    Hide Wikipost
Old 10-10-2017, 01:54 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC SCT410.3 Thread
Last edit by: DirkW
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8702 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree86Likes
Old 08-01-2016, 08:31 AM   #3946
Need some advice. I have a somewhat hopped up Tekno Sct410. I am looking for a new hobbywing esc. I run a HW 4700 motor. We race with 2s. I use a 7200 mah amp battery....SMC....What is the best HW esc for this truck and my situation? The tracks that I race on are medium and large outdoor orange clay. I have a HW sct pro now, but it is showing its age....
SouthFloridaApp is offline   Reply With Quote
Old 08-02-2016, 09:22 AM   #3947
sapperc's Avatar
Originally Posted by SouthFloridaApp View Post
Need some advice. I have a somewhat hopped up Tekno Sct410. I am looking for a new hobbywing esc. I run a HW 4700 motor. We race with 2s. I use a 7200 mah amp battery....SMC....What is the best HW esc for this truck and my situation? The tracks that I race on are medium and large outdoor orange clay. I d a HW sct pro now, but it is showing its age....
Actually that is a very good ESC especially with that motor. Not sure what you mean by "showing its age?" If it is malfunctioning look for wiring problems before you give up on it. Also check your batteries for any issues. If the ESC is bad, replace. The HW SCT PRO is still a good value and has all the features your motor needs. If you want an upgrade consider the HW XR10 Pro. Pricey and probably overkill, but you're unlikely to out grow it. Good luck!
sapperc is offline   Reply With Quote
Old 08-02-2016, 11:22 AM   #3948
Suspended
Planning on getting a a second motor and esc for my second truck. Main is RX8 and Pro4 HD4300, so I was looking at the HW combos and most are $139, but what kV and can size should I go for? Going to be 2s
deceit is offline   Reply With Quote
Old 08-02-2016, 11:26 AM   #3949
If your stuck on HW, get the 4700kv. I believe they changed from solder posts on the motor, to Tabs. I hated the posts myself.
I just got the SMC 4500kv, haven't tried it yet, but have heard good things.
The off-road Tekno 3some-> EB48.4 - ET48.3 - SCT410.3 ---Soon eb410
The oval 3some -> Tekno SCT410.3 - Tekno SCT210.3 - Blitz
Sponsors: Fiercercsolutions.com, AKA, jtbearingco.com, CowRC, Walden Designs, Leadfinger Racing, And BoomRC.net
ezlight is offline   Reply With Quote
Old 08-02-2016, 03:41 PM   #3950
King DORK's Avatar
Trader Rating: 31 (100%+)
I'm not saying that it is or isn't, since I don't know for certain, but I'd make sure the XR10 Pro is compatible with 4-pole sc motors.
B5M Lite, Centro CT4.2, Tekno SCT410.3, Losi 22-4 (RC Shox-ified), Losi Comp Crawler, Losi MRC Pro Gatekeeper, Super Clodbuster
Proud father of my boys Kevin, Brandon, Dylan, and my dogs Kaelee, Bella Roo, and Wilbur. Thank you to my only sponsor, my beautiful wife!
King DORK is offline   Reply With Quote
Old 08-02-2016, 04:23 PM   #3951
Suspended
I'm not stuck on HW, I never thought I'd buy one, but I don't want to spend as much as I would getting a second set of what I have... Just want a decent setup for my second truck, without spending a ton.
Old 08-03-2016, 04:08 AM   #3952
It is, i'm using the XR10 Plus on a LRP Dynamic 10L 4700kv and still have room for more. XR10 works really good and it has the 7.4v output for high voltage servos.
adriaav is offline   Reply With Quote
Old 08-03-2016, 04:15 AM   #3953
When I say that there's still room for more, i'm mean amp draw... not place for a longer/bigger motor case.
Old 08-03-2016, 07:38 PM   #3954
King DORK's Avatar
Not in any way trying to start an argument, but in your pic it appears (to me) to be an XR8 Plus, not an XR10 Pro. Of course the XR8 Plus is designed around 4-pole motors. Just not sure if the XR10 Pro is compatible with them.
Old 08-03-2016, 07:39 PM   #3955
King DORK's Avatar
By the way. How do you like that LRP motor? I was so close to getting one.
Old 08-03-2016, 10:07 PM   #3956
Trader Rating: 25 (100%+)
One of the interviews that Jason Ruona did with Ron shurr, He said they would handle a 4 pole. I believe it was the new software. And almost like they made sure that you could use it for 4x4...
LRP America
My RC Depot - myrcdepot.com
tfrankito is offline   Reply With Quote
Old 08-03-2016, 10:09 PM   #3957
That LRP 4700 10L is a beast. I run one but have it geared and lowered on my esc or everything runs hot LOL. Even with it turned down to 85% geared with a 16 came off at 180 esc 120 and was pulling on the straight.
LRP America
Old 08-03-2016, 10:37 PM   #3958
Trader Rating: 32 (100%+)
[QUOTE=tfrankito;14623747]That LRP 4700 10L is a beast. I run one but have it geared and lowered on my esc or everything runs hot LOL. Even with it turned down to 85% geared with a 16 came off at 180 esc 120 and was pulling on the straight.[/QUOTE
Lower your pinion gear to 14 i'm running my tekno paired with orion r10.1 it's beast motor compare to HW4700KV. I don't know why they discontinue this motor glad i got one in towerhobbies before thery discontinue
raved007 is offline   Reply With Quote
Old 08-05-2016, 04:17 PM   #3959
mxrcracer23's Avatar
What would be a good starting point for a pinion gear on a Hobbywing 4700 on a large 1/8 scale track?
mxrcracer23 is offline   Reply With Quote
Old 08-05-2016, 05:52 PM   #3960
Kremzeek's Avatar
I run a 15T and should probably go down to 14T
Kremzeek is offline   Reply With Quote
Tags
sct410, sct410.3, short course, short course 4x4, tekno
