    Hide Wikipost
Old 10-10-2017, 01:54 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC SCT410.3 Thread
Last edit by: DirkW
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8702 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree86Likes
Old 11-20-2016, 07:19 PM   #4351
Matthew_Armeni's Avatar
Trader Rating: 31 (100%+)
Originally Posted by JoeRC123 View Post
I'm having issues with the inside of wheel rubbing on the rear A-arm. Am I supposed to space the hexes off using washers or something? This is the second set of wheels that rubbed. They are Jconcepts Hazard wheels, 3mm offset. the Tekno FAQ says that LOSI SCTE wheels are compatible, which these are (wrong! see below Edit)..
https://www.amainhobbies.com/jconcep...o3344b/p212763
Edit: These wheels are actually not LOSI compatible, they are Associated compatible. I wonder if that's the problem? A fellow racer at the track hobby shop may have given me the wrong wheels. The part number 3352B is the LOSI SCTE wheel. Crap. Good thing I checked before I glued them.
That's probably the issue, they're not the SCTE wheel. Even though the AE wheel has that +3 offset which you would think would give more clearance, there's usually less because they have more webbing inside.
Tekno RC
Matthew_Armeni is offline   Reply With Quote
Old 11-20-2016, 07:31 PM   #4352
Kremzeek's Avatar
I had the same problem with some older Proline wheels. I picked up these hexes and then added about .5mm worth of shims just to be on the safe side.
http://www.teknorc.com/shop/tkr1654x...d-ae-sc10-4x4/
Kremzeek is online now   Reply With Quote
Old 11-20-2016, 07:46 PM   #4353
JoeRC123's Avatar
Originally Posted by caffeine357 View Post
Ive always been happy with DE racing wheels amongst a number of my cars and cant recommend them enough.
Yes thanks, I also found that out in my research today. The Borrego is a disk looking but stronger, the Trinidad is a little cooler looking but not as strong from what I read.
Here are the DE Racing part numbers that I plan on using:
Borrego DER-SCB-LB (black, front and back)
Trinidad DER-SCT-LFB (black, front only)
Trinidad DER-SCT-LRB (black, back only)
JoeRC123 is offline   Reply With Quote
Old 11-20-2016, 08:26 PM   #4354
Hi folks,
I've been following this forum for a bit and I'm a big fan of Tekno.
Just about to pull the trigger on a sct410.3 and would thought i'll ask for opinions about the electronics.
I'm planning to use it for casual racing at outdoor loose coarse dirt BMX tracks some the size of 1/8 and some 1/10th. It's mostly going to be fun with friends and no RC clubs so no requirements for ROAR legal electronics.
I'm leaning towards Hobbywing for the ESC + Motor. Should I be looking at 3400, 4000 or 4700 KV for these sort of tracks?
My budget is up to $200 for ESC & Motor and I'm open to other suggestions besides HW
Cheers!
sct_shift is offline   Reply With Quote
Old 11-20-2016, 08:37 PM   #4355
JoeRC123's Avatar
Thanks.
Old 11-20-2016, 08:38 PM   #4356
JoeRC123's Avatar
Thanks.
Old 11-21-2016, 12:11 PM   #4357
[QUOTE=raved007;14739077]
Originally Posted by rcnewbie418 View Post
To be honest the SCTE 3.0 is amazing easy to drive with stock set up and more planted and faster entering/Exit in the corner. The tekno guy sponsor i always got him inside the corner with 180 turn. My SCT410.3 i mod battery location with BCE chassis but my driving style is still not good. I think if you running indoor track i'll go with SCTE 3.0 but outdoor SCT410.3.
Until the bearings go and you DNF due to a blown diff housing...The inferior engineering, and inferior plastics...Also won't take long to slop out...Yup, I'll stay away, thanks.
The off-road Tekno 3some-> EB48.4 - ET48.3 - SCT410.3 ---Soon eb410
The oval 3some -> Tekno SCT410.3 - Tekno SCT210.3 - Blitz
Sponsors: Fiercercsolutions.com, AKA, jtbearingco.com, CowRC, Walden Designs, Leadfinger Racing, And BoomRC.net
ezlight is offline   Reply With Quote
Old 11-21-2016, 12:24 PM   #4358
Originally Posted by sct_shift View Post
Hi folks,
Cheers!
assuming you are running 2s the 4000kv would be good. i have used it for a while and like it.
Tekno SCT410.3
Tekno EB48.4
Tekno EB410
snowninja is offline   Reply With Quote
Old 11-21-2016, 12:51 PM   #4359
You don't want the ones that say front only...They're bearing wheels, not hex.
Old 11-21-2016, 12:55 PM   #4360
Cheers!
Yup, the 4000kv motor with a 18t pinion is nice...Or the 4700kv with a 16t pinion. Both should keep a smile on your face.
Old 11-21-2016, 02:22 PM   #4361
Thumbs up
Thanks a lot I guess 4000 with 18t it is then!
Should I pair it with Hobbywing's 120A SCT-PRO or the newer 140A XR8 SCT PRO
Old 11-21-2016, 02:26 PM   #4362
I would suggest the newer sct pro, since it can now go up to 7.4v for BEC
Old 11-21-2016, 02:55 PM   #4363
Great! Thanks a lot for your help
Old 11-21-2016, 02:57 PM   #4364
So I have a 3000kv on 3s, and a 3500kv on 2s
What pinion should I try first for each of these,
LOL, is a 20t to much for the 3000kv?
I see 16-18 on the 4000-4700kv motors, wouldnt a lower Kv motor necessitate a larger pinion?
Malazan is offline   Reply With Quote
Old 11-21-2016, 03:23 PM   #4365
What SCT body do you guys run and are there any that arent roar legal not like I think I would be stopped at my local race track but its probably good to know.
Id like to get something a little unique like the Ford Bronco.
On the other hand I race outdoors alot so maybe getting a gimmicky body isnt the best so in addition which one would you guys recommends for jumping and racing performance.
caffeine357 is online now   Reply With Quote
Tags
sct410, sct410.3, short course, short course 4x4, tekno
