    Hide Wikipost
Old 10-10-2017, 01:54 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC SCT410.3 Thread
Last edit by: DirkW
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8702 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree83Likes
Old 04-14-2015, 04:48 PM   #331
Trader Rating: 19 (100%+)
What shock pistons are the ticket on the 410's? I am sure this has been covered, but trying to set one up. CSI's , Fioroni's are pricey... but are they worth the coin?? I am at minimal going to use the CNC'd white tapered pistons. Would like to hear from some fast guys that have tested the different brands.....
Brandon Powell is offline   Reply With Quote
Old 04-14-2015, 04:49 PM   #332
Tech Legend
Cain's Avatar
Trader Rating: 235 (100%+)
hitec servos have taken a beating for me, and there customer service is the best.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL | Yokomo YZ-2 DTM x 2>
Old 04-14-2015, 04:59 PM   #333
Carter Flotron's Avatar
Not many of us know what works best on the new truck yet. Its a safe bet to go with a variety of the Tekno CNC pistons and just test and tune.
That said, Ive tried a bunch of the 'fancy' pistons out there and haven't cared for most of them. Ive recently been trying the VRP pistons and they seem to be the best out of the bunch. Cheap too!
Thanks to all my sponsors for 2016!
|Pro-line Racing|Hobbywing North America|Highest Servos|Fierce RC Solutions|
Carter Flotron is offline   Reply With Quote
Old 04-14-2015, 07:04 PM   #334
Default SCT410.1
So do most people here have the first version of the SCT410? If so, are you selling them as rollers and, if so, for what price?
I'm waiting for people to start running V3 and compare them to V1.
qstorm777 is offline   Reply With Quote
Old 04-14-2015, 07:06 PM   #335
Tech Legend
Cain's Avatar
depends on condition and price. The big thing that helped with people selling V1s was the lack of vehicles out in the wild to buy and those who wanted a vehicle right away. You could still get a nice premium for the V1.
Once the V3s are out in the wild in force, you will probably see the market drop a lot for the v1. woudl still be an excellent vehicle though.
Old 04-15-2015, 10:13 AM   #336
Jordan Anderson's Avatar
UPS delivered our kit this morning.
This is our first Tekno; looking forward to building it!
Might be a late night tonight...
JORDAN // EVAN
R/C GEARS , TRUKZ/KARZ , VRC PRO
Jordan Anderson is offline   Reply With Quote
Old 04-15-2015, 10:18 AM   #337
Tech Legend
Cain's Avatar
congrats! those are the late nights I enjoy!
Old 04-15-2015, 11:25 AM   #338
Originally Posted by Matthew_Armeni View Post
To use the Lunsford kit you listed, yes, you would need the larger camber link rod ends that accept the 5mm threads. If you don't already have that Lunsford kit and want titanium links I'd suggest you pick up six 4x55mm links (LNS1455) or six 4x60mm links (LNS1460) so that you can run the new smaller/lighter rod ends.
Thanks for clarifying this. I decided to go with 5mm camber links and the old style larger rod ends for maximum durability.
The aluminum C block and the plastic C block are different. The aluminum block puts the inserts 1mm lower than the plastic ones. The plastic C block did not have enough material to lower it as far as the aluminum version. However, the current plastic version is the same height as the older pill style C blocks so any antisquat or roll center position that you may have like can be exactly duplicated
I personally like the new aluminum C block because it allows 1 degree of antisquat with the D block in a LRC position (or HRC) or even 0 degrees of antisquat when the D block is in an HRC position. My driving style prefers very little antisquat.
So to get to the 'box stock' setup ( 3 anti-squat / 2 toe ) using the aluminum C block, you'd use the 0 insert instead of the 1 ( 1 dot down )?
Is that correct?
JORDAN // EVAN
Old 04-15-2015, 11:34 AM   #339
Tech Legend
Cain's Avatar
so, what are some of the things to start adding to the first page of the list and what can come off or be clarified? the turnbuckle size and turnbuckles to use thing seems like one.
Old 04-15-2015, 12:32 PM   #340
we can change out the old pill adjustments, and remove the info about aluminum wheel hexes.
TEKNO SCT410.3; Hobbywing Sct-pro; Hobbywing 3656 4000kv; Protek 130S; SPC 70C 7200mAh 2s
TEKNO EB48.3; Hobbywing Xerun 150a; SMC 1900kv; Savox 2274SG; ECO Power 35c 4100mAh 4s
Associated B5R; Trackstar 120a turbo; Trackstar 8.5t; Solar D771; Reedy 65C 5800mAh 2s square
kyleman7 is offline   Reply With Quote
Old 04-15-2015, 07:03 PM   #341
Tekin RX8... Check
Tekin 4300... Check
Associated DS 1015... Check
AKA Enduro tires... Check
Proline Flowtek body... Check
TEKNO SCT410.3... not check!!!
Cegraham23 is offline   Reply With Quote
Old 04-15-2015, 07:07 PM   #342
Evo X Revo's Avatar
Trader Rating: 17 (100%+)
proline flowtek or jc f250. decisions decisions. leaning towards the flowtek since upgrade has a wrap and a 25% off sale. my last wrapped sct body is still going strong over 2 years later, i think the wrap is actually holding it together at this point..
Tekno ET48
Tekno SCT410.3
Tekno EB48.2, .3
Tekno Nb48 (coming soon)
Evo X Revo is offline   Reply With Quote
Old 04-15-2015, 08:23 PM   #343
Matthew_Armeni's Avatar
Trader Rating: 31 (100%+)
Updated the first post, more to come.
Tekno RC
Matthew_Armeni is offline   Reply With Quote
Old 04-15-2015, 09:36 PM   #344
Trader Rating: 486 (100%+)
Is the truck out? I have one on order. I have 9 months to build it yet Im really excited to see it.
Now that I've discovered the ignore list I plan to use it.....17 and counting!
QDRHRSE is offline   Reply With Quote
Old 04-16-2015, 05:47 AM   #345
Trader Rating: 67 (100%+)
Tower Hobbies is now saying "mid-may". On 4/15 it was "late April"
Sounds like it'll be several more weeks before there is decent stock.
"Wow he's really fast isn't he????.....Yeah but he's Stupid"
lyork is offline   Reply With Quote
Tags
sct410, sct410.3, short course, short course 4x4, tekno
