumps involved.
Lastly we dont have a class of racing for 4wd sct locally here because there is not enough numbers. However there are now probably enough of us now to start one. I am going to run 1/8 wheels on mine. For you guys that race- do they allow the use of 1/8 wheels in the same race as those using 1/10 wheels?
Does it handle/jump better with 1/10 wheels or 1/8 wheels?
Cheers
Mark
Old 12-11-2016, 12:49 PM   #4465
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
Some tracks will allow the 1/8th scale wheels. If I'm directing a race I won't. The 1/8 wheels definitely handle better. There is a lot less sidewall flex. You can get a short course tire to feel almost like an 1/8 tire but you have to be a wizard with the tire glue.
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 12-11-2016, 01:19 PM   #4466
Tech Legend
Cain's Avatar
If you decide though to keep it more SCT style, just get some 17mm SCT wheels. Work great on the desc10 I had.
Old 12-12-2016, 05:42 AM   #4467
shadaloo's Avatar
I have both kinds of DE SCT 17mm wheels and I love them. I did try my EB tires on it before, but for whatever reason I didn't care for the setup I was using with SCT wheels, with EB wheels.. I didnt really adjust anything I don't think. So ride heith and stuff was probably all jacked.
shadaloo is offline   Reply With Quote
Old 12-12-2016, 06:51 AM   #4468
When there is a hole through the chassis at the read diff housing...Paperthin. LOL
The off-road Tekno 3some-> EB48.4 - ET48.3 - SCT410.3 ---Soon eb410
The oval 3some -> Tekno SCT410.3 - Tekno SCT210.3 - Blitz
Sponsors: Fiercercsolutions.com, AKA, jtbearingco.com, CowRC, Walden Designs, Leadfinger Racing, And BoomRC.net
ezlight is online now   Reply With Quote
Old 12-12-2016, 02:18 PM   #4469
Anyone off the top of their head know what the track width of the 410.3 is?
Malazan is offline   Reply With Quote
Old 12-12-2016, 03:43 PM   #4470
Tech Legend
Cain's Avatar
lol good stuff. I'll go ahead and rebuild with this chassis and see what is what when the eb48.4 version comes out in case something changes.
Tags
sct410, sct410.3, short course, short course 4x4, tekno
