    Hide Wikipost
Old 10-10-2017, 01:54 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC SCT410.3 Thread
Last edit by: DirkW
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8702 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree83Likes
Old 03-21-2016, 06:58 PM   #3301
Some " More" build ?
1.Tkr5053a is flanged but on page 9 bag f it shows is on opposite side ? I followed f-4 picture. F-3 has flanged on opposite side if you go to back of manual & reference part #. weirdness??
2.Tkr5107 rubs on ackerman arm in one direction only? ( Dremel down )
3.Tkr5579 Shafts - ad orings? ( Orings come with Slash kit )
4.Tkr6018n - where does manual show when to screw these on? ( no biggie , figured id ask though)
5. StepL-3 Shock mounts inboard or outboard A - arm ? seems to look & fit better inboard IMO
SerpJimmy is offline   Reply With Quote
Old 03-22-2016, 11:02 AM   #3302
Ruffdog1's Avatar
Do any of you guys clean and re-lubricate your Tekno bearings or just replace them when needed? For those that clean them, what do you use to lubricate them? How do they come lubricated from the factory? I have some racers edge bearing oil but should I be using some black grease instead? Thanks in advance!!
Ruffdog1 is offline   Reply With Quote
Old 03-22-2016, 11:38 AM   #3303
Matthew_Armeni's Avatar
Trader Rating: 31 (100%+)
I would just buy new ones, it's not worth the time to clean and re-lube them to me. I used to buy from Avid RC, they sell bearings for $1 each.
Tekno RC
Matthew_Armeni is offline   Reply With Quote
Old 03-22-2016, 02:44 PM   #3304
ryan432greening's Avatar
Who has a recommendation for diff weights for better turning on indoor high-bite?
Anyone tried going to more of a grease?
B-Main Racing
TLR 22 4.0, TLR 22 3.0, 22-4 2.0, 8ight-E 4.0
ryan432greening is offline   Reply With Quote
Old 03-22-2016, 05:43 PM   #3305
Dan.J's Avatar
Trader Rating: 21 (100%+)
What setup is on the truck? I run mostly on med/high bite indoor and usually am taking steering out to get smooth laps, the truck has shit tons of steering so I'm thinking maybe something in your setup is not where it needs to be. What tires/compound you using most the time? Post a setup sheet, I'm sure plenty of people can offer up some things that may help . As for diffs, 10/10/7 and 7/7/5 seem to be the go to's for most locally but I do hear of people trying stuff heavier with success.
Tekno EB48.3/Tekno EB48SL/Tekno SCT410.3
Dan.J is offline   Reply With Quote
Old 03-22-2016, 06:02 PM   #3306
Trader Rating: 16 (100%+)
15/15/10 is the go to for most of the team. The truck is so light and small tire contact patch. Every time I try lighter I bail and go back to 15/15/10. Green springs all the way around. Play with sway bars a lot!
Truck is very predictable with that diff setup.
Steve Downs
Team Kyosho, AKA Tires, COWRC, BOOMrc, Triton RC Engines, FTM Grip, Boca Bearings
steve downs is offline   Reply With Quote
Old 03-22-2016, 06:59 PM   #3307
justpoet's Avatar
Please see comments in line.
The flange direction can be changed as part of the tuning of the vehicle to move the link even further. It is also often shown on different sides of the vehicle.
This happens on some vehicles. I take a bit out just to be safe on my vehicles, as you can see here where I talk about doing so for the truggy.
+ YouTube Video
Generally we don't add o rings here. If you can't stand the sound, o rings can help make it a little quieter. However, with the chassis flex that can happen in a large crash, leaving the full amount of space for the shaft to move can be the difference between a bent shaft or not.
TKR6018 is the shock cap. These will be built different depending on how you're building the shocks, as we can use emulsion, vented, or non vented builds. You can see an example of a shock build by Ryan Lutz here.
+ YouTube Video
If you mean inner or outer holes (from chassis center towards wheel), then this is a tuning option again. If you mean inside the rectangular opening vs on the outside edge of the arm, then it should always be in the rectangular opening so it is supported by the arm on both the front and back sides of the screw.
"We do not act rightly because we have virtue or excellence, but we rather have those because we have acted rightly. We are what we repeatedly do. Excellence, then, is not an act but a habit." -Aristotle
My wallet supports: TeknoRC.com, NorCalHobbies.com, SMC, Tekin, and several tire/servo companies.
justpoet is offline   Reply With Quote
Old 03-22-2016, 07:26 PM   #3308
Ruffdog1's Avatar
I usually run 7-7-5 associated diff fluid on outdoor hard packed medium traction watered track. 15-15-10 seems pretty thick but I hear people are liking the thicker setups with the 410.3. What benefits would I get by going with thicker diff fluids?
Old 03-22-2016, 08:30 PM   #3309
Tks again , for hooking me up Mr poet..
Q5 : I looked at the manual until i was cross eyed.. It really looks as if shock get mounted on outside of a arm .Weirdness ! I have a buddy that mounts his 410.3 front shocks on the outside as well. Dizzy on this one. Maybe another option ? IDK
Old 03-22-2016, 09:29 PM   #3310
The shock mounts inside the arm. Here's a pic of the SCT410, the .3 mounts the shock the same way.
Tekno RC
Old 03-22-2016, 09:31 PM   #3311
Trader Rating: 25 (100%+)
I used this setup for high bite. The tweak on this setup is pink fronts. I normally run green all around but this setup worked really well on high bite.
http://www.teknorc.com/tekno5/wp-con...0Bumpy_Wet.pdf
LRP America
My RC Depot - myrcdepot.com
tfrankito is offline   Reply With Quote
Old 03-22-2016, 09:35 PM   #3312
thicker fluids front and middle give 1. more 4x4 action in center diff. better acceleration 2. more on power steering. front diff 3. more traction off power entering corner. etc... The truck will pull it self around the corner. It will also smooth out the steering
LRP America
Old 03-23-2016, 03:17 AM   #3313
Awesome Matt!
Old 03-23-2016, 09:19 PM   #3314
Just about done with my build. What way should I build the shocks I know there's a few options and should I run the shock oil it came with or put heavier in?
HPI Trophy Truggy, Tekno 410.3 sct, TLR 8ight e 3.0, Associated B5M, Tlr 8ight 4.0, tlr 8ight e 4.0, tlr scte 2.0, associated rc8t3e
mikey91martin is offline   Reply With Quote
Old 03-24-2016, 06:32 AM   #3315
celt's Avatar
Default shock package...
Has anyone tried this package:
Front
oil: 800 (65wt)
piston: 4x1.8 taper up
spring: Tekno pink
rebound: min.
vented
Rear
oil: 500 (40wt)
spring: Tekno pink
rebound: min.
vented
http://www.teknorc.com/tekno5/wp-con...Lewis_SDRC.pdf
Just looks odd on paper.
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Tags
sct410, sct410.3, short course, short course 4x4, tekno
