    Hide Wikipost
Old 10-10-2017, 01:54 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC SCT410.3 Thread
Last edit by: DirkW
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8702 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree83Likes
Old 11-16-2016, 07:51 PM   #4336
Originally Posted by rcnewbie418 View Post
Ok, I've had this truck about 6 months. Love Tekno, have/had their buggies. No issues. For this truck, I've run it on loose outdoor and now a few times indoor on clay. The truck has the battery mod and I've had no issues with nose down (actually lands great), BUT for the life of me can't get the rear planted. It's pretty good in and out of the tight turns within a track but going down a straight into a sweeper kills me every time. I have to let up just to make the turn (or oversteer) without the rear spinning out while other trucks go right through it. I've tried everything (hubs forward, springs, oils, shocks up/down, long links, etc). I'm just starting to accept that with the battery mod, this truck just can't get that balance to hit a sweeper full speed. Just don't know if I'm still missing something, my skill level (racing about a year) or do I just learn to drive what the truck will give? I don't really have a question here, just ranting I guess..carry on.
I believe what you need to do is induce a little more roll in the rear. At high speed this will help plant the rear so it doesn't want to rotate. Be careful with inducing too much roll as this will prevent the truck from steering in the corners. Best thing is to move the rear camber link up on the tower. After you've tried that, possibly going to one spring lower on the rear or moving the rear shocks in on the rear tower could help too. Wouldn't recommend the last two until you tried going up on the rear tower camber link.
Matt Wolter
Tekno RC - National Team Manager
MattDub is offline   Reply With Quote
Old 11-17-2016, 03:53 AM   #4337
Originally Posted by ezlight View Post
Yes it does. You'll need the extended body posts. Not optimal for racing, but perfectly find for bashing.
Thank you for your help...Yeah...i will get the othor body shell for Bashing.
Lloyd16 is offline   Reply With Quote
Old 11-17-2016, 05:55 AM   #4338
Matt, wouldn't a softer rear sway bar be a tuning option to address this?
The off-road Tekno 3some-> EB48.4 - ET48.3 - SCT410.3 ---Soon eb410
The oval 3some -> Tekno SCT410.3 - Tekno SCT210.3 - Blitz
Sponsors: Fiercercsolutions.com, AKA, jtbearingco.com, CowRC, Walden Designs, Leadfinger Racing, And BoomRC.net
ezlight is offline   Reply With Quote
Old 11-17-2016, 06:36 AM   #4339
Trader Rating: 18 (100%+)
[QUOTE=raved007;14736614]
Ok, I've had this truck about 6 months. Love Tekno, have/had their buggies. No issues. For this truck, I've run it on loose outdoor and now a few times indoor on clay. The truck has the battery mod and I've had no issues with nose down (actually lands great), BUT for the life of me can't get the rear planted. It's pretty good in and out of the tight turns within a track but going down a straight into a sweeper kills me every time. I have to let up just to make the turn (or oversteer) without the rear spinning out while other trucks go right through it. I've tried everything (hubs forward, springs, oils, shocks up/down, long links, etc). I'm just starting to accept that with the battery mod, this truck just can't get that balance to hit a sweeper full speed. Just don't know if I'm still missing something, my skill level (racing about a year) or do I just learn to drive what the truck will give? I don't really have a question here, just ranting I guess..carry on.[/QUOT
Try something new if not fit to your driving skills. I have tekno 410.3 with ton of upgrade I just sold here. I am not bashing this thread I love tekno products most durable kit that I have same with xray but my driving skills not fit so i try to get SCTE 3.0 and my driving skills fit easier to drive than tekno. My local track never beat tekno guy sponsor since we're both tekno but when i got the SCTE 3.0 lucky i beat him twice in race.
Thanks for the input (other guys too). I think you nailed it though on driving style/skill. I'm going to try the suggested changes this weekend, but i think you might be right. Yeah Tekno's awesome. Ran an EB48.2 all spring and summer and it was great. The .3 is in my shopping cart as we speak. But for SC...we'll see. Thanks guys
rcnewbie418 is offline   Reply With Quote
Old 11-17-2016, 06:50 AM   #4340
[QUOTE=rcnewbie418;14738385]
Don't give up on the SC just yet. I'm still working on my setup now, but I had my last truck pretty close to dialed. Kinda wish I didn't sell it. This truck can be really, really good. Just have to work on setup to find what you like. Make a change, run a pack. See how it feels. Best way to figure out what each change does, and which way you need to go.
