    Hide Wikipost
Old 10-10-2017, 01:54 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC SCT410.3 Thread
Last edit by: DirkW
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8702 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree86Likes
Old 09-25-2015, 11:07 PM   #2281
Barillms's Avatar
I was running softer set up all summer, but finally realized something recently now that I've gotten quite a bit faster, and I'm pushing the truck much harder now. If you try to drive a soft Suspension very aggressively, it seems to not work well. The harder you start pushing, its helped me to start going heavier on both my springs and oils. The truck seems to handle aggressive driving much better, it handles hard landings better, resists bottoming better and I haven't noticed any loss in traction or steering. I've got my pills dialed and its on rails... So I really don't want to fool around with them anymore. I'm just continually experimenting with oil weights, and springs.
I also added a Tekin 4600kv Pro4 today and I'm hoping i can make up some time with the new motor. I tested it outside this evening, its very smooth and very fast for a 540! I've got a 15t on it now, with the cooler weather now, I might be able to bump up to a 16t for the Tekno NE Shootout race at LCRC in a week.
RC Juice
Dialed RC Hobbies
HobbyStar
Savox Servos
HRP - Hobby & Recreation Products
Barillms is offline   Reply With Quote
Old 09-26-2015, 02:20 AM   #2282
Josh L's Avatar
Your prolly going to love the power band of the higher KV.
I love my Hobbywing 4700 in my SCTE 2.0.
I run it with a 15,16,17t on 40spur, 1 on timing and 1 on punch.
It's really smooth through the band. If I run on a real loose track, the taller pinion seems to smooth out the initial traction hook, without needing to dial a bunch of expo in there.
And on the straits, no one can catch me.
Because of the higher weight of the tekno however, I am considering the 4500 SMC. But I want to see what new motors hobbywing is releasing for their new XR8 ESC. I feel like the new coast feature is going to be a hit for the SC guys especially, due to the nose dive issues many seem to be having.
Josh L is offline   Reply With Quote
Old 09-26-2015, 06:44 AM   #2283
Dan.J's Avatar
Trader Rating: 21 (100%+)
Coast feature on the Xr8 isn't really working right at the moment for alot of us just FYI. I am curious about the new Hobbywing motors coming too but I believe they are only 1/8 motors. The Pro4 4600 is a great motor but not really comparable to your Hobbywing 4700, the Hobbywing is a bunch more motor IMO.
Tekno EB48.3/Tekno EB48SL/Tekno SCT410.3
Dan.J is offline   Reply With Quote
Old 09-26-2015, 07:54 AM   #2284
Josh L's Avatar
Yeah that is what I heard about the coast deal to, but I figured that the motor release might clear up that feature since they are supposed to work together and all.
But yeah your right, I didn't think about the fact they may just release 550 cans... Doh!
Hopefully there will be a firmware revision that will come soon to correct some UI issues in regard to other motors.
I really liked the fact that the new ESC finally stepped into the modern era with the upgraded BEC voltage increase, considering most are running HV servos these days.
That feature has been the Achilles heel on the SCT-Pro I have now. My Futaba 9352 kills the puny 6v/3a BEC and will get mushy to the point it struggles to hold half turn radius by 2/3 pack drain. Had no choice but to use an external unit.
And I haven't personally tried a tekin motor, so I have to take your word on that one. The tekin stuff seems nice enough, but I have noticed that my HW set takes no prisoners on the straits and can run anyone down with ease around my area. But I figured that was more due to the fact I have a bad case of the lead finger!
Old 09-26-2015, 12:54 PM   #2285
justpoet's Avatar
Trader Rating: 16 (100%+)
Most of us had that Pro4 4600 motor at the eNats there this summer and still ran 16t. Go for it.
"We do not act rightly because we have virtue or excellence, but we rather have those because we have acted rightly. We are what we repeatedly do. Excellence, then, is not an act but a habit." -Aristotle
My wallet supports: TeknoRC.com, NorCalHobbies.com, SMC, Sanwa, and several tire/servo companies.
justpoet is offline   Reply With Quote
Old 09-26-2015, 05:38 PM   #2286
Barillms's Avatar
I finished rebuilding my shocks last night, and I ended up going with 40 front, 45 (Losi) rear with Green/Yellow. It may be too heavy, but I figure it would be worth a shot.... We'll find out in the morning! I love race day
RC Juice
Dialed RC Hobbies
HobbyStar
Savox Servos
Old 09-26-2015, 06:41 PM   #2287
Default Tires/Wheels
Hi,
I'm brand spanking new to RC cars, but have been flying RC helis for years.
My new SCT410.3 build is running great, but I'm struggling with wheels/tires.
After reading through this site, I ordered DE Racing Trinidad SC Wheels with +3mm offset (P/N DER-SCT-AWB (SC10 4x4)). I had to drill out the center hole for it to clear the axle stub on the Tekno, and there is a papers' width of clearance between the arms/CVA and the wheel. Can someone give me the correct part-number for the +3mm DE Racing wheel?
