    Hide Wikipost
Old 10-10-2017, 01:54 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC SCT410.3 Thread
Last edit by: DirkW
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8702 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree83Likes
Old 02-01-2016, 10:13 PM   #2941
An suggestion on a servo for this truck?
Malazan is offline   Reply With Quote
Old 02-01-2016, 10:58 PM   #2942
hitec 7955tg - great choice
Tekno EB48.3, EB48SL, and SCT410.3
Team Associated B5M Lite
HoldDaMayo is offline   Reply With Quote
Old 02-02-2016, 03:13 AM   #2943
Dan.J's Avatar
Trader Rating: 21 (100%+)
I just ordered the new futaba S9372sv's for my stuff, should be good one's but time will tell.
Tekno EB48.3/Tekno EB48SL/Tekno SCT410.3
Dan.J is offline   Reply With Quote
Old 02-02-2016, 04:47 AM   #2944
lowspark's Avatar
I run the tekin 4300 with a rx8 with no heat issues. 16t pinion. Large indoor hard pack dirt track (32 second lap times). Punch set at 70. Brake at 50.
7 min qual using 5800 lipo, 25-30% batt power remain.
10 min main using a 7200 lipo. Battery has 25-30% after race.
There is a very fine line between "hobby" and "mental illness".
Tekno SCT410.3 / Tekin RX8 Gen3 / Tekin Pro-4 HD 4300 / Savox 1268 servo / Spectrum DX5R
lowspark is offline   Reply With Quote
Old 02-02-2016, 12:50 PM   #2945
Josh L's Avatar
I am glad you posted this, cause I was getting upset about how they discontinued the 9352 and couldn't seem to find a likeness with any of the other newer listed servos.
Amain hasn't even stocked this one yet, but I found it at Tower.
Interestingly enough tower only list it's 6v output numbers, rather it's 7.4v stats.
Also, everyone else seems to be measuring it's torque in metric kg-cm, instead of the normal oz/in
The only thing I didn't like about the older 9352 servo was that it didn't like to be hooked up to an unregulated 2S battery and would become unstable in operation when powered like that.
I had no choice but to use an external BEC to get my low output BEC from the hobbywing SCT-Pro to allow it to operate with full stable power.
Looks like they must have fixed this issue with the new 9372, because it directly states that it was designed to operate from 2S outputs in the description, with the added benefit of roughly 40 oz/in torque as well.
The conversion stats come out to be>
7.4v - .06 sec/60
7.4v - 341 oz/in
I will definitely be getting one of these to try out in the near future.
Josh L is offline   Reply With Quote
Old 02-02-2016, 04:05 PM   #2946
Dan.J's Avatar
7.4v - .06 sec/60
7.4v - 341 oz/in
Yah, the specs look good @.06/341tq on 7.4 and thats why I bought them. I was disappointed too when I went to purchase another 9352 and found it to be discontinued but these are the new supposed to be better replacements to that servo, time will tell.
Old 02-02-2016, 04:53 PM   #2947
Savox SB-2274SG per justpoet's recommendation. Works great.
80ms/347 oz-in @ 7.4v
roundguy is offline   Reply With Quote
Old 02-02-2016, 05:55 PM   #2948
Dan.J's Avatar
I know alot of fast guys that run Savox and love them so I am not knocking them but to me they just don't give me the feel my past RadioPost servo's or my current Futaba servo's do, they just don't feel as smooth and precise but thats just my opinion. As I said alot of very fast guys run them so......
Old 02-02-2016, 07:17 PM   #2949
Trader Rating: 32 (100%+)
I've been running this servo in my truck and love it so far
http://www.horizonhobby.com/vortex-v...servo-ori68027
raved007 is offline   Reply With Quote
Old 02-02-2016, 09:12 PM   #2950
Trader Rating: 486 (100%+)
I've used many of the servos that people have suggested and they are all very good. Currently I use the Airtronics 94780M. On paper its slow but its speed is perfect on the track. I run my SCT like a hammer head, it is a hammer head class after all, and no matter who or what I hit I've never broken one. Specs:
Torque at 4.8v: 361oz-in (26.0kg-cm)
Torque at 6.0v: 423oz-in (30.5kg-cm)
Speed at 4.8v: 0.19sec/60
Speed at 6.0v: 0.15sec/60
Now that I've discovered the ignore list I plan to use it.....17 and counting!
QDRHRSE is offline   Reply With Quote
Old 02-04-2016, 03:17 PM   #2951
I have been away from the hobby for a while and I got the new Tekno sct410.3 and was wondering if my Viper Copperhead R system is worth even running or get something else? I have the 4.5 and 5.1 motors and have never used them thanks for any information.
mastark is offline   Reply With Quote
Old 02-04-2016, 06:44 PM   #2952
Look what the UPS man brought me
Old 02-04-2016, 06:57 PM   #2953
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
They will work just fine. The copperheads are notiriously noisy so your truck might be a bit louder than others.
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 02-04-2016, 07:03 PM   #2954
mkl
Nice! Enjoy the build!
Tekno SCT410, Tekno EB48, Tekno ET48, X-Ray 808E, TRCE Slash 4x4, Tamiya Lunchbox, Tamiya Frog, Slash 4x4, Axial Wraith
mkl is offline   Reply With Quote
Old 02-06-2016, 11:53 AM   #2955
King DORK's Avatar
Trader Rating: 31 (100%+)
Lol. I had a Copperhead system (louder than most) in an Axial EXO buggy which has a very loud drivetrain. Thing was hilarious running down the street. Sounded similar to a kid putting playing cards in the spokes of his bike rims. Motor was actually very ballsy and plenty fast in the EXO, which was a heavy pig.
B5M Lite, Centro CT4.2, Tekno SCT410.3, Losi 22-4 (RC Shox-ified), Losi Comp Crawler, Losi MRC Pro Gatekeeper, Super Clodbuster
Proud father of my boys Kevin, Brandon, Dylan, and my dogs Kaelee, Bella Roo, and Wilbur. Thank you to my only sponsor, my beautiful wife!
King DORK is offline   Reply With Quote
Tags
sct410, sct410.3, short course, short course 4x4, tekno
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Screech
