    Hide Wikipost
Old 10-10-2017, 01:54 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC SCT410.3 Thread
Last edit by: DirkW
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8702 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree87Likes
Old 06-11-2016, 06:23 AM   #3796
Originally Posted by Kremzeek View Post
I'm in the process of putting my truck back together and noticed that there is a bit of play in the center driveshaft. Has anyone tried putting o-rings in the outdrives to reduce this a bit?
When we had tekno shafts in our Traxxas slash's the shafts came with o'rings for exactly what your saying. Were still noisy as heck ..
SerpJimmy is offline   Reply With Quote
Old 06-11-2016, 06:26 AM   #3797
Is there any up grade for more of a automotive style universal joint. This pin and a slot design really blows..
Old 06-11-2016, 08:49 AM   #3798
Kremzeek's Avatar
Originally Posted by mkl View Post
Do you mean fore/aft play? If so there should be some allowance for movement to allow for chassis flex. When running it doesn't really make any noise
Yep, that's what I meant.
Kremzeek is offline   Reply With Quote
Old 06-11-2016, 01:40 PM   #3799
What's wrong with the pin and slot design?
4s losi is offline   Reply With Quote
Old 06-11-2016, 04:09 PM   #3800
Ton of slop , friction , noise , Wear .. Other then that they work terrific..
Old 06-11-2016, 06:05 PM   #3801
I ran mine for over a year before they wore out. But I also serviced them regularly.
Old 06-11-2016, 06:11 PM   #3802
mkl
as you can see from the plethora options for pin and slot alternatives, scaling down anything from the 1:1 world is not easy, simple, lighter, stronger, cheaper, or better.
I have seen some CV joints that use ball bearings, but there were some negatives to them. Weight, and the need for suspension travel are all barriers.
MIP make their CVD kits, but they are tanks needed to be strong enough. They use a sliding shaft to account for suspension travel.
Tekno SCT410, Tekno EB48, Tekno ET48, X-Ray 808E, TRCE Slash 4x4, Tamiya Lunchbox, Tamiya Frog, Slash 4x4, Axial Wraith
mkl is offline   Reply With Quote
Old 06-11-2016, 06:50 PM   #3803
mxrcracer23's Avatar
No oring under shock collar (preload adjuster)? Just want to make sure
mxrcracer23 is offline   Reply With Quote
Old 06-11-2016, 07:08 PM   #3804
mkl
If I understand you correctly, yes, you want the o-ring in the inside groove of the pre-load adjuster. It will give it just enough friction to keep the adjuster fro moving unintentionally.
Old 06-11-2016, 07:14 PM   #3805
Didn't see a groove on the stock plastic adjusters and don't have a o-ring, that was my concern, that the adjusters would be free to move without it
Old 06-11-2016, 08:02 PM   #3806
The plastic ones have enough resistance that they are not needed.
crash n go is offline   Reply With Quote
Old 06-11-2016, 08:11 PM   #3807
Ok, thanks!
Old 06-11-2016, 08:42 PM   #3808
Josh L's Avatar
Originally Posted by DirkW View Post
In stock classes people try to heat up their lipos by doing a 40A discharge/charge cycle to actually lower the IR and get more punch. Kind of opposite of what you're saying there, isn't it?
No, my statements aren't opposite, just not defined in regards to what they are doing and or why.
I never stated you want a cold battery, but you dang sure don't want a hot one either.
They are essentially just warming their packs up to get the chemistry to release electrons more efficiently due to thermal expansion.
But... There is a threshold for which is optimum over a run. Being to cold as well as to warm will exponentially decrease your performance.
Additional caps them selves are important to further normalize the voltage and amperage output to prevent crossing said threshold.
Trust me when I tell you a cap pack WILL make your setup better!
Josh L is offline   Reply With Quote
Old 06-11-2016, 09:03 PM   #3809
ryan432greening's Avatar
What the heck is a cap pack?
B-Main Racing
TLR 22 4.0, TLR 22 3.0, 22-4 2.0, 8ight-E 4.0
ryan432greening is offline   Reply With Quote
Old 06-11-2016, 10:37 PM   #3810
Jordan Anderson's Avatar
Yes, I put an o-ring in the outdrives. There's still plenty of play to accomadate chassis flex.
JORDAN // EVAN
R/C GEARS , TRUKZ/KARZ , VRC PRO
Jordan Anderson is offline   Reply With Quote
Tags
sct410, sct410.3, short course, short course 4x4, tekno
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
