    Hide Wikipost
Old 10-10-2017, 01:54 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC SCT410.3 Thread
Last edit by: DirkW
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8702 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 – V2 Adjustable Hinge Pin Brace “A” block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 – V2 Adjustable Hinge Pin Brace “C” block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B – HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 – Hinge Pins (inner, front/rear)
TKR5516 – Front Suspension Arms and TKR5515 – Rear Suspension Arms
TKR5542 – Spindle Carriers - TKR5541B Spindles
TKR6009 – Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree87Likes
Old 12-04-2015, 11:18 AM   #2686
rjohn929's Avatar
Originally Posted by ResultsRC View Post
i can finish a race with the fan unplugged, im running longer in practice and it eases the load and heat on the elecs. 4700kv down to a 13 pin will run good bit over 10 min in practice,its as fast as i need to go on this size track
4700 with a 13t might be undergeared creating more heat. I run a 15-16t with my LRP Dynamic 10L 4700 and can run all day while keeping it under 180.
SCT410.3, SCT410, ET48, SCTE 1.0, SC10 4x4, SC10, B44.1, B44.2, Yeti, Yeti XL, Wraith, SCX10 JK, Gold pan/repro, Worlds Car/repro, Rival, Emaxx, Tmaxx, assorted Ofna's, 6 Big Bears, MERV, 3DR Solo, DMG DRIII, Vanquish, Avante, mixed bag of crawlers/scalers and the list goes on and on and..........
rjohn929 is offline   Reply With Quote
Old 12-04-2015, 12:47 PM   #2687
Josh L's Avatar
Agreed! 13T is way to low. Should never need lower than 15. Over revving the motor can cause more heat than over gearing one.
Josh L is offline   Reply With Quote
Old 12-04-2015, 08:05 PM   #2688
my kit arrived today. i was able to get a great deal from tower. they had it on sale for a couple of days and a 25 dollar gift card.
i will start the build it tomorrow. i am siked
rekim is offline   Reply With Quote
Old 12-05-2015, 10:08 AM   #2689
Man I love my teknos!!
Took my sct410.3 to my first race last night. TQed and won by two laps against mostly associated and losi trucks. I was dialed all night on a hard packed clay watered indoor track. Truck was awesome. Thanks for answering all my set up questions guys it really paid off for me. And thanks tekno! I have all your electric vehicles and will purchase whatever you come up with in the future!!!!
Dragonfueled is offline   Reply With Quote
Old 12-05-2015, 12:30 PM   #2690
FAO
FAO's Avatar
Location: Germany near famous clay track of RCRT Duisburg
Default rodends
Originally Posted by qstorm777 View Post
...Are you saying you have all the marks on your rods pointing towards the same side of the truck (left or right), but rotating the rod towards the front of the car shortens some of the links, but lenghtens the other ones?
Yes to 1. (right) and no to 2. question. But with driving and servicing other cars with the correct marks, i get confused.
The former seastar:
Tekno SC 410.3, Serpent Spyder SCT, dust, loomy, slippery, dirt
FAO is offline   Reply With Quote
Old 12-05-2015, 12:37 PM   #2691
FAO
FAO's Avatar
Originally Posted by Sofa King View Post
On my first SCT410.0, some of the turnbuckles had the mark on the left hand threads and some had the mark on the right hand threads...
Thanks a lot for answering, so iīm not the only one and not stupid...
Doing setup-changes i alwas look for the marks of the left thred, with marks on the right thread on some of my cars i become confused in the pits.
Think i will change to titanium pushrods.
The former seastar:
Old 12-05-2015, 12:47 PM   #2692
Dragon what is you setup?
taz169 is offline   Reply With Quote
Old 12-05-2015, 12:56 PM   #2693
Ruffdog1's Avatar
what setup do people like the most for their 410.3? outdoor, clay, bumpy, hard pack but dusty? Thanks in advance!!
Ruffdog1 is offline   Reply With Quote
Old 12-05-2015, 01:27 PM   #2694
FAO
FAO's Avatar
Congratulation! Are there some videos to look at?
The former seastar:
Old 12-05-2015, 02:07 PM   #2695
Not the best video but it's all I got
https://youtu.be/0h2A6mBLWIM
Old 12-05-2015, 04:01 PM   #2696
Trader Rating: 32 (100%+)
Here is my video with FTW DAIMOND BODY seating on third got second place in a-main.Since running with steering stop got TQ'd, Win in AMAIN compare with out steering stop out of 3rd place.
https://www.youtube.com/watch?v=wTGCMCp-6qE
raved007 is offline   Reply With Quote
Old 12-05-2015, 10:18 PM   #2697
TheCore's Avatar
Trader Rating: 45 (100%+)
nice run dragon.
i haven't been to critters to see that new track layout. it looks... interesting.
what were your lap times ?
TheCore is offline   Reply With Quote
Old 12-06-2015, 03:49 AM   #2698
Josh L's Avatar
Those indoor races look interesting. There are none here in central VA
Old 12-07-2015, 02:13 AM   #2699
FAO
FAO's Avatar
Thumbs up Jump, Jump, Jump
Nice run, clearest line of all cars. One can see the nose down "problem", and how you managed to get benefit of it. Very jumpy course.
The former seastar:
Old 12-07-2015, 10:51 AM   #2700
I was there! This truck was friggen DIALED. I was the guy putting his together right behind you in the pits....coming for you brother!!!
Hungryarch is offline   Reply With Quote
Tags
sct410, sct410.3, short course, short course 4x4, tekno
