    Hide Wikipost
Old 10-10-2017, 01:54 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC SCT410.3 Thread
Last edit by: DirkW
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8702 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree87Likes
Old 04-07-2015, 11:56 PM   #196
Jpm1's Avatar
Originally Posted by Monkey#39 View Post
trying to figure out the .3 specific parts? arms? are the shock towers different ?
Chassis
TKR5016B Gearbox (rear, angled)
TKR5049A Pivot Balls (6.8mm, no flng, sway bar, shck ends, almnm, 4pcs) TKR5052A Pivot Balls (6.8mm, inside camber, steering links, aluminum, 4pcs) TKR5053A Pivot Balls (6.8mm, flanged, outside camber, aluminum, 4pcs)
TKR5058A Pivot Balls (5.8mm, no flange, brake/steering link, aluminum, 4pcs) TKR5079A Stabilizer Balls (6.8mm, sway bars, aluminum, 4pcs)
TKR5165 * V2 Hinge Pin Inserts, Wheelbase Shims (EB/NB/ET/NT/SCT)
TKR5188 * Rod Ends (6.8mm, M4 thread, SCT/SL, 8pcs)
TKR5212 LCG Motor Mount Insert (aluminum, gun metal ano)
TKR5260 * CNC Split Cntr Diff Mount (mtr mnt only, 7075, gun metal ano, EB/ET/SCT) TKR5263 * Split Cntr Diff Mount (composite, requires TKR5260, EB/ET/SCT/SL) TKR5288 Chassis (7075, black anodized, lightened)
TKR5491 * Sway Bar (2.4mm, rear)
TKR5515 * Suspension Arms (rear, SCT.3/SL)
TKR5516 * Suspension Arms (front, SCT.3/SL)
TKR5518B Front Bumper Set (SCT410)
TKR5541B * Spindles (6x13x5mm outer bearing, L/R, SCT410/EB48SL)
TKR5545 * Rear Hubs (L/R, CV or uni, SCT.3/SL)
TKR5548 Decal Sheet (SCT410.3)
TKR5554A Spindle Bushings (SCT410, 4pcs, aluminum, hard ano)
TKR5555A Arm Bushings (SCT410, 4pcs, aluminum, hard ano)
TKR5570B Stub Axles (SCT410, hardened steel, 2pcs)
TKR5571M * Wheel Hexes (steel w/ set screw, lightened, 12mm, SCT410/SL) TKR5575X Diff Coupler (SCT410, f/r, hardened steel, lightened)
TKR5579 * Tapered Driveshaft (SCT/EB48SL, center, front, 7075 aluminum, black ano) TKR5581 * Shock Tower (front, 7075, black ano, SCT.3/SL)
TKR5584 * Shock Tower (rear, 7075, black ano, SCT.3/SL)
TKR5730 * V2 Adj. Hinge Pin Brace Set (composite, EB/NB/ET/NT/SCT)
Diff
TKR5149X Differential Cross Pins (composite, 3pcs) TKR5614X Differential Outdrives (SCT410, f/c/r, lightened)
Shocks
TKR6140 * Locking Shock Rod End and Spring Perch Set (EB/NB/ET/NT/SCT) TKR6143 * Shock Boots (medium length, front, EB/NB/SCT, 2pcs)
TKR6144 * Shock Boots (long length, rear EB/NB/SCT, front ET/NT, 2pcs)
Hardware
TKR1215 * M5 Locknuts (aluminum, flanged, serrated, black, 4pcs) TKR1238 * Droop Adjustment Screws (M4x10mm, 8pcs)
TKR1605 * M3x10mm Set Screws (black, 10pcs)
TKR1609 * M3x3mm Set Screws (black, 10pcs)
TKRBB05134 Ball Bearing (5x13x4, 4pcs) TKRBB06135 Ball Bearing (6x13x5, 4pcs)
Cheers
...........Coast2coastRC ............. http://www.coast2coastrc.com.au/
Australian Importer for SMC Products
Australian Distributor for TeknoRC-LeadfingerRC-SnowsDesigns(FTW)-PT Racing Oils-TritonRC
Gceorrccc founding member.(Gceorrccc.com)
Jpm1 is offline   Reply With Quote
Old 04-08-2015, 08:32 AM   #197
Trader Rating: 19 (100%+)
does anyone know when these are going to start shipping, I can't wait to get my build on
TEKNO SCT410.3; Hobbywing Sct-pro; Hobbywing 3656 4000kv; Protek 130S; SPC 70C 7200mAh 2s
TEKNO EB48.3; Hobbywing Xerun 150a; SMC 1900kv; Savox 2274SG; ECO Power 35c 4100mAh 4s
Associated B5R; Trackstar 120a turbo; Trackstar 8.5t; Solar D771; Reedy 65C 5800mAh 2s square
kyleman7 is offline   Reply With Quote
Old 04-08-2015, 08:39 AM   #198
I might have missed this somewhere but here goes what size are the turnbuckles for the new truck? I have heard the same and that only 4mm rods on all 6? Help please thanks
ben1692 is offline   Reply With Quote
Old 04-08-2015, 08:40 AM   #199
Now!!!
