    Hide Wikipost
Old 10-10-2017, 01:54 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC SCT410.3 Thread
Last edit by: DirkW
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8702 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree83Likes
Old 04-16-2015, 06:25 AM   #346
Trader Rating: 19 (100%+)
Originally Posted by lyork View Post
Tower Hobbies is now saying "mid-may". On 4/15 it was "late April"
Sounds like it'll be several more weeks before there is decent stock.
I saw that too. I wonder if the stock status is estimated based on current order numbers. For example if there were no back orders it would be in stock next week, but with all back orders its next month.
who knows.
TEKNO SCT410.3; Hobbywing Sct-pro; Hobbywing 3656 4000kv; Protek 130S; SPC 70C 7200mAh 2s
TEKNO EB48.3; Hobbywing Xerun 150a; SMC 1900kv; Savox 2274SG; ECO Power 35c 4100mAh 4s
Associated B5R; Trackstar 120a turbo; Trackstar 8.5t; Solar D771; Reedy 65C 5800mAh 2s square
kyleman7 is offline   Reply With Quote
Old 04-16-2015, 06:42 AM   #347
I was reading over the manual and saw that it says in the "needed to complete" section: MOD1 Pinion (TKR4171 ->TKR4190). That is a huge span!
I have a 3300 kv Pro 4 motor. Any recommendations for a good starting point on pinion selection?
never mind I found it on page one. I was searching for pinion...didn't think to try gearing
jjl1 is offline   Reply With Quote
Old 04-16-2015, 06:46 AM   #348
Tech Legend
Cain's Avatar
Trader Rating: 235 (100%+)
maybe someone can contact Tower or Tekno (not sure if they would give the info out though) about how many vehicles Tower actually was sent.
Heck this may kind of a good thing for Tekno, big demand and all, just hope they can fill orders lol.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL | Yokomo YZ-2 DTM x 2>
Old 04-16-2015, 07:23 AM   #349
Trader Rating: 18 (100%+)
i was thinking the same thing on what pinion to use. I'm somewhat of a newbie looking to build this truck. i have a Tekin SC4X 4.5T 550 motor.
rcnewbie418 is offline   Reply With Quote
Old 04-16-2015, 07:32 AM   #350
No experience with that particular setup, but the range is to cover the different pinions available. If you look at their page, they do offer a 3 pack of mod1's, I'd start there.
The off-road Tekno 3some-> EB48.4 - ET48.3 - SCT410.3 ---Soon eb410
The oval 3some -> Tekno SCT410.3 - Tekno SCT210.3 - Blitz
Sponsors: Fiercercsolutions.com, AKA, jtbearingco.com, CowRC, Walden Designs, Leadfinger Racing, And BoomRC.net
ezlight is offline   Reply With Quote
Old 04-16-2015, 07:33 AM   #351
I think people usually run between 15t - 18t pinions depending on motor and track size. I was running a 16t on my gen1 with a tenshock sc411 4600kv
Old 04-16-2015, 07:48 AM   #352
Orion_2kTC's Avatar
I canceled my order and bought one from PowerHobby's Ebay store. Sure it's an extra $20 but it's arriving next Thursday.
Orion_2kTC is offline   Reply With Quote
Old 04-16-2015, 07:59 AM   #353
Jakesterama's Avatar
Trader Rating: 66 (100%+)
Mine is on my porch!!!!! Now to fake an illness and get home.....
if (racing_skill<AWESOME){
practice_lap++;
Jakesterama is offline   Reply With Quote
Old 04-16-2015, 08:00 AM   #354
I'll go pick it up for you
Old 04-16-2015, 08:02 AM   #355
My address is 123 Fake Street, Springfield :P :P :P
practice_lap++;
Old 04-16-2015, 11:03 AM   #356
Jordan Anderson's Avatar
The one piece composite diff cross pins don't seem too bad.
They were ever so slightly tight in the gears and so there was a very slight drag/resistance when turning the gear on the pin. Once submerged in oil and run for a bit they'd likely be fine.
I went with the aluminum cross pins (TKR5149A) which are still very light and had perfect tolerances.
JORDAN // EVAN
R/C GEARS , TRUKZ/KARZ , VRC PRO
Jordan Anderson is offline   Reply With Quote
Old 04-16-2015, 11:12 AM   #357
Orion_2kTC's Avatar
While I'm sure the boys at Tekno have tested and tested the composite pins I went with the ALU pins. Perhaps the thought of plastic pins in a diff environment makes me uneasy.
Old 04-16-2015, 11:21 AM   #358
Tech Legend
Cain's Avatar
whats the weight diff between aluminum and plastic cross pins?
Old 04-16-2015, 11:56 AM   #359
I had no intention of using the plastic cross pins, so I didn't bother checking the weight difference with a scale. The aluminum pins felt very light.
JORDAN // EVAN
Old 04-16-2015, 12:00 PM   #360
Tech Legend
Cain's Avatar
be curious tekno's stance if a plastic cross pin fails if they will replace the diff gears. game to try them, but also skeptical too.
Tags
sct410, sct410.3, short course, short course 4x4, tekno
