    Hide Wikipost
Old 10-10-2017, 01:54 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC SCT410.3 Thread
Last edit by: DirkW
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8702 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree86Likes
Old 05-01-2016, 11:33 AM   #3526
Lowe's48's Avatar
Originally Posted by celt View Post
Finally!!
Someone who gets it and put it into words. The slight weight forward bias of the Tekno is THE reason I run their kits - if they where to change that, it would ruin this chassis.
The last thing you want in a 4WD chassis is to heel and toe over jumps. Nothing wrong with Tekno's weight bias.
Can you please share the electronics combo you are running with your car on the scale? So I can understand what I'm doing wrong with my car. Because it shows on my scale that my right side is way heavier than my left,numbers just don't lie. To me the left to right unbalance is unacceptable !!
Thx.
Tekno Sct410.3-VRP,HW120 SCT-PRO,Pro4-4300kv,Hitec,LRP 8000/2s
Tekno SL.3-VRP,HW120 SCT-PRO,T8i-1950,Hitec,LRP 5000 4s
Weapon of choice : Airtronics M12
Home track : Coyote Hobbies,Ca
Lowe's48 is offline   Reply With Quote
Old 05-01-2016, 11:47 AM   #3527
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
Originally Posted by Lowe's48 View Post
Hey Jimmy
I'm more concern about left to right bias more than front to rear bias. Front/rear can be tailor to your liking by shocks/springs/oil package but side to side isn't.
Everyone can quit the bickering now. He states straight out that his main focus was on side to side weight balance as opposed to front to rear. No one was commanded to follow what he was doing. I found the same side to side bias as well and I plan on doing something about it. I could have just as easily ignored it and not argued with everyone about something this senseless.
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 05-01-2016, 12:04 PM   #3528
Matthew_Armeni's Avatar
Trader Rating: 31 (100%+)
On the right - RX8 (76 grams) and a Pro4 4600 (193 grams), most servos are about 60 grams and most receivers are about 10 grams. All of that together is ~335-345 grams. Most of the big batteries, 7000-8000 mah weigh about 320-340 grams.
Tekno RC
Matthew_Armeni is offline   Reply With Quote
Old 05-01-2016, 12:35 PM   #3529
Lowe's48's Avatar
Finally
someone understand what I was saying
Old 05-01-2016, 12:38 PM   #3530
Lowe's48's Avatar
Yup,I knew it was that Pro4 4300 motor!!
But i love that low end torque so much though.....
Old 05-01-2016, 12:47 PM   #3531
justpoet's Avatar
Trader Rating: 16 (100%+)
Thanks Matt for making it official with what was used so people can have some idea of where they stand with their chosen electronics.
Many people now have AL servos that are in the 75g range, Pro4 HDs with heat sinks and fans on them, and batteries that are only 300 or so grams...and thus end up with the mentioned side to side balance issues.
Some will be happy, some won't. Some will notice, some won't.
As for the front/rear bias mentioned above, I agree with more up front being generally better. That's why I stuff as much up front as I can, rather than putting things back by/in the rx case. Everybody will have their own preferences, and that's all good.
"We do not act rightly because we have virtue or excellence, but we rather have those because we have acted rightly. We are what we repeatedly do. Excellence, then, is not an act but a habit." -Aristotle
My wallet supports: TeknoRC.com, NorCalHobbies.com, SMC, Sanwa, and several tire/servo companies.
justpoet is offline   Reply With Quote
Old 05-01-2016, 12:47 PM   #3532
8ight-e's Avatar
Trader Rating: 58 (100%+)
what are some tricks to keep this truck flatter on jumps.. likes to nose dive a bit. Never had this issue w/ other pro4 trucks.. just looking for thoughts. Its not from chassis slapping and going over, it just wants to nose dive... some jumps you can just adapt.. but others are really tough and there typically isn't enough motor to correct and save.
Tekno ET48, EB48.2
Durango Fleet - Dex410 v3, Dex210, Desc410, Desc210
8ight-e is offline   Reply With Quote
Old 05-01-2016, 01:01 PM   #3533
Actual front to rear weight of mid motor desert racing trucks range between 50/50 to 52R/48f. Imo that's where I'm shooting for.
SerpJimmy is offline   Reply With Quote
Old 05-01-2016, 04:36 PM   #3534
celt's Avatar
Thx.
HW SCT-Pro
Protek 150 servo
HW 4000kw
15T pinion
SMC 6500maH
Frankly, I didn't take anyones statements as "bickering." I thought most of the comments on weight bias were pretty constructive. Comments were made with good intentions, there was no foul language or name calling, and all were on topic.
I understand moderation, I am a systems administrator myself, but let and encourage folks to discuss ideas. Everyone gains understanding in different ways and at a different pace.
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Old 05-01-2016, 05:30 PM   #3535
I'm about to order this kit tonight and I was curious if there are any upgrades to purchase from the get-go for the initial build to get out of the way? I've heard it uses plastic diff pins for the spider gears? Is that something that should be upgraded right away? I haven't heard much in terms of overall durability, meaning that its tough out of the box but I feel like those diff pins should be steel.
Yeti XL Kit ⚡ Blitz ⚡ 2x 2wd Slash ⚡ 2x 2wd Stampede ⚡ SCT410.3 ⚡ TeamC TC02T ⚡ TeamC T8E ⚡ BSR BZ-444 ⚡ Mad Force Kruiser VE ⚡ SCX10 Honcho ⚡ BL E-Revo ⚡ BL Blazer SST ⚡ Mini Desert Truck ⚡ RC18MT
deviltrigger529 is offline   Reply With Quote
Old 05-01-2016, 05:32 PM   #3536
celt's Avatar
deviltrigger529,
I've rebuilt my diffs a few times with the carbon cross-pins, no issue in my opinion.
You might consider an aluminum A-Block.
http://www.amainhobbies.com/rc-cars-...kr5161/p443632
Stan Garvin
Old 05-01-2016, 05:40 PM   #3537
deviltrigger529,
Yeah I was looking more into it and its actually considered an improvement that they are boasting, so maybe I'll just give them a try. I'll keep the A-Block in mind, thanks.
Old 05-01-2016, 05:50 PM   #3538
Aluminum A block and servo horn.
twistedneck is offline   Reply With Quote
Old 05-01-2016, 05:51 PM   #3539
Ah yes, almost forgot the servo horn! Thanks!
Old 05-01-2016, 05:52 PM   #3540
Lowe's48's Avatar
Aluminum"A"block is a must imo. The plastic diff pins in other hand are great, weight saving and tougher than they look. I've raced my car almost a year and a half with no issues with those pins.
Tags
sct410, sct410.3, short course, short course 4x4, tekno
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
