    Hide Wikipost
Old 10-10-2017, 01:54 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC SCT410.3 Thread
Last edit by: DirkW
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8702 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree83Likes
Old 04-12-2016, 01:11 PM   #3406
Originally Posted by Snorkel54 View Post
Thank you, is it the red grease one?
Yep..
SerpJimmy is offline   Reply With Quote
Old 04-12-2016, 08:28 PM   #3407
Trader Rating: 19 (100%+)
Originally Posted by SerpJimmy View Post
The problem im running into is ,, I went with a 3S set up & Im having problems finding Quality lipos that fit . Wanted to stay in the 5300mah - 5800mah range. Soft packs MAH are perfect. But the soft pack is to long to fit tray. Also, people are in my ear that im going to puncture. Which I find hard to believe. Hard case is limited to 5000mah or upper 6000mah +.
If you are looking at going back to a 2S, the new Reedy Zappers 8000 are great. I run on a medium sized outdoor track and after a 10 min main, still have 7.8 v left in the tank.
AE
TeamOSG is offline   Reply With Quote
Old 04-12-2016, 11:57 PM   #3408
Hello fellow Tekno Lovers! I'm a new convert! I just got rid of my Losi SCTE Troy Lee & SCTE MIP Pro4mance edition to get an SCT410 & SCT410.3. I've had them for a couple months, and I couldn't be happier! I'm also waiting for my EB48SL to come in the mail! TEKNO FOR LIFE!!!!
TEKNO - SCT410*SCT410.3*EB48SL HOT BODIES D413 X 2 TEAM ASSOCIATED - B5M Champions Edition TRAXXAS - Slash 4x4*Summit 1/10*E-Revo 1/10 DJI Phantom 2 Vision+ Tekin*HobbyWing*Reedy*Castle Creations Mamba Futaba*Airtronics.
*****************Life is Short, Eternity is Forever******************
RCTesoro21 is offline   Reply With Quote
Old 04-13-2016, 12:42 AM   #3409
Welcome to the club
Snorkel54 is offline   Reply With Quote
Old 04-13-2016, 03:45 AM   #3410
Tks , buddy
I guess if roar rolls into town I might have to . Or watch from the stands
Old 04-13-2016, 09:55 AM   #3411
ryan432greening's Avatar
If ROAR rolls into town the zappers won't work for you either, the high voltage lipos aren't ROAR legal. At least yet.......
B-Main Racing
TLR 22 4.0, TLR 22 3.0, 22-4 2.0, 8ight-E 4.0
ryan432greening is offline   Reply With Quote
Old 04-13-2016, 10:20 AM   #3412
tazfam2's Avatar
Trader Rating: 40 (100%+)
Real nice sct410.3 for sale Tekno sct410.3 arts. Great deal. Must sell
Xray x1 17 Xray t4 2017
T4 2017 tekno 48.3. Associated B6 B64
Leisure Hours Hobbies and Raceway
Fiercesolutions.com
Windy City RC raceway and hobby's
tazfam2 is offline   Reply With Quote
Old 04-14-2016, 08:14 PM   #3413
Lowe's48's Avatar
Welcome !!
Come run with us at Coyote Hobbies in Victorville. Very healthy class of SCT and 1/8 buggy
Tekno Sct410.3-VRP,HW120 SCT-PRO,Pro4-4300kv,Hitec,LRP 8000/2s
Tekno SL.3-VRP,HW120 SCT-PRO,T8i-1950,Hitec,LRP 5000 4s
Weapon of choice : Airtronics M12
Home track : Coyote Hobbies,Ca
Lowe's48 is online now   Reply With Quote
Old 04-16-2016, 09:38 AM   #3414
I'm almost done building. I have a few questions with the ride height and shock length. My shock lengths are Front-101, Rear-119, (measuring the mounting holes, right?) I have zero tension on the springs and the droop screws are all the way in, is it possible to make them longer? My ride height is Front-34 Rear-29, how do I lower the ride height since I have no tension on the shocks already ?
My set up is stock, with pink springs front and back, front shock oil is 40, 35 in rear
weedsnager is offline   Reply With Quote
Old 04-16-2016, 09:41 AM   #3415
I think you may have put the droop screws in from the top of the arms, they need to go in from the bottom so the button had hits the chassis. Note that the other end of the screw has a space for an Allen so toy can adjust it from the top.
Danger Dietrich is offline   Reply With Quote
Old 04-16-2016, 10:22 AM   #3416
Drop screws are installed correctly. They are all the way up in the arms, not even touching the chassis
Old 04-16-2016, 10:46 AM   #3417
are you measuring the front ride height behind the kickup in the front of the chassis? Also, are you measurinng with electronics and battery installed?
TEKNO SCT410.3; Hobbywing Sct-pro; Hobbywing 3656 4000kv; Protek 130S; SPC 70C 7200mAh 2s
TEKNO EB48.3; Hobbywing Xerun 150a; SMC 1900kv; Savox 2274SG; ECO Power 35c 4100mAh 4s
Associated B5R; Trackstar 120a turbo; Trackstar 8.5t; Solar D771; Reedy 65C 5800mAh 2s square
kyleman7 is offline   Reply With Quote
Old 04-16-2016, 10:59 AM   #3418
wrightcs77's Avatar
Trader Rating: 521 (100%+)
Take off you shocks and see if your arms move freely. Once installed, the droop screws compress the hole the hinge pin goes thru, creating too tight of a fit. Take a 4mm reamer or a round chainsaw file (I got one for .99) and run it thru the arm a couple times.
Next, compress the springs a few times to let them settle.
Finally, if needed, you can take off the upper spring collar and file it down to half thickness, which should lower your possible ride height by a couple mm.
wrightcs77 is offline   Reply With Quote
Old 04-16-2016, 01:11 PM   #3419
Delete
Old 04-16-2016, 01:13 PM   #3420
Yes
The arms move freely. I'm not even close to being a few mm's off, I'm 10 mm off.
Tags
sct410, sct410.3, short course, short course 4x4, tekno
