    Hide Wikipost
Old 10-10-2017, 01:54 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC SCT410.3 Thread
Last edit by: DirkW
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8702 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree83Likes
Old 05-01-2016, 05:00 PM   #3541
The route I took was to find a pro's setup from the tekno site that kinda matched the tracks around here & order Mods based on that.
SerpJimmy is offline   Reply With Quote
Old 05-01-2016, 05:15 PM   #3542
celt's Avatar
Originally Posted by twistedneck View Post
Aluminum A block and servo horn.
Very true...completely forgot about the alu servo horn.
I really like the newer version (two hole). It has a larger 3mm cap screw rather than 2mm - a pinch more robust and a good safe upgrade.
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Old 05-03-2016, 04:18 AM   #3543
rx8 gen II mount:
Im getting to the point where this ESC needs to be fastened . Builds been going on for almost 2 months now, HAHAHaa. Anyway , I picked up some kyosho Z006 Absorption 2x sided Tape . In addition to tape , how is everyone else fastening there ESC? zip ? screw through bottom ? Trust tape only?
Old 05-03-2016, 04:32 AM   #3544
You could never make a living building rc's lol
I use regular Parma servo tape and never had an issue. Clean the mount and esc with simple green first and then make its dry. It will stay put
Dragonfueled is offline   Reply With Quote
Old 05-03-2016, 04:39 AM   #3545
mkl
I use the Zeal tape as well. I clean the surfaces with alcohol so there is no residue. Some will use a zip tie loosely as a back up. But I have had good luck with the tape alone.
Tekno SCT410, Tekno EB48, Tekno ET48, X-Ray 808E, TRCE Slash 4x4, Tamiya Lunchbox, Tamiya Frog, Slash 4x4, Axial Wraith
mkl is offline   Reply With Quote
Old 05-03-2016, 04:43 AM   #3546
Gotchaa.. I see theres some holes bored in the bottom of RX8 though. Im thinking there trying to tell me something
Old 05-03-2016, 04:46 AM   #3547
My huge Novak Activ8 V2 had to be shoe goo'd on. it has not moved since! I ripped off the ESC side side rail so looks like I have a big problem coming to replace that rail and remove the goo!
anyone know how to remove it?
twistedneck is offline   Reply With Quote
Old 05-03-2016, 04:47 AM   #3548
I know it ! I get carried away making sure everything is spot on perfect. Just cant figure how guys do builds claiming 12 hours ?? Along with I need to order every damn new tool along the way..
Old 05-03-2016, 11:12 AM   #3549
Build ?
Page 15 /step J2
Part TKR 1529 /Cap head screw with washers as shown.
Upon trial mount of a J concepts Rim Part # 3352B Hazard /Losi SCT-e .
I noticed Cap screw scraping inside of rim . Anyone else get this?
Old 05-03-2016, 11:28 AM   #3550
Replace it with the same size button head. Did the trick for me and a few of my friends.
Originally Posted by SerpJimmy View Post
Build ?
Page 15 /step J2
shanondink is offline   Reply With Quote
Old 05-03-2016, 11:36 AM   #3551
Same thing happened to me.. I had to file down the cap screws to gain clearance.
Old 05-03-2016, 11:38 AM   #3552
You guys are the best of the best...Nice idea..
Old 05-03-2016, 11:41 AM   #3553
justpoet's Avatar
Trader Rating: 16 (100%+)
Build ?
Page 15 /step J2
As mentioned, replace with button head screw. If you're not using all of the washers (if they're under the screw head vs under the link), then you can also use a shorter screw. I typically do both.
"We do not act rightly because we have virtue or excellence, but we rather have those because we have acted rightly. We are what we repeatedly do. Excellence, then, is not an act but a habit." -Aristotle
My wallet supports: TeknoRC.com, NorCalHobbies.com, SMC, Tekin, and several tire/servo companies.
justpoet is offline   Reply With Quote
Old 05-03-2016, 11:44 AM   #3554
justpoet's Avatar
This is from my truggy build, but the concepts are the same. Fast forward to the ESC tray portion (about 8:15). This will make life much better for your ESC, and the tape holding it.
https://www.youtube.com/watch?v=rGsYCB5UHyI
Old 05-03-2016, 12:06 PM   #3555
Yep, watched that .. Sweet vid , SIR.
Also, rather then adhering one slab of 2 face tape/zeal to entire bot of esc. Im using a 1/2' piece in each corner to further reduce trauma..
Tags
sct410, sct410.3, short course, short course 4x4, tekno