Old 11-17-2016, 07:20 AM   #4341
Tech Legend
Cain's Avatar
Trader Rating: 235 (100%+)
Originally Posted by CarlosRS4 View Post
Someone has a 4300HD for sale $75.00 shipped I was thinking on getting
If you are hepped up on getting the Tekin I would say compare that price to what they go for in a range on ebay and that should give you an idea if thats a fair price.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL | Yokomo YZ-2 DTM x 2>
Old 11-17-2016, 08:45 AM   #4342
For sure, anything to induce a little more roll in the rear will help with high speed sweepers.
Matt Wolter
Old 11-17-2016, 08:54 PM   #4343
Trader Rating: 32 (100%+)
To be honest the SCTE 3.0 is amazing easy to drive with stock set up and more planted and faster entering/Exit in the corner. The tekno guy sponsor i always got him inside the corner with 180 turn. My SCT410.3 i mod battery location with BCE chassis but my driving style is still not good. I think if you running indoor track i'll go with SCTE 3.0 but outdoor SCT410.3.
raved007 is offline   Reply With Quote
Old 11-19-2016, 06:39 PM   #4344
shadaloo's Avatar
Originally Posted by Lloyd16 View Post
Anyone use Proline Ford bronco Body shell for Sct410.3?Is it fit?
I have this, the proline screw on body mounts, and the MKS 599 servo (up from Savox 1267/1268)! I can't wait to try em out.
Aside from the Ford Bronco, any other good bodies to try that are different? Mainly looking for various practice bodies... I love my Jconcepts Ford Raptor Xflow for racing....
Super excited to try out my MKS 599, it was supposed to arrive today but it got delayed, so looks like Monday i'll get it!
shadaloo is offline   Reply With Quote
Old 11-19-2016, 07:32 PM   #4345
justpoet's Avatar
Trader Rating: 16 (100%+)
I'm glad that by the sounds of your description the SCTE 3.0 is finally able to provide the Tekno some competition. Tekno just had a huge unfair advantage prior. Let the racing begin! :-D
"We do not act rightly because we have virtue or excellence, but we rather have those because we have acted rightly. We are what we repeatedly do. Excellence, then, is not an act but a habit." -Aristotle
My wallet supports: TeknoRC.com, NorCalHobbies.com, SMC, Tekin, and several tire/servo companies.
justpoet is offline   Reply With Quote
Old 11-20-2016, 07:55 AM   #4346
Tech Legend
Cain's Avatar
I am glad to see the vehicle battles still going on in 4x4 SCT. Enjoy the class and hope it stays around. Its popular out here with Tekno leading the way from the vehicle types I see. the make excellent vehicles for those starting out who want a tough vehicle that handles well too.
Old 11-20-2016, 12:54 PM   #4347
Lowe's48's Avatar
Yes,here at our track too. The battle between Tekno and Losi is alive and well. The matter of fact we've been running B main in our club races lately
Tekno Sct410.3-VRP,HW120 SCT-PRO,Pro4-4300kv,Hitec,LRP 8000/2s
Tekno SL.3-VRP,HW120 SCT-PRO,T8i-1950,Hitec,LRP 5000 4s
Weapon of choice : Airtronics M12
Home track : Coyote Hobbies,Ca
Lowe's48 is offline   Reply With Quote
Old 11-20-2016, 12:59 PM   #4348
Lowe's48's Avatar
Originally Posted by Malazan View Post
Ran a really bumpy dusty track today, rear end real loose on power,
Any setup suggestions?
3s
3000kv
Front Green 30wt
Rear Green 35wt
7-7-5
All chassis braces in
Stock toe, camber settings, anti-squat, shock mounts, camber mounts
Try running 25wt in rear and run less anti squat.
Old 11-20-2016, 04:25 PM   #4349
JoeRC123's Avatar
I'm having issues with the inside of wheel rubbing on the rear A-arm. Am I supposed to space the hexes off using washers or something? This is the second set of wheels that rubbed. They are Jconcepts Hazard wheels, 3mm offset. the Tekno FAQ says that LOSI SCTE wheels are compatible, which these are (wrong! see below Edit)..
https://www.amainhobbies.com/jconcep...o3344b/p212763
Edit: These wheels are actually not LOSI compatible, they are Associated compatible. I wonder if that's the problem? A fellow racer at the track hobby shop may have given me the wrong wheels. The part number 3352B is the LOSI SCTE wheel. Crap. Good thing I checked before I glued them.
JoeRC123 is offline   Reply With Quote
Old 11-20-2016, 06:14 PM   #4350
Ive always been happy with DE racing wheels amongst a number of my cars and cant recommend them enough.
caffeine357 is offline   Reply With Quote
Tags
sct410, sct410.3, short course, short course 4x4, tekno
