    Hide Wikipost
Old 10-10-2017, 01:54 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC SCT410.3 Thread
Last edit by: DirkW
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8702 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree83Likes
Old 10-25-2016, 12:06 PM   #4231
jason07's Avatar
Thank you ANR!!
Agama A215E Hobbywing 1900KV and Xerun XR8
Agama A215 Bullitt B221
jason07 is offline   Reply With Quote
Old 10-25-2016, 09:24 PM   #4232
Hey guys,
I just picked up a used roller of a 410.3 I moved cross country and no longer have access to the indoor track I was planning to race at.
I have a D413 that I picked up that has a
7.5 turn LRP X-20 modified motor
a novak GTB ESC
and a hitech-5996TG servo
can any of this be used for the SCT or will it need all new electronics?
I may sell the D413 complete or as a roller depending on what you guys think.
Or i could scavenge from my 8th scale Arrma Typhon but it has all the stock electronics and a Savox servo SC1256TG
Jaynen is offline   Reply With Quote
Old 10-26-2016, 02:00 AM   #4233
Mrbigglesworth's Avatar
The electronics from your D413 will be under powered for the truck.
Most guys seem to be using 4 pole motors around 4000 to 4800kv and Tekin RX8 or Hobbywing esc's.
I've been running the Tekin for quite a while but it sounds like the Hobbywing is really good and is a bit cheaper:
http://www.hobbywingdirect.com/products/xerun-xr8-esc
Your Savox 1256 would do the job for steering.
Mrbigglesworth is offline   Reply With Quote
Old 10-26-2016, 04:42 AM   #4234
I ordered the hobbywing 4000kv last night, Ill nab the servo off my 8th scale and replace it down the road
Old 10-26-2016, 10:24 AM   #4235
Sounds good you will love it!! There is gearing information in the first post if you haven't read it already...
Old 10-26-2016, 10:26 AM   #4236
I ordered an 18T for now based on the comments in this thread to go with the 4000kv setup
Old 10-26-2016, 10:44 AM   #4237
18t is perfect for the 4000kv. 17t if on a smaller technical track...But I always ran 18t
The off-road Tekno 3some-> EB48.4 - ET48.3 - SCT410.3 ---Soon eb410
The oval 3some -> Tekno SCT410.3 - Tekno SCT210.3 - Blitz
Sponsors: Fiercercsolutions.com, AKA, jtbearingco.com, CowRC, Walden Designs, Leadfinger Racing, And BoomRC.net
ezlight is offline   Reply With Quote
Old 10-26-2016, 10:49 PM   #4238
Josh L's Avatar
To add to the convo, I wouldn't suggest getting the the XR8. I have that ESC and it's huge and to heavy for the already nose heavy chassis.
Hobbywing just announced their new SCT Pro and it now has a 7.4v BEC with the ability to WIFI connect with an adapter.
Here is a chart to look at that I made for comparison
Josh L is offline   Reply With Quote
Old 10-27-2016, 09:54 AM   #4239
Yeah, I wish I knew Hobbywing was coming out with that one before I bought the XR8 Plus. Just curious tho Josh, have you run both and noticed a difference? If so, what were the differences?
qstorm777 is offline   Reply With Quote
Old 10-27-2016, 10:48 AM   #4240
Josh L's Avatar
I can't tell you from personal experience, but from what I am reading on it, there really isn't any difference besides have a lower cell count capability and being much smaller and lighter.
I downloaded the latest HW PC link software and it's not mentioned in the drop down list yet. The newest addition to that software revision is the XR10 Pro, which is another viable option for an SCT ESC believe it or not.
A friend runs one on his SCTE
Old 10-27-2016, 01:26 PM   #4241
This is the one I got, it says SCT pro butnot XR8
https://www.amainhobbies.com/hobbywi...040201/p279179
Old 10-27-2016, 11:10 PM   #4242
Josh L's Avatar
Yes, that is the original version. I have this ESC as well. It has been a great ESC over all, and it has a good feel to it. But it lacks a decent BEC with only 6v @ 3A. That is good for many servos, but if you're like me and run high torque/speed Hight voltage servos, then it can't run them reliably.
To fix this issue I ran an external castle 10amp adjustable BEC and bypassed the ESC's BEC by removing the red Rx input wire. I like to run my servos at a minimum 7.2-7.4v and it's easier on the system as well thanks to that extra voltage reducing the need for as much amps for lower resistance.
If you have a servo that can deal with 6v, then your all set for long time.
Be careful of that switch though, it's not as robust as the XR8 switches are and you can't just clip it off if it shorts like you can with other ESC's.
If you don't have the switch on the hobbywing ESC, it will eventually loose calibration and must have it on there to reset.
Old 10-29-2016, 07:52 AM   #4243
Default New build!
Hello all! Picked up my first Tekno vehicle and I'm glad to be aboard the Tekno train! Any recommendations for setup sheets for indoor clay? I'll be running at OCRC here in southern California. Any suggestions before I start the build? I thumbed through the thread and everyone seems to have very few issues with the build. Thanks for the advise in advance! See you guys on the track!
claytrackstar is offline   Reply With Quote
Old 10-29-2016, 12:45 PM   #4244
Thrifty's Avatar
Tekno's site will link you to some setups. You'll most likely find one for your track.
Thrifty is offline   Reply With Quote
Old 10-29-2016, 03:32 PM   #4245
Josh L's Avatar
Shaun Brown High Bite Clay Setup
Tags
sct410, sct410.3, short course, short course 4x4, tekno
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