Also, what's a good tire to run high traction carpet?
Thanks,
Steve
cubewarrior is offline   Reply With Quote
Old 09-26-2015, 07:15 PM   #2288
Lowe's48's Avatar
With those springs you should be running 37.5 fr/32.5rr
Have fun
Tekno Sct410.3-VRP,HW120 SCT-PRO,Pro4-4300kv,Hitec,LRP 8000/2s
Tekno SL.3-VRP,HW120 SCT-PRO,T8i-1950,Hitec,LRP 5000 4s
Weapon of choice : Airtronics M12
Home track : Coyote Hobbies,Ca
Lowe's48 is offline   Reply With Quote
Old 09-26-2015, 07:49 PM   #2289
Josh L's Avatar
Originally Posted by cubewarrior View Post
Hi,
Thanks,
Steve
I hear that the proline pin-point tires are a good choice for carpet. Also have heard of plently of people that claim the badlands motocross inspired tires work really well contrary to what you'd think by looking at them.
And I don't understand why you are wanting +3 offsets to begin with. The tekno was built to run 0 offset like the SC10 4x4 and Losi SCTE.
Here is the wheel chart from this thread's first post, showing what fits or may need to be slightly modified to work
Old 09-26-2015, 09:17 PM   #2290
Barillms's Avatar
The DE Speedline +3 are the best +3 wheels if you're looking for a bit of added width. They do not rub at all.
The DE +3 Borrego wheels work well also, but they have larger inner ribs that rub the Rear A arm when the wheel flexs. The rubbing eventually wears a flat spot on the end of the Arm.
JConcepts Hazard +3 wheels also will work.
The +3 width isny per wheel. It's 1.5mm per wheel extra width designed to make the SC10 4x4 wider. When using them on the Tekno, they make the truck a few millimeters wider than when using the SCTE wheels that are recommend. I feel the added width helps alot with stability, less traction rolls and you can drive harder. But they are not ROAR legal. It's hard to pass ROAR tech inspection with SCTE wheels, because the rear toe and camber can easily put you too wide. They're rules suck.
RC Juice
Dialed RC Hobbies
HobbyStar
Savox Servos
Old 09-26-2015, 09:21 PM   #2291
Barillms's Avatar
Have fun
Should be? LMAO There's no rules that say what oil to run with what springs?? Wow. You run whatever works best for you! Hilarious
RC Juice
Dialed RC Hobbies
HobbyStar
Savox Servos
Old 09-26-2015, 09:40 PM   #2292
Josh L's Avatar
Interesting info. I am new to the tekno so far so I haven't personally tried it with this particular truck yet. And yes I figured it would help with stability and knew it would throw you out of ROAR spec, but more of concern for me is excessive body rub that I figured likely with going wider. I tried the wider wheel thing on my SCTE with a proline 66 ford shell, and while it didn't look like much difference bare chassis, the body was getting rubbed raw. So bad I had no choice but to go back to 0's or cut away a load of lexan.
All aside, ROAR don't hold much ground around here on the East Coast. Almost no one actually holds their sanctions. They tried at first, but the hassle was greater than the gain and ended up just going outlaw that allowed most things passable, with the only rules really being your body needs to cover most of your wheels and 2s batteries are the max allowed.
Old 09-26-2015, 09:56 PM   #2293
Josh L's Avatar
Just looked those wheels up and according to A-main, they do increase your width 3mm per side. Have a look> [Trinidad +3 wheels
If that is the case, I don't understand how you guys are getting proper wheel clearance with 6 extra mm over all?
Old 09-26-2015, 10:00 PM   #2294
Lowe's48's Avatar
That's from my experience of all the testing I have done. Just trying to help that's all.
if you have to run rear oil thicker than the front to make your car drive half way decent then your set ups are off. Just sayin. .....
But hey....do what you want!! Lol
Old 09-26-2015, 10:46 PM   #2295
Josh L's Avatar
So the tire clearance thing and the fact it has been raining nonstop for the last 3 days has inspired me to do a little homework measuring a few things.
What I found was with the SCTE body and wheels with slim sidewall proline tires, I am just making clearance at 1.5mm. Luckily I have a low roll center/camber gain that exponentially retracts the top of the tire as it is compressed to follow the inner body line flow, but only have 1.5 deg of static camber dialed in. With the ballooned out sidewall of the panther boa's I typically run, I am not even sure they would clear completely as is with the 0 offset SCTE wheel under these settings.
What this tells me is, I would have to run atleast a minimum and most likely more than 3 deg. camber with the same low roll center in order to make clearance with many of the tires I run.
I can certainly see how the +3mm wheel would help around the corners with side roll traction increase due to the forced - camber I'd have to run, but it would be at a cost of losing straight line tread foot-print for forward bite at the higher deg of camber I wouldn't normally run in order to make body clearance.
With that being said, I think I'll stay with the 0 offset that gives me more room for play.
Tags
sct410, sct410.3, short course, short course 4x4, tekno
