    Hide Wikipost
Old 10-10-2017, 01:54 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC SCT410.3 Thread
Last edit by: DirkW
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8702 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree86Likes
Old 04-13-2015, 02:57 PM   #286
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Originally Posted by Nemaris View Post
Yes! The Jconcepts Ford F-250, now believe me when I tell you I'm not a ford guy, but that body is done really well. I've been trying to give myself an excuse to paint a 3rd body.
I have run the f-250 body on the old truck and it jumped nicely. I am drawing 1 up now for my new truck and will post pictures when I`m done, the truck gets here Tuesday.
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 04-13-2015, 03:14 PM   #287
Matthew_Armeni's Avatar
Trader Rating: 31 (100%+)
Originally Posted by Cain View Post
So in your opinion Matt do you believe if you are doing say a 4S 1/8 motor setup to upgrade to either the steel or aluminum pins? (sorry question is more EB48SL on regular buggy electronicc oriented)
You definitely don't need to upgrade right away. You should be fine for a whole season on the composites. If and when you do upgrade, the aluminum pins are the way to go.
Originally Posted by Jordan Anderson View Post
To use the Lunsford SCT410 titanium turnbuckles (LNS2600) on the SCT410.3, you'd just need a set of the old SCT410 camber link rod ends (TKR5051) to use on the 5x50mm / 5x55mm front and rear camber links? Correct?
To use the Lunsford kit you listed, yes, you would need the larger camber link rod ends that accept the 5mm threads. If you don't already have that Lunsford kit and want titanium links I'd suggest you pick up six 4x55mm links (LNS1455) or six 4x60mm links (LNS1460) so that you can run the new smaller/lighter rod ends.
Originally Posted by losi b View Post
does it come with the black or white shock pistons?
The kit comes with the molded black pistons.
same question and which pistons exactly? (8 x 1.3, etc)
They are the 10x1.2 pistons. We looked into including the delrin pistons but it would have increased the cost of the kit.
question on the setup sheet as shown in the manual.
Are the aluminum hingepin blocks the same as the composites as far as position settings or is there a difference on some? Reason I ask is that looking at the setup sheet, the "C" Block is listed as "-1" for the aluminum one?
For the stock setup, what kind of "conditions" is that considered for? If I recall correctly the stock setup for the V1 was considered for "smooth" tracks I think.
Would this one be worth running as is for rough loose 1/8 tracks or what should be changed right away setup wise?
The aluminum C block and the plastic C block are different. The aluminum block puts the inserts 1mm lower than the plastic ones. The plastic C block did not have enough material to lower it as far as the aluminum version. However, the current plastic version is the same height as the older pill style C blocks so any antisquat or roll center position that you may have like can be exactly duplicated
I personally like the new aluminum C block because it allows 1 degree of antisquat with the D block in a LRC position (or HRC) or even 0 degrees of antisquat when the D block is in an HRC position. My driving style prefers very little antisquat.
Tekno RC
Matthew_Armeni is online now   Reply With Quote
Old 04-13-2015, 04:12 PM   #288
Nemaris's Avatar
Trader Rating: 18 (100%+)
Originally Posted by rcnewbie418 View Post
Thanks man. you mean the 'XLT' body?
http://www.amain.com/rc-cars/jconcep...co0243/p239843
Yes that is the one, it has a flatter hood, and the dipped area on the rear
Nemaris is offline   Reply With Quote
Old 04-13-2015, 05:06 PM   #289
Jakesterama's Avatar
Trader Rating: 67 (100%+)
"Order Now Being Picked and Packed in Warehouse" Wooooo Hoooooo!
if (racing_skill<AWESOME){
practice_lap++;
Jakesterama is offline   Reply With Quote
Old 04-13-2015, 06:29 PM   #290
Trader Rating: 19 (100%+)
when did you place your order? mine is still nowhere.
