    Hide Wikipost
Old 10-10-2017, 01:54 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC SCT410.3 Thread
Last edit by: DirkW
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8702 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree83Likes
Old 05-22-2016, 12:02 PM   #3661
Josh L's Avatar
Originally Posted by lowspark View Post
As a follow up to my question about shock springs from last week.
I was actually asking about using an alternate manufacturer to match the the pink Tekno springs but allow a lower ride ht.
I found some old Losi red springs (5450 & 5456) and gave them a try. I was able to get the ride height down to 24 but they were too stiff.
Next I tried a set of yellow HB front springs. They are 2mm shorter and the rating was 3.81 vs 3.83 (front pink). I was able to get the ride ht down to 25 and my truck ran great. Driver error allowed for, but I ran a very fast main, the truck felt great.
$30 on springs this week LOL
Question... how do you compare manuf-A spring rating from manuf-B spring rating?? I doubt they use the same testing equipment??
I doubt you would ever know without having a spring rate tester handy
Spring rate tester
Josh L is offline   Reply With Quote
Old 05-22-2016, 06:08 PM   #3662
3 out of the 5 times I've had my truck to the track, I've had one side pop out of the front bumper ( the very bottom where it meets the chassis) Is this common ?
weedsnager is offline   Reply With Quote
Old 05-22-2016, 06:47 PM   #3663
Trader Rating: 19 (100%+)
Mine pops off the chassis all the time too. Was just thinking about going back to the first Gen bumper if I can
kyleman7 is offline   Reply With Quote
Old 05-22-2016, 07:07 PM   #3664
Lowe's48's Avatar
If you can find them...please me know!
I don't think Tekno make the gen1 front bumper anymore. Anyone ??
Tekno Sct410.3-VRP,HW120 SCT-PRO,Pro4-4300kv,Hitec,LRP 8000/2s
Tekno SL.3-VRP,HW120 SCT-PRO,T8i-1950,Hitec,LRP 5000 4s
Weapon of choice : Airtronics M12
Home track : Coyote Hobbies,Ca
Lowe's48 is offline   Reply With Quote
Old 05-23-2016, 06:43 AM   #3665
Put a piece of battery foam in between the round section of the bumper problem solved.
Scottysspeedsho is offline   Reply With Quote
Old 05-23-2016, 07:53 AM   #3666
Do you glue the foam ?
Old 05-23-2016, 01:34 PM   #3667
JoeRC123's Avatar
Post a pic.
JoeRC123 is offline   Reply With Quote
Old 05-23-2016, 04:32 PM   #3668
Trader Rating: 25 (100%+)
On the old truck I ran green all around with the 8x1.3. With the new truck I have been experimenting a little. Ran green all around with the 6x1.5. This past weekend tried yellow all around and it felt great. This was on a low bite hard packed indoor track. Going to try same setup outdoor on medium bigger jumps. I didn't have any nose dive problems and truck felt planted all around. I didn't loose any steering, that I noticed. Running the Jeremy McGuinen set up from willow farms.
LRP America
My RC Depot - myrcdepot.com
tfrankito is offline   Reply With Quote
Old 05-23-2016, 06:28 PM   #3669
What ride height are ya getting with Green or Yellow? And weight of fluid , front and rear?
SerpJimmy is offline   Reply With Quote
Old 05-23-2016, 10:33 PM   #3670
HaulinBass's Avatar
can anyone help me with setup on the old truck, im running stock settings but with a few changes, rear:shocks leaned in to innermost hole on tower, 8x1.3 kyosho white pistons, 32.5wt ae oil and black rc8b rear springs.
front has:rc8b silver springs, 45wt oil.
the truck handles fairly well on our rough 1/8th track but i have to roll any of the higher speed jumps or else its front flipping and bending rear towers. im not really into the electric thing so im just using a traxxas 7200 7.4 pack i had to cut the batt box to fit as its so large(it sits against the brake servo mount in rear).
id really like to run the truck but tonight i got so frustrated with it i pulled it off the track halfway through the main.
anyone have a decent setup sheet for a rough 1/8th track with highspeed/large jumps
Tyler MacKenzie
Relax, Have fun
SOAR Racing USA/Dialed RC Hobbies
HaulinBass is online now   Reply With Quote
Old 05-24-2016, 04:25 AM   #3671
Josh L's Avatar
Originally Posted by JoeRC123 View Post
Post a pic.
Here is a pic I took of my SCTE with the foam in the flex oval to better show you what they are talking about. Granted the foam in the pic is XPS (house insulation type) which is purely for demonstration purposes. Wouldn't last two seconds on a track!
And no glue is necessary if you use the right kind of foam. It's not going to go anywhere if you cut it thick enough that it expands over the top and bottom of the hoop.
Your best bet is to get some EVA foam and cut it to size. You can find this stuff in abundance anywhere you can buy interlocking mats, like these>
Old 05-24-2016, 06:08 AM   #3672
I'm at 450 and 425. Ride height....with the green I was able to get down to 22. But I also took some droop out.
LRP America
Old 05-24-2016, 06:11 AM   #3673
Good info, thanks for the pictures
Old 05-24-2016, 06:27 AM   #3674
With those springs I wasnt able to get ride height down that low.. Unless I brought shocks all the way out . Shocks all the way out werent working on tracks with alot of jumps..
Indoor ,high bite, alot of jumps , Fairly smooth: I started with yellow , then to green. These were to high and bouncing around to much. So now using pink. Going to try blk next. But as of now IMO anything heavier then say pink is maybe more for a heavier 1/8 set up. Things might be totally different outdoors ...
Old 05-24-2016, 07:10 AM   #3675
Post a pic.
Tags
sct410, sct410.3, short course, short course 4x4, tekno
Currently Active Users Viewing This Thread: 4 (3 members and 1 guests)
Backyard RC, HeavyD99, tsair
