    Hide Wikipost
Old 10-10-2017, 01:54 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC SCT410.3 Thread
Last edit by: DirkW
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8702 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree87Likes
Old 09-27-2015, 07:24 AM   #2296
Dan.J's Avatar
Trader Rating: 21 (100%+)
Originally Posted by Barillms View Post
Should be? LMAO There's no rules that say what oil to run with what springs?? Wow. You run whatever works best for you! Hilarious
Lowes was just trying to help you Mr. AVC racer, what are u 12? You sure seem like a goof.
Back on the 410.3, wheels wise I really like the DE speedline plus with 0 offset, awesome wheels that fit and hold up great. Everyone is right that no one setup is going to fit everyone's style/track, sometimes they will get you close with minor changes though. I try to listen and learn from the guys on here and at the track that know what there talking about and I also try to learn things on my own......the tuning and learning setups is another fun part of the hobby to me.
Tekno EB48.3/Tekno EB48SL/Tekno SCT410.3
Dan.J is offline   Reply With Quote
Old 09-27-2015, 10:17 AM   #2297
Lowe's48's Avatar
I agree with you. The zero offset DE speedline are my favorite as well due to the fact that they are the stiffest and more consistent than other brands.I found in many tests that your set ups will have to be reconsider if you switch wheels or even tires/foam.
Tekno Sct410.3-VRP,HW120 SCT-PRO,Pro4-4300kv,Hitec,LRP 8000/2s
Tekno SL.3-VRP,HW120 SCT-PRO,T8i-1950,Hitec,LRP 5000 4s
Weapon of choice : Airtronics M12
Home track : Coyote Hobbies,Ca
Lowe's48 is offline   Reply With Quote
Old 09-27-2015, 12:25 PM   #2298
Default Wheels and Tires
Gentlemen, appreciate the advice. My first SCTE wheels were 0 offset and rubbed the inside A-arm at full turn. My second set of DE's (Trinidads) are +3mm offset and don't rub the A-arm --but they seem really tight relative to the CVA assembly (I can only get a single sheet of paper through the gap between the set screw on the arm and the inside of the wheel.)
So, I'll try the J-Concept Hazard SCTE wheel with a Proline Trencher for our carpet races -- will a 0 offset fit without rubbing the A-arm at full turn? ROAR rules doen't apply to the racing we do.
Thanks,
Steve
cubewarrior is offline   Reply With Quote
Old 09-27-2015, 01:50 PM   #2299
rcgod's Avatar
Trader Rating: 27 (100%+)
If you guys want to run the wider offset wheels and keep it within the body width you can always run the front and rear pills on the inner locations. Don't know what effect it will have on the handling, narrow pivot and wider offset, but it's something to look at. It won't fully offset the different wheels if they are 3mm per side though. I think the narrow pivot will change 1.5mm per side.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 09-27-2015, 03:58 PM   #2300
lowspark's Avatar
First race today with the new set-up... WINNER WINNER WINNER !!!
Old Guys Rule !!!! LOL
Ran my fastest laps today, picked one lap in the 10 min main (won't comment on 10 second turn-marshal fiasco...).
There is a very fine line between "hobby" and "mental illness".
Tekno SCT410.3 / Tekin RX8 Gen3 / Tekin Pro-4 HD 4300 / Savox 1268 servo / Spectrum DX5R
lowspark is online now   Reply With Quote
Old 09-27-2015, 04:21 PM   #2301
Trader Rating: 65 (100%+)
I'm considering picking one of these bad boys up. I'm wondering if there are any must upgrades? Ive heard to get the carbon towers and aluminum suspension holders, those are a must?
nrm1977 is offline   Reply With Quote
Old 09-27-2015, 04:35 PM   #2302
Dan.J's Avatar
Carbon towers are nice but not a "must" in my opinion, I haven't hurt a stock tower yet BUT I'm sure it can and does happen. The alum blocks are nice, I built my kits with alum A and D blocks and recently put in the alum C block to get a little less antisquat if needed. Alum servo horn and upgrade the wheel hex's is a good idea and I personally run all the CNC shock parts as I feel its money well spent. Truck is solid and performs VERY well.
Old 09-27-2015, 05:54 PM   #2303
Lowe's48's Avatar
I would say aluminum A block,servo horn that's all then build it and have fun
Old 09-27-2015, 07:48 PM   #2304
Barillms's Avatar
That's from my experience of all the testing I have done. Just trying to help that's all.
if you have to run rear oil thicker than the front to make your car drive half way decent then your set ups are off. Just sayin. .....
But hey....do what you want!! Lol
My set up is way off eh? I got 3rd today out of a stacked field of 17 CORR Mod trucks.... all fast Teknos and 2 Losi. But 40/45 is too heavy to run with Green/Yellow springs right?
RC Juice
Dialed RC Hobbies
HobbyStar
Savox Servos
HRP - Hobby & Recreation Products
Barillms is offline   Reply With Quote
Old 09-27-2015, 09:19 PM   #2305
Lowe's48's Avatar
[QUOTE=Barillms;14200413]My set up is way off eh? I got 3rd today out of a stacked field of 17 CORR Mod trucks.... all fast Teknos and 2 Losi. But 40/45 is too heavy to run with Green/Yellow springs right?[/QUOTE)]
Congrats!! You're my hero!!!
Old 09-28-2015, 01:45 AM   #2306
Trader Rating: 23 (100%+)
M2C adaptors and Buggy wheels FTW ☺
hawks is offline   Reply With Quote
Old 09-28-2015, 01:50 AM   #2307
Josh L's Avatar
Pretty cool man! I am thinking about getting the adapters myself. Would like to know how the ARRMA Senton wheels fit. I think they are really nice looking, especially with some trick wheel nuts
DarkStar Senton Wheels
Josh L is offline   Reply With Quote
Old 09-28-2015, 03:15 AM   #2308
Wheel ARRMA Senton fit! I use the wheel on my Durango and Tekno with 17mm adapters!
mitrich is offline   Reply With Quote
Old 09-28-2015, 03:30 AM   #2309
Josh L's Avatar
Wurd. I will have to pick a setup then.
How where they in quality in your opinion?
Old 09-28-2015, 05:25 AM   #2310
My English is very bad (((
I can understand not all! (((
I'm running wheels DE 17mm and Teкno plastic adapter
DE Racing "Trinidad" SC
very good wheels
Tags
sct410, sct410.3, short course, short course 4x4, tekno
