    Hide Wikipost
Old 10-10-2017, 01:54 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC SCT410.3 Thread
Last edit by: DirkW
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8702 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree83Likes
Old 11-04-2015, 10:42 AM   #2491
Originally Posted by ezlight View Post
Ok, So did the front diff do the same thing when trying to install it in the rear bulkhead??
Yes the front diff did the same thing and the rear diff was perfect in the front bulkhead?
theo551 is offline   Reply With Quote
Old 11-04-2015, 11:25 AM   #2492
Rebuild diff. That's your issue. Something not quite right there.
The off-road Tekno 3some-> EB48.4 - ET48.3 - SCT410.3 ---Soon eb410
The oval 3some -> Tekno SCT410.3 - Tekno SCT210.3 - Blitz
Sponsors: Fiercercsolutions.com, AKA, jtbearingco.com, CowRC, Walden Designs, Leadfinger Racing, And BoomRC.net
ezlight is offline   Reply With Quote
Old 11-04-2015, 11:41 AM   #2493
Originally Posted by Josh L View Post
Sounds like you don't have it seated completely strait.
You might wanna go ahead and tear down that diff, clean and dry off the seal and then reassemble it to try again. These are extremely close tolerance parts compared to other diffs I have built. Wouldn't take much to bind things to get a slight wobble induced into the gear rotation.
When everything is apart, I would check the outer gear thoroughly by laying it on a very flat surface, like a glass table or marble counter top to make sure it is't a manufacturer warp or defect in the trueness of the part. If all looks good, just put it back together again and go from there.
When I used the rear diff in the front gear box I get the same results. When I use the front diff in the rear it works perfectly. This leads me to believe it maybe a defective front bulkhead\gear box. I could be wrong but I don't know what else it could be.
Old 11-04-2015, 11:45 AM   #2494
Both diffs work in the rear and both diffs don't work in the front. How could it be the diffs? Wouldn't they not work in the rear if it was the diff?
Old 11-04-2015, 11:56 AM   #2495
Well, that's not what you said. You said "the rear diff was perfect in the front bulkhead" Which, IF that were the case, the issue would be the front diff.
But now that you say "Both diffs work in the rear and both diffs don't work in the front.", you have a different scenario.
Look closer at your pinion/bearings.
1) Make sure the inside bearing is seated fully into the opening in the bulkhead.
2) Make sure the pinion seats fully into bearing.
3) You may not need shims at all.
Old 11-04-2015, 12:15 PM   #2496
My mistake. I meant to say front diff was perfect in the rear bulkhead
Old 11-04-2015, 12:24 PM   #2497
Also, IIRC, there was mention, or someone showing to use a little fine sandpaper to shave back the very edge of the bulkhead is sometimes needed. Don't remember where I saw that though.
I've built 3, and never had an issue.
Old 11-04-2015, 01:51 PM   #2498
I got it guys thank you all so much for your help. There was a small piece of something stuck to the bearing I mean very small it's hard to believe that woukd make a difference. Thanks again guys I'm sure you will be hearing from me again
Old 11-04-2015, 01:55 PM   #2499
Good stuff, glad you found the problem.
Old 11-04-2015, 05:31 PM   #2500
Yeah me too, it was making me crazy. Thanks again for your help.
Old 11-05-2015, 05:18 PM   #2501
justpoet's Avatar
Trader Rating: 16 (100%+)
When in doubt, ask. We're a very friendly and helpful group of folks in the Tekno forums.
"We do not act rightly because we have virtue or excellence, but we rather have those because we have acted rightly. We are what we repeatedly do. Excellence, then, is not an act but a habit." -Aristotle
My wallet supports: TeknoRC.com, NorCalHobbies.com, SMC, Tekin, and several tire/servo companies.
justpoet is offline   Reply With Quote
Old 11-06-2015, 08:55 AM   #2502
Accept for this guy......he's kinda questionable...
Old 11-06-2015, 10:00 AM   #2503
I talked to a Tekno rep on the phone the other day for quite a while. They are a very friendly and extremely helpful group of people. Jonathan gave me some great setup advice and was very patient with all my questions.
By the way, if you're running on a indoor clay track and haven't put those spacers under your wheel stops you are not helping yourself at all. I started at 2mm of spacer, that helped a lot but did decrease steering radius on the track. Switched to 1mm of spacer and a great amount of oversteer came back. I ended up settling at 1.5 mm of spacer under the stops and it is perfect! Turns just about a sharp as without the spacers but is so much more stable, consistent and easier to driver without a ton of oversteer. What is interesting is after you install the spacers and drive the truck at slow speed on the ground, the lack of steering radius is noticeable. But once you get the truck on the track at speed the thing turns as sharp as before, this truck likes to be driven hard!
I am so happy with the 410.3. It is a great car to drive. Feels nimble, consistent and is just a fast car. Tekno did the short course market awesomely, I hope they're around for a while. I wouldn't mind picking up one of their e buggies next.
JayCrash450 is offline   Reply With Quote
Old 11-06-2015, 10:29 AM   #2504
Josh L's Avatar
"Except"
If your going to take a crack at a person you have to have correct grammar!
It is after all the internet mayne! Spell something wrong on youtube and see what happens!
On another note,.. I received some nice parts in the mail today. The girl friend will be ecstatic!
Will also be getting these three soon to do some testing with
Josh L is offline   Reply With Quote
Old 11-06-2015, 10:33 AM   #2505
Josh L's Avatar
Originally Posted by JayCrash450 View Post
I talked to a Tekno rep on the phone the other day for quite a while. They are a very friendly and extremely helpful group of people. Jonathan gave me some great setup advice and was very patient with all my questions......
I have noticed this myself. They seem more down to earth in regard to customer relation than a few other companies I have dealt with.
I am sold on them for sure.
Tags
sct410, sct410.3, short course, short course 4x4, tekno
