    Hide Wikipost
Old 10-10-2017, 01:54 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC SCT410.3 Thread
Last edit by: DirkW
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8702 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree83Likes
Old 09-11-2015, 05:18 AM   #2176
Barillms's Avatar
Originally Posted by Monkey#39 View Post
trying to figure out the .3 specific parts? arms? are the shock towers different ?
There's an entire list in the beginning of this thread.
RC Juice
Dialed RC Hobbies
HobbyStar
Savox Servos
HRP - Hobby & Recreation Products
Barillms is offline   Reply With Quote
Old 09-11-2015, 05:20 AM   #2177
Barillms's Avatar
Originally Posted by Dan.J View Post
I don't even bother with this site on my phone much as the redirects kicking me off the site piss me off in the worst way Very frustrating when you are trying to do something on the site from your mobile and it takes 5 attempts to do a single thing
Go "Settings" then to "Internet" > "Advanced" > "Content Settings" then check the "Block Pop Ups" box. C'mon guys lol
RC Juice
Dialed RC Hobbies
HobbyStar
Savox Servos
Old 09-11-2015, 05:51 AM   #2178
Already have this checked. Still get the redirects. Sometimes, the redirects just keep firing...can't even browse the forums. Oh well. I was just wondering.
qstorm777 is offline   Reply With Quote
Old 09-11-2015, 07:47 AM   #2179
Hoese37's Avatar
Originally Posted by qstorm777 View Post
Off subject, but very irritating, anybody know how i keep all these ads etc. from popping up while in the forums here? I'm using my phone 99% of the time.
All you have to do is go to your settings on your phone, and click "Block pop ups".
I am experiencing the same thing. Click a link and it loads a banner ad on the top and that's it. Its not a pop up, but a redirect. Hitting the back button goes to the page you try to access. Only happens when theres an American Express ad tho.
Tekno R/C
FTR 510 Raceway
Team FTR
REX Engines USA
RW Mods
Hoese37 is offline   Reply With Quote
Old 09-11-2015, 08:03 AM   #2180
c'mon guys, this thread is for the sct410.3!
Sofa King Racing
Sofa King is offline   Reply With Quote
Old 09-11-2015, 09:24 AM   #2181
+100%
mikeinsocal is offline   Reply With Quote
Old 09-11-2015, 06:06 PM   #2182
Barillms's Avatar
I have no ads or pop ups whatsoever. Don't use the mobile version. Scroll to the very bottom and click" View Full Site" and bookmark it.
RC Juice
Dialed RC Hobbies
HobbyStar
Savox Servos
Old 09-12-2015, 09:12 AM   #2183
Default Shock Towers
Anybody tried the m2cracing shock towers?
Old 09-12-2015, 10:54 AM   #2184
AccessRacer's Avatar
Trader Rating: 20 (100%+)
Originally Posted by MitchCraft View Post
I have been having trouble with my 3656 4700 and sct pro combo in my new 410.3. Esc cuts out after a few mins, restarts and runs for 30 seconds, then cuts out again. Tried all the typical troubleshooting below, conclusion is that the esc is overloaded somehow (with help from hobbywing tech support). I suspect I could have a weak esc, maybe components out of spec. I know others have tried this combo on this truck. If it is working well, what is your setup?
Tried:
Re-calibrated radio
LVC off
Multiple different batteries of different brands (high quality, high C and capacity that work fine in other vehicle)
Updated firmware
Unplugged sensor wire
Different radio system (completely different brand)
Put radio/steering servo direct to battery
Checked all connections
14t and 16t pinion
Hard wired switch
Confirmed no binding in drivetrain
Punch set to min, no drag brake, no timing
Temps all ok, except caps on esc get hot with 16t pinion.
Side note: tech support (Angelo) has been extremely fast responding, and great support in the tech support thread here on rctech (Slotmachine, lewis110).
Mine is doing the same thing with the SMC 4500 motor, did you get anything figured out?
AccessRacer is online now   Reply With Quote
Old 09-12-2015, 11:20 AM   #2185
Dan.J's Avatar
Trader Rating: 21 (100%+)
I haven't jacked up a tower yet so the stockers are holding up fine for me, If I do bend one I may try the M2c towers though as they should be even tougher yet. The carbon ones from Tekno while nice are just too much coin IMO for what they are.
Tekno EB48.3/Tekno EB48SL/Tekno SCT410.3
Dan.J is offline   Reply With Quote
Old 09-12-2015, 02:31 PM   #2186
Lol...i jacked up two of the rear ones. I went to the carbon fiber and they have actually work real good. However, I'm still a little leary of carbon fiber and was looking for some tough aluminum towers.
Old 09-12-2015, 04:50 PM   #2187
I can't find the sct410.3 to eb48.3SL conversion parts list. Does anyone have a link to it?
losi b is offline   Reply With Quote
Old 09-12-2015, 04:56 PM   #2188
rcgod's Avatar
Trader Rating: 27 (100%+)
http://www.stormerhobbies.com/cgi-bi....pl?pn=TKR5003
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 09-12-2015, 05:50 PM   #2189
Barillms's Avatar
I've had my HW SCT Pro ESC for about 3 months, do I need to update the firmware?
RC Juice
Dialed RC Hobbies
HobbyStar
Savox Servos
Old 09-12-2015, 06:38 PM   #2190
Raced some indoor with my 410.3 and this truck is amazing. I'm not, but the truck is. Let some other drivers drive it and they were extremely impressed with the handling. Very happy with this truck.
Riflebuilder is offline   Reply With Quote
Tags
sct410, sct410.3, short course, short course 4x4, tekno
