    Hide Wikipost
Old 10-10-2017, 01:54 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC SCT410.3 Thread
Last edit by: DirkW
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8702 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree87Likes
Old 09-08-2015, 05:55 PM   #2146
Originally Posted by TRoy9696 View Post
Im about to make my second order to complete my 410.3, is there any spare parts or screws that i should purchase. I dont think my local track stocks much tekno stuff.
check your local hardware store for screws. way cheaper than what you will pay for at hobby prices
Tekno eb48.2
Tekno sct410.3
one8updragracer is offline   Reply With Quote
Old 09-08-2015, 05:58 PM   #2147
Dan.J's Avatar
Trader Rating: 21 (100%+)
Truck is a tank so not much needed really. Some guys bend shock towers ( I haven't) I personally have enough spares to build another truck but thats because IF I do need something I like to have it with me. With that said I ran it for all of our summer series plus quite a few practice days and didn't get to use any parts Truck is amazingly durable.
Tekno EB48.3/Tekno EB48SL/Tekno SCT410.3
Dan.J is offline   Reply With Quote
Old 09-08-2015, 06:01 PM   #2148
Backyard RC's Avatar
I have the Hobbywing 3656/4700kv set up and it hasn't given me any problems. (knock on wood) I don't have too many packs through it yet.
Troy9696: The only thing I changed on my build was a round head screw on the steering knuckles so the wheels wouldn't rub. Different shock pistons, Spring strengths and fluid weights are a good thing to have on hand.
Here's my 410.3 getting dusty.
+ YouTube Video
Backyard RC is offline   Reply With Quote
Old 09-08-2015, 06:04 PM   #2149
Dan.J's Avatar
Originally Posted by Ruffdog1 View Post
How often do you guys change your diff oil? I think Ryan Lutz changes his every hour of driving. Is it necessary to change it that often? What do you guys do? Thanks!!
I go thru mine every 4 race days or so but clean after every race and check everything over to make sure its all smooth and right. Sometimes I go longer and sometimes I change early trying different weights, of course I'm not Lutz though
Old 09-08-2015, 06:14 PM   #2150
Shock oil ill buy locally, what are common springs/pistons you guys swap out, i think i remember reading something about green in the rear.
Thanks for the help so far guys
TRoy9696 is offline   Reply With Quote
Old 09-09-2015, 07:41 AM   #2151
rjohn929's Avatar
You can also try these guys. Boltdepot.com. I buy most of my stuff here.
SCT410.3, SCT410, ET48, SCTE 1.0, SC10 4x4, SC10, B44.1, B44.2, Yeti, Yeti XL, Wraith, SCX10 JK, Gold pan/repro, Worlds Car/repro, Rival, Emaxx, Tmaxx, assorted Ofna's, 6 Big Bears, MERV, 3DR Solo, DMG DRIII, Vanquish, Avante, mixed bag of crawlers/scalers and the list goes on and on and..........
rjohn929 is offline   Reply With Quote
Old 09-09-2015, 04:58 PM   #2152
just ordered this truck. can't wait to get everything in the mail and get started!
Tekno eb48.2
Tekno sct410.3
Old 09-09-2015, 05:11 PM   #2153
TKR5161 - Aluminum "A" block... the plastic one seems to have a breaking point where one of the screws mounts into it. Mine broke with a fairly timid ht on some piping, but it just happened to catch the tire just right so it broke the A block in two.
Tekno EB48.3, EB48SL, and SCT410.3
Team Associated B5M Lite
HoldDaMayo is offline   Reply With Quote
Old 09-09-2015, 05:18 PM   #2154
Trader Rating: 23 (100%+)
New war paint for my 410.3. Thanks to Pistol Designs (Australia)
I still have to cut out the body vents.
hawks is offline   Reply With Quote
Old 09-09-2015, 05:23 PM   #2155
Body looks great, I would do something like that if I was not crashing so much.
Riflebuilder is offline   Reply With Quote
Old 09-09-2015, 05:39 PM   #2156
Ok, so I finally finish my kit this afternoon after work, put a battery in and roll it forward and back to set the sub trim on my remote to straighten the servo/steering. Then I roll it round the living room (slick tile, large room) and the next thing I notice is the rear wheels aren't really doing anything, upon closer look the little dog bone is laying on the chassis. Apparently the drive cup came apart, like broke a section off. I have a photo of it but I need to figure all that out from my iPad....
Anyway anyone else had this happen??? I could somwhat understand it if it was on concrete and I was trying to push it against a wall or something but on slick tile and two quick blips of the throttle would not be unreasonable I would think.
Any thoughts? I need to find and source a set before the weekend.
Rob4607 is offline   Reply With Quote
Old 09-09-2015, 05:54 PM   #2157
nmdesertracer's Avatar
Trader Rating: 58 (100%+)
Nice!
Trailer Park Boys Racing!
nmdesertracer is offline   Reply With Quote
Old 09-09-2015, 07:31 PM   #2158
Hoese37's Avatar
Theres only really one part Ive seen break more than once, and that's the front steering spindle. I usually just keep a full set of arms, hubs and spindles on hand just in case. Also a good idea to get the Alum A block.
I usually do it every few races. Not really on a tight maintenance schedule.
Tekno R/C
FTR 510 Raceway
Team FTR
REX Engines USA
RW Mods
Hoese37 is offline   Reply With Quote
Old 09-09-2015, 07:44 PM   #2159
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
Hoese is pretty meticulous with his rigs. If he doesn't do it regularly it isn't hugely important. Dude cleans his sealed bearings on a regular basis.
Our local area is completely over-run with Teknos and I can not recall actually seeing a part break.
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 09-09-2015, 08:36 PM   #2160
Barillms's Avatar
JConcepts Illuzion SCT High Flow.... Great body. Loved mine. That paint job is very unique and looks killer. Very nice work. Would look badass with the number plates bolted on, painted that same blue with white & red outline Numbers ����
RC Juice
Dialed RC Hobbies
HobbyStar
Savox Servos
HRP - Hobby & Recreation Products
Barillms is offline   Reply With Quote
Tags
sct410, sct410.3, short course, short course 4x4, tekno
