    Hide Wikipost
Old 10-10-2017, 01:54 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC SCT410.3 Thread
Last edit by: DirkW
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8702 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree87Likes
Old 10-10-2016, 06:04 PM   #4141
Suspended
Originally Posted by Cain View Post
I used the VANT 100C 8000mah in the heavier durango desc10, they worked excellent. With that truck sold, go no need for em as the cars I have now are all shortie style setups.
Would you say that 100c is worth it over 70c? It's worth the money difference?
deceit is offline   Reply With Quote
Old 10-10-2016, 06:19 PM   #4142
jason07's Avatar
I'm a Hitec servo guy. Is the 7954 a good servo option? It has 403 oz of torque while using 7.4v
https://www.amainhobbies.com/hitec-h...37954s/p140824
Agama A215E Hobbywing 1900KV and Xerun XR8
Agama A215 Bullitt B221
jason07 is offline   Reply With Quote
Old 10-10-2016, 07:03 PM   #4143
suzukipro's Avatar
Trader Rating: 23 (100%+)
Eric
________________________________________________________________________
Tekno, XRAY, Team Associated & Traxxas Powered by SMC.
Innovative Hobbies Raceway, Flyin-High RC Track
suzukipro is offline   Reply With Quote
Old 10-10-2016, 07:55 PM   #4144
jason07's Avatar
Originally Posted by suzukipro View Post
thanks!
Old 10-11-2016, 12:10 PM   #4145
Suspended
I'm torn on which batteries to buy.. ]:
-Tekno SCT/EB-
Old 10-11-2016, 12:22 PM   #4146
Thrifty's Avatar
I'm using SPC racing 2s 7200 70c in my SL and have had zero issues ... barely get warm..
Thrifty is offline   Reply With Quote
Old 10-11-2016, 12:33 PM   #4147
Suspended
http://spcracingbatteries.com/ ??? The site doesn't load, do you order from somewhere else?
-Tekno SCT/EB-
Old 10-11-2016, 12:53 PM   #4148
Tech Legend
Cain's Avatar
Trader Rating: 239 (100%+)
personally at these various C levels for the batteries you mentioned, I haven't heard of too much issues.
The big thing though is Capacity. You want that capacity so you are not running the batteries all the way down trying to squeeze every bit out of them. this of course relative to C Rating but for what you listed, that would be more my concern.
< HB Racing D413 | Tekno EB48SL / SCT410.3 | Tekno EB410 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 10-11-2016, 01:04 PM   #4149
Personally, I've run SMC 7200's for 2 season now with no drop off.
The off-road Tekno 3some-> EB48.4 - ET48.3 - SCT410.3 ---Soon eb410
The oval 3some -> Tekno SCT410.3 - Tekno SCT210.3 - Blitz
Sponsors: Fiercercsolutions.com, AKA, jtbearingco.com, CowRC, Walden Designs, Leadfinger Racing, And BoomRC.net
ezlight is offline   Reply With Quote
Old 10-11-2016, 01:06 PM   #4150
Suspended
the SMC 7200 60c?
-Tekno SCT/EB-
Old 10-11-2016, 01:20 PM   #4151
the SMC 7200 60c?
Yup
http://www.smc-racing.net/index.php?...product_id=248
Old 10-11-2016, 01:37 PM   #4152
Suspended
I have a warranty on my 4s, so I will probably order a SMC better now. I am between the one you listed (7200mah 60c $38) and (6000mah 100c $50), would get 2 of either for now... I imagine 6000mah 100c should still enough runtime.
-Tekno SCT/EB-
Old 10-11-2016, 01:48 PM   #4153
hoyt1967's Avatar
Trader Rating: 35 (100%+)
I have 4 of the 7200 SMC's, they are a great battery for the money. I would also recemmond these, lots of punch, great racing battery
http://www.smc-racing.net/index.php?...product_id=341
hoyt1967 is offline   Reply With Quote
Old 10-11-2016, 01:49 PM   #4154
Suspended
Nice, I am actually ordering 2 of those now! the 6000mah 100c, can't wait to test them out!!!
Thank you for the responses!
-Tekno SCT/EB-
Old 10-11-2016, 01:52 PM   #4155
How do they compare to the normal 7200?
Tags
sct410, sct410.3, short course, short course 4x4, tekno
