    Hide Wikipost
Old 10-10-2017, 01:54 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC SCT410.3 Thread
Last edit by: DirkW
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8702 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree86Likes
Old 10-13-2016, 04:51 AM   #4171
Nanaotech and graphene may not be using the true technology, but they have worked well for me. I have four nanotech packs that I have been running for two seasons with no problems. Just another good option in my opinion. I love smc and I run their 4s packs in buggy, but I managed to crack the cases on the two 2s packs I had a while back, granted it was probably due to wrecks or not landing jumps as smoothly as I should. If it wasn't for the case cracking, I doubt that I would have ever looked at other lipos.
qstorm777 is offline   Reply With Quote
Old 10-13-2016, 12:14 PM   #4172
Josh L's Avatar
Yeah I am not knocking on the over all performance of the packs, just pointed out another marketing spoof. The day a real break through battery tech actually happens is the day everyone will notice all the pros had been running them about a month before the public knew about them.
As for the cases, the nicest one's I have seen have been on my protek packs. I don't know what the material difference is past a hydro dip pattern, but it seems to be the toughest and best looking cases on any pack so far.
Josh L is offline   Reply With Quote
Old 10-13-2016, 05:20 PM   #4173
Suspended
Btw I went with these. I think he just out them up! Ordered a few to try out.http://www.smc-racing.net/index.php?...ry&path=67_152
deceit is offline   Reply With Quote
Old 10-13-2016, 06:07 PM   #4174
hoyt1967's Avatar
Trader Rating: 35 (100%+)
Those look great, great price too.
hoyt1967 is offline   Reply With Quote
Old 10-13-2016, 11:10 PM   #4175
Wow, that's a great price on those 2S lipos!
Old 10-14-2016, 07:25 PM   #4176
Suspended
Of course I finally order new springs for my SCT, and then Tekno releases a new type the next day...
Low Freq Tekno Springs
-Tekno SCT/EB-
Old 10-14-2016, 08:29 PM   #4177
Matthew_Armeni's Avatar
Trader Rating: 31 (100%+)
Those are specifically for the EB/NB and will be too long to achieve proper ride height (most of the time) on the SC/SL.
Tekno RC
Matthew_Armeni is offline   Reply With Quote
Old 10-14-2016, 10:18 PM   #4178
Suspended
Good to know! Thank-you. I. Used to EB/NB stuff being pretty compatible. Still bummed cause I could of bought the new ones for my EB/NB and put the old onto the SCT. Not a big deal, just curious about new parts.[:
Old 10-15-2016, 12:57 AM   #4179
Anyone have a good starting recommendation for Pinion Gear, when running on 3s,
I have a Tekin Pro 4 HD 3000 Kv, RX 8
Malazan is offline   Reply With Quote
Old 10-15-2016, 02:47 AM   #4180
Josh L's Avatar
I would think you'd prolly want like a 15-16T based off of KV per volt
I run 2S 4700KV with a 15T
4700KV @ 7.4v = 34,780 RPM
You'd be getting>
3000KV @ 11.1 = 33,300 RPM
Old 10-15-2016, 08:34 PM   #4181
Suspended
Which pistons are most common on the SCT? the 6 hole? 8? My buggies use 4 hole, and I just noticed the stock SCT is 10...
Thinking about ordering some new pistons, just not sure which to go with...
-Tekno SCT/EB-
Old 10-15-2016, 08:57 PM   #4182
Suspended
The 2 SMC's I ordered came in today, they look amazing! Cells were matched, and they are all charged up and ready for the track tomorrow. Will see how they do!
7200 90c 2s
and a new
6700(7200) 90c 4s (for my EB)
Can't wait to try these bad boys out!
-Tekno SCT/EB-
Old 10-15-2016, 09:58 PM   #4183
I just tried that tonight with a 17t. No problems. External motor temp around 140. Esc around 100. I wasn't using a tekin esc so I can't actually review any data.
Old 10-15-2016, 10:00 PM   #4184
6x1.5 seems to be pretty common.
Old 10-15-2016, 11:07 PM   #4185
I was thinking 17-19
Hell, I thought about trying a 20t
Tags
sct410, sct410.3, short course, short course 4x4, tekno
