    Hide Wikipost
Old 10-10-2017, 01:54 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC SCT410.3 Thread
Last edit by: DirkW
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8702 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree83Likes
Old 04-04-2016, 07:53 PM   #3346
Originally Posted by weedsnager View Post
Thanks for all your help so far. I ordered the kit along with the
Hobbywing SCT ESC/Motor Combo.... Is there a limit to battery size with this motor/esc ? Pinion gear suggestions ?
I run a 15 tooth pinion. plenty of speed for anything indoor and a lot of torque. motor barely gets hot unless you run practice.
using a 2S / 8000 pack but that's overkill I just like it because it balances the trucks weight left to right. I used a really heavy servo and ESC.
in a 5min race I only use 1750 Mah of energy! I usually finish a 7min race with 7.9V still.
twistedneck is offline   Reply With Quote
Old 04-05-2016, 03:11 AM   #3347
Dan.J's Avatar
Trader Rating: 21 (100%+)
You guys that say you are running 15/16T pinions on the Hobbywing 4000, have you try'd bigger? I really felt that even indoors that motor wants a 17-19T depending on layout. Of course if it works for you then it works, just seem's odd to me.
Tekno EB48.3/Tekno EB48SL/Tekno SCT410.3
Dan.J is offline   Reply With Quote
Old 04-05-2016, 03:33 AM   #3348
Josh L's Avatar
I run the 15t pinion with a 4700 and that feels pretty much perfect in my opinion. I would run at least 17 to 18 on a 4000
Josh L is offline   Reply With Quote
Old 04-05-2016, 07:20 AM   #3349
Fwiw tower hobbies dropped the price to 369 before discount code. That's 325 shipped. Killer deal if anyone is thinking about getting this truck.
Homer723 is offline   Reply With Quote
Old 04-05-2016, 07:49 AM   #3350
And $10 back in tower cash for every $100 you spend starting today. I bought mine yesterday.
weedsnager is offline   Reply With Quote
Old 04-05-2016, 06:05 PM   #3351
Will this body fit ?
Pro-Line Pre-Cut Flo-Tek Ford F-150 Raptor SVT Clear
http://www3.towerhobbies.com/cgi-bin...W-caAoLm8P8HAQ
Old 04-05-2016, 06:49 PM   #3352
Trader Rating: 32 (100%+)
Yes it fit but pricey. I like the Jconcept HF2
raved007 is offline   Reply With Quote
Old 04-05-2016, 06:51 PM   #3353
Do they offer it pre cut ?
Old 04-05-2016, 06:54 PM   #3354
Yeah killer deal $369.99 less $60 off = $309 shipped
Old 04-06-2016, 08:53 AM   #3355
I run a 4700 hobby wing with 15tooth pinion and it gets really hot, 2s 5500. Solutions?
HPI Trophy Truggy, Tekno 410.3 sct, TLR 8ight e 3.0, Associated B5M, Tlr 8ight 4.0, tlr 8ight e 4.0, tlr scte 2.0, associated rc8t3e
mikey91martin is offline   Reply With Quote
Old 04-06-2016, 01:36 PM   #3356
Time to tweak the esc? Punch, current limiter, timing etc
Snorkel54 is offline   Reply With Quote
Old 04-06-2016, 01:46 PM   #3357
If you are still getting a hot motor add a fan. I did the same on my 4700. On hot days even the 4300hd needs a fan for long practice runs.
Old 04-06-2016, 05:10 PM   #3358
Thanks!
Old 04-06-2016, 06:20 PM   #3359
Slotmachine's Avatar
Send a message via MSN to Slotmachine
How long is your track laptime wise? I run on a 100ft straight track with 18sec laptimes with a 17 pinion with no heat problems in a 6 minute race. My boost is 8 and timing is 7.
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 04-06-2016, 08:50 PM   #3360
With the Hobbywing 4000, running on 2s...7200, with the 16t, outdoors, is there anything I need to tweak with the esc program card or just run it as is out of the box ?
Tags
sct410, sct410.3, short course, short course 4x4, tekno
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