Pete @ fiercercsolutions.com has first shipment on the way now, tracking says they should be at his place Monday. Still 3 unclaimed, might want to get in on those 3. (Mines one of the claimed ones.)
The off-road Tekno 3some-> EB48.4 - ET48.3 - SCT410.3 ---Soon eb410
The oval 3some -> Tekno SCT410.3 - Tekno SCT210.3 - Blitz
Sponsors: Fiercercsolutions.com, AKA, jtbearingco.com, CowRC, Walden Designs, Leadfinger Racing, And BoomRC.net
ezlight is offline   Reply With Quote
Old 04-08-2015, 01:22 PM   #200
Woo Hoo!Tekno shipped my new 410.3 today!
ba4ma is offline   Reply With Quote
Old 04-08-2015, 01:48 PM   #201
rjohn929's Avatar
Got one preordered. Think I'm going to give the LRP 10L 4700 a shot and see how it hangs with the 4300HD.
SCT410.3, SCT410, ET48, SCTE 1.0, SC10 4x4, SC10, B44.1, B44.2, Yeti, Yeti XL, Wraith, SCX10 JK, Gold pan/repro, Worlds Car/repro, Rival, Emaxx, Tmaxx, assorted Ofna's, 6 Big Bears, MERV, 3DR Solo, DMG DRIII, Vanquish, Avante, mixed bag of crawlers/scalers and the list goes on and on and..........
rjohn929 is offline   Reply With Quote
Old 04-08-2015, 01:49 PM   #202
rjohn929's Avatar
Probably. Is that a problem?
Old 04-08-2015, 03:03 PM   #203
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Mine shipped out today also, it's going to be a busy weekend.
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 04-08-2015, 04:27 PM   #204
Curious because I ordered the same Durango aluminum turnbuckles as my first sct410 now Im wondering if the new set I ordered will fit
Old 04-08-2015, 05:32 PM   #205
Nick@Jet's Avatar
Trader Rating: 17 (100%+)
Already customizing ...jeezz
Companies I think do a great job..
JetSuspension.com
TEKNO SCT410 / EB48
Team Losi Racing
Tekin
Nick@Jet is offline   Reply With Quote
Old 04-08-2015, 05:53 PM   #206
King DORK's Avatar
Trader Rating: 31 (100%+)
That LRP caught my eye as well. I'll be keeping an eye on this for your results
B5M Lite, Centro CT4.2, Tekno SCT410.3, Losi 22-4 (RC Shox-ified), Losi Comp Crawler, Losi MRC Pro Gatekeeper, Super Clodbuster
Proud father of my boys Kevin, Brandon, Dylan, and my dogs Kaelee, Bella Roo, and Wilbur. Thank you to my only sponsor, my beautiful wife!
King DORK is offline   Reply With Quote
Old 04-08-2015, 06:00 PM   #207
Ok, thoughts. I run on a small-med indoor tracks (astro & clay) And about to start the outdoor tracks when they open (hopefully soon) Here are my motor choices. Tekin Pro4 4000kv, tekin Pro4 HD 4300, & hobbywing 4700kv. I have all 3, so it's not deciding on what to buy, just what would be the better choice. I have mod1 pinions 13t-20t
I've ran the 4300HD in my last truck with 15t pinion, but have yet to try the other two.
Old 04-08-2015, 06:05 PM   #208
to those of you that are running a tekin rx8 gen 2 in your tekno,would the tekin TT3811 100mm sensor cable be long enough to reach from the esc to the motor?i will be hooking it up to a hobbywing 4700kv motor,so i want to make sure it is long enough and compatible.I also ordered a hotwire for it,will there be anything else i need to make this work?This is my first tekin esc and i just wanted to know what parts,adapters i will need to make it work?
Old 04-08-2015, 06:07 PM   #209
I was running 50mm, and it was "just" long enough, wish I had just a little more. 100mm should be perfect.
Old 04-08-2015, 06:08 PM   #210
I already ordered ceramic bearings from boca, aluminum screw kit, aluminum turnbuckles, another m2c chassis, plus all aluminum shock components and carbon fiber parts plus some more stuff I forgot
Tags
sct410, sct410.3, short course, short course 4x4, tekno
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
fircrest
