    Hide Wikipost
Old 10-10-2017, 01:54 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC SCT410.3 Thread
Last edit by: DirkW
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8702 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree83Likes
Old 10-16-2016, 04:06 PM   #4186
Suspended
Originally Posted by qstorm777 View Post
6x1.5 seems to be pretty common.
Awesome, gonna order some and see how they do!
Been flawless all day today the track, next Saturday I'll be racing it with the new smc batts I have. Ran I to a issue today tho.... My motor mount kept coming loose.
I tried installing a. Ew screw and it only threads 1-2 threads and comes out after a few laps... The next size up in screw hits something in the can.... Any ideas? Or what size screw to use? I tried using a washer W/ the longer screw but then it won't fit...
I use a Tekin 4300pro4 HD and have never had an issue until today. The same screws I have always used are too short now..
I'll post a picture later if no one understands what I mean haha
deceit is offline   Reply With Quote
Old 10-17-2016, 08:20 AM   #4187
Suspended
I'm new to learning about pistons, so I'm curious...why does the SL use 4x1.8, but the SCT isn't even on TKR6159 parts compatibility list? Why does the SCT use 6 or 8, vs the Eb, nb, and even SL 4 hole?
Also, since my above issue with the motor mount, I might buy a new spur, is steel the way to go? I've never had any issues with composite, just wasn't sure for the long run how it would hold up.
Im stealing some stuff off my nb to nb put on my sct, the aluminum hinge pin braces, aluminum shock caps, delrin cartridges, etc... And noticed the pistons are different so I'm about to order the 6 hole, just curious why the 4x1.8 isn't good for the sct.
Old 10-17-2016, 01:01 PM   #4188
I run the 4x1.8 with Losi 50 in the front and 35 in the rear and have had great luck with them. I use to run the 6x1.5 and 6x1.6 Pistons but like the idea of fewer holes that are larger which should stay soft at lower speeds but pack up nice at higher speeds. Lately I have been running the 3x2.1 with PT 750 in the front and 700 in the rear in my SCT with really good success. I like how the truck rolls and jumps but still packs up. When running the 6x1.5 I was having problems with it being too stiff or too soft.
Riflebuilder is offline   Reply With Quote
Old 10-17-2016, 07:07 PM   #4189
I gave the 4x1.8 a try once and it was evident the oils I was using was too soft 550f/500r ptrc (rear end was donkey kicking and truck was bottoming on jump landings where it wasn't previously). I meant to revisit the 4x1.8 with stiffer oils, but haven't yet.
qstorm777 is offline   Reply With Quote
Old 10-18-2016, 12:28 AM   #4190
Thrifty's Avatar
The SL and the SCT are basically the same thing +- a few cosmetic parts. But the actual buggys are made different. More aluminum and tougher all around...
Thrifty is offline   Reply With Quote
Old 10-18-2016, 06:39 AM   #4191
Suspended
Yeah I've built both, and that's why I didn't understand why the SL would use a piston the SCT wouldn't? They are basically the same car..
4x1.8 Pistons
6x1.5 Pistons
All the pistons show the SCT, except the 4's, guessing it's just a mixup on the compatibility list then? Can't see why the 4 wouldn't be good for the SCT..
Old 10-18-2016, 10:59 AM   #4192
Thrifty's Avatar
Riflebuilder had some good info as to what and how they work for him.. might give the larger holes a try.
Although I have recently picked up a B6d.... my wrenching and experimenting will be split.
Old 10-18-2016, 12:12 PM   #4193
Suspended
Just now learning about pack and low/high speed with pistons.... So I'll try 6x1.5 coming from the stock 10s, and maybe try the 4x1.8 later.. crazy to see that 700 oil is too soft cause of the holes hah, so used to not gojng anywhere near that with stock pistons.
Old 10-18-2016, 06:57 PM   #4194
If I only had a 410.3, then I would typically have no business owning anything above 600 PT Oil for shocks, but since I have an ET48.3 and I just picked up a Mugen MBX7R Eco (5x1.3 pistons drilled out to 5x1.5 running 850 Front and rear) I have a bunch of heavy oil to play with. I will tell you, this shock package has been HOT!!!
