    Hide Wikipost
Old 10-10-2017, 01:54 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC SCT410.3 Thread
Last edit by: DirkW
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8702 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree83Likes
Old 05-03-2016, 04:38 PM   #3556
justpoet's Avatar
Trader Rating: 16 (100%+)
Originally Posted by SerpJimmy View Post
Yep, watched that .. Sweet vid , SIR.
Also, rather then adhering one slab of 2 face tape/zeal to entire bot of esc. Im using a 1/2' piece in each corner to further reduce trauma..
I would always cover the entire bottom of the ESC with your adhesive of choice. I just use the 3m outdoor mounting tape, but I run 2 strips of it so I fully cover the bottom of the ESC and get it really good and solidly stuck to the plate. Nothing EVER is going to knock that ESC off the plate (I actually saw somebody I did this for break a screw in the plate on a crash and the ESC was still stuck on and fine). The key is to make sure it is clean and FULLY covered. Openings invite dirt to creep in on the edges and reduce adhesion.
"We do not act rightly because we have virtue or excellence, but we rather have those because we have acted rightly. We are what we repeatedly do. Excellence, then, is not an act but a habit." -Aristotle
My wallet supports: TeknoRC.com, NorCalHobbies.com, SMC, Tekin, and several tire/servo companies.
justpoet is offline   Reply With Quote
Old 05-03-2016, 06:15 PM   #3557
Hey, looking for some opinions on punching holes in tires in addition to rims.. What do ya think?
SerpJimmy is offline   Reply With Quote
Old 05-03-2016, 07:05 PM   #3558
justpoet's Avatar
Generally the tire is better for this than the rim. On the rim when dirt gets in, the foam just gets eaten up over time as the dirt is spun into it. On the tire, most of it gets flung back out.
Old 05-03-2016, 07:23 PM   #3559
I prefer do punch the wheel so when I clean the tires I don't get water in them. I've never had an issue with dirt getting in the foam
4s losi is offline   Reply With Quote
Old 05-03-2016, 07:50 PM   #3560
Lowe's48's Avatar
My theorys are if I run indoor clay(wet) no dust situation I will drilled the wheels but for outdoor loamy,dusty condition then I punch the tires.
Or if you wash tires often over the course of the day then drill the wheels so you don't get the foam wet and ruin them.
Tekno Sct410.3-VRP,HW120 SCT-PRO,Pro4-4300kv,Hitec,LRP 8000/2s
Tekno SL.3-VRP,HW120 SCT-PRO,T8i-1950,Hitec,LRP 5000 4s
Weapon of choice : Airtronics M12
Home track : Coyote Hobbies,Ca
Lowe's48 is offline   Reply With Quote
Old 05-04-2016, 04:06 AM   #3561
Gotcha tks bro , Im kinda skeptical about punching holes in spanking new tires gotta say .These Jconcept rims already have holes. Need more holes, that would be 4 holes total. What size hole are we looking at? Also , Im setting up to run primes, Webs & Pressure points For high bite indoor & outdoor clay . These all need holes ?
Old 05-04-2016, 05:13 AM   #3562
Outdoor Racing and Tire washing the Tire Punch is the way to go. Holes in wheels is what lets water and dirt in the foam.
Whosold is offline   Reply With Quote
Old 05-04-2016, 07:34 AM   #3563
Lowe's48's Avatar
I would recommend you to run AKA black foam up front with the Primes and run the stock blue in the rear for indoor high bite track.
Old 05-04-2016, 08:10 AM   #3564
Roger..
Old 05-04-2016, 08:15 AM   #3565
rregl0612's Avatar
Trader Rating: 33 (100%+)
My take on these two options:
Wholes in the wheel trap dirt and water in.
While the whole in the center if tire allows it to escape when the tire expands. I've had better luck with the later
rregl0612 is offline   Reply With Quote
Old 05-04-2016, 09:17 AM   #3566
so , seal up rim vent? HMMMm..
Old 05-04-2016, 03:00 PM   #3567
Lowe's48's Avatar
Ok Jimmy. I'll make this easy for ya....indoor=drill wheels, outdoor=punch tires 😉
Old 05-04-2016, 04:11 PM   #3568
Evidently you don't wash your tires when you run indoors.:
Old 05-04-2016, 04:23 PM   #3569
HAHAHA.. You guyz,,, Yep keep it simple stupid , def works...
Old 05-04-2016, 04:35 PM   #3570
Lowe's48's Avatar
lol yes we wash tires often....I don't know how you guys wash them but we use wet brushes and inside of the wheels never get wet.
Tags
sct410, sct410.3, short course, short course 4x4, tekno