TEKNO SCT410.3; Hobbywing Sct-pro; Hobbywing 3656 4000kv; Protek 130S; SPC 70C 7200mAh 2s
TEKNO EB48.3; Hobbywing Xerun 150a; SMC 1900kv; Savox 2274SG; ECO Power 35c 4100mAh 4s
Associated B5R; Trackstar 120a turbo; Trackstar 8.5t; Solar D771; Reedy 65C 5800mAh 2s square
kyleman7 is offline   Reply With Quote
Old 04-13-2015, 06:31 PM   #291
I'm expecting my kit any day now and need to get some wheels and a pinion. This will be my first SCT so sorry if I am covering old ground but my searches did not turn up much.
I have a Pro 4 3300 motor. Any recommendations on a good starting point for a pinion gear? I will be running on a loose outdoor track. What is the gear pitch?
Also any recommendations on wheels?
jjl1 is offline   Reply With Quote
Old 04-13-2015, 06:38 PM   #292
March 20th, pretty much as soon as they posted it.
Old 04-13-2015, 06:59 PM   #293
It's a standard mod1 pinion gear.The wheels will be a losi offset.
ba4ma is offline   Reply With Quote
Old 04-13-2015, 07:27 PM   #294
Jpm1's Avatar
Our 1st lot have just shipped, so there on their way to Oz!!!
...........Coast2coastRC ............. http://www.coast2coastrc.com.au/
Australian Importer for SMC Products
Australian Distributor for TeknoRC-LeadfingerRC-SnowsDesigns(FTW)-PT Racing Oils-TritonRC
Gceorrccc founding member.(Gceorrccc.com)
Jpm1 is offline   Reply With Quote
Old 04-13-2015, 08:49 PM   #295
Trader Rating: 27 (100%+)
Mine has arrived from Tower @ Reno
going box stock till approx mid summer then perhaps al c,d, blocks and split diff
Cain, been happy bashing with Vants 4000mah just got some more with higher c rate from barnfloor/dirtcheap as per 4 plug vs 2 in the end it is still going back into 2 at the esc so I don't think it can make a huge difference, but time will tell. Right now I only have the four plug in shorty for b5m. The 6500 75c,hard wired vants I just got with 10 awg wire seams very beefy hope to run in about a week
cjd66 is offline   Reply With Quote
Old 04-13-2015, 10:56 PM   #296
Aahhh that new truck smell!
mikeinsocal is offline   Reply With Quote
Old 04-14-2015, 07:39 AM   #297
I expect mine on Thursday (thanks Pete). I will have my bench ready for assembly Wednesday night, so I can come home Thursday, and begin assembly. Can't wait!
The off-road Tekno 3some-> EB48.4 - ET48.3 - SCT410.3 ---Soon eb410
The oval 3some -> Tekno SCT410.3 - Tekno SCT210.3 - Blitz
Sponsors: Fiercercsolutions.com, AKA, jtbearingco.com, CowRC, Walden Designs, Leadfinger Racing, And BoomRC.net
ezlight is offline   Reply With Quote
Old 04-14-2015, 07:50 AM   #298
FastPete's Avatar
Trader Rating: 44 (100%+)
Your welcome, cant wait for pics, parts are in also will be marked in stock today. Just no arms, wheel hexes, and front bumper yet. Hoping this week. Got a bunch of preorders already.
Authorized Dealer for /Agama / Tekno / Team Associated / Schelle / Hobbywing / PT Racing Shock & Diff oil / Serpent / Tekin / JConcepts / AKA / Proline / Savox / M2C / Picco / Raceform Jigs/ Proamps Servos-Lipos www.fiercercsolutions.com Like us on facebook www.facebook.com/FierceRCSolutions
FastPete is offline   Reply With Quote
Old 04-14-2015, 08:13 AM   #299
Tech Legend
Cain's Avatar
Trader Rating: 239 (100%+)
How can you tell which tower its coming from?
Thanks for the info on the vants. Do you know where to get them hardwired in the 7600mah size? Promatch won't be back in stock for about a month it sounds like, so on the hunt.
Speaking of batteries, other than SMC who else makes a reasonably priced 7000mah+ lipo hardcase pack that is in stock? Can be bullets or hardwired.
< HB Racing D413 | Tekno EB48SL / SCT410.3 | Tekno EB410 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 04-14-2015, 08:16 AM   #300
genstattu has 7200's (70C) in stock. These are what I run in my 410.
Tags
sct410, sct410.3, short course, short course 4x4, tekno