3x2.1 front and rear
Green front , PT 750
Pink rear, PT 700
I just love how it packs up, but you can drop the truck from 10" and it just nicely lands with out slapping the chassis and it still feels a on the softer side on the bench. I ran Lutz's Enats set up with 6x1.5 pistons and PT 650 and it jumped and landed great, but for anything not high speed and smooth, it was just way too stiff.
I typically go lighter on my fluids until I can tell there is a problem like slapping down hard on flat landings, or the nose of the vehicle digging into the face of a jump, or bouncing up after a flat landing. Whatever system you try, be prepared to keep going heavier until you get it the way you like.
I have never used the black stock pistons, so i'm not sure what to tell you there, but i will say I just like the idea of fewer holes with larger diameter. It just makes sense to me for the majority of tracks out there on a club level.
Old 10-18-2016, 07:03 PM   #4195
Suspended
Nice, I still need to mess around with different pistons and oils... I have been messing around with too many cars to really work on one.. i got all of my Tekno's within 2-3 months, so I haven't tuned them for the track yet... My SCT is dialed currently, but my buggies setup's are AWFUL.. I'm going to try the 6x1.5 when they get here, and also my 4x1.8's eventually... glad to hear you are having success with the 3x2.1's
-Tekno SCT/EB-
Old 10-19-2016, 06:09 AM   #4196
Pink rear, PT 700
Thank bud. I'll have to give that a whirl.
On a side note, Rama signups open in 2 weeks...You ready?
The off-road Tekno 3some-> EB48.4 - ET48.3 - SCT410.3 ---Soon eb410
The oval 3some -> Tekno SCT410.3 - Tekno SCT210.3 - Blitz
Sponsors: Fiercercsolutions.com, AKA, jtbearingco.com, CowRC, Walden Designs, Leadfinger Racing, And BoomRC.net
ezlight is offline   Reply With Quote
Old 10-20-2016, 09:11 AM   #4197
Matt1970's Avatar
Any suggestions on a good 2s Lipo battery brand? I' ve been running SMC last 2 or 3 years, but bought a new one in Jan and one in March and both are "puffed" and neither are lasting 8 minute race now. Haven't changed gearing or anything. Motor comes off track at 115 degrees. Never had problems with them before in the 4 years I've been running short course. I also had an issue with one of my 4s SMC lipos for my 1/8th scale. Anyhow, suggestion on what brands to look at???
Mugen XB7R Eco Tekin RX8 Gen 2 / Tekin 2050kv
Tekno SCT410.3 Tekin RX8 Gen 2/ 4300HD/BCE Chassis
Future additions: Whatever I can get without my wife seeing it!!!
"When in doubt, FULL THROTTLE. It may not be the best solution, but it ends the suspense."
Matt1970 is offline   Reply With Quote
Old 10-20-2016, 09:16 AM   #4198
I've been running SMC in everything this season with no issues.
Old 10-21-2016, 05:27 AM   #4199
Matt1970's Avatar
I also have been for the last 3 years until now. Last year I had a 4s in my 1/8 scale that had a cell go bad prematurely and they replaced it. I now have a bad 2s after only a few months. I balance charge every time and watch my temps with gearing, etc. Their reply is that 4x4 short course is too hard on batteries and they will not replace it. My last batteries for the same vehicle lasted a couple years.
Old 10-21-2016, 06:45 AM   #4200
Suspended
As you can see from the recent posts I have been using SMC and love em, they have the new 2s out 7200/90c that are supposed to be good for the SCT and at $40 you can't beat it. I know a few other recommended ProMatch. I also had a 4s SMC go bad and they replaced it np, so far my 2s are good tho.
I'd check out the new SMC 7200/90 or SPC, ProMatch, or you could try GensAce
Tags
sct410, sct410.3, short course, short course 4x4, tekno
