    Hide Wikipost
Old 10-10-2017, 01:54 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC SCT410.3 Thread
Last edit by: DirkW
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8702 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree83Likes
Old 08-20-2015, 06:48 AM   #1966
Dan.J's Avatar
Trader Rating: 21 (100%+)
I built mine with 1 shim on gear side as well, ran some packs thru it and rebuilt using 2 shims on gear side because it had broken in and needed them. Run it and adjust it after everything is broken in.
Built my shocks emulsion last night and put back together, still can't get lower than 28mm in front so bladder to emulsion build did nothing ride height wise like some thought possible. Just can't get it low with the Tekno springs and have no idea why some can and some cant.
Tekno EB48.3/Tekno EB48SL/Tekno SCT410.3
Dan.J is offline   Reply With Quote
Old 08-20-2015, 09:05 AM   #1967
Okay, I'll have to try notching my case, right now I have my front diff with one shim on the non-gear side. With it on the gear side it feels notchy.
TRoy9696 is offline   Reply With Quote
Old 08-20-2015, 11:58 AM   #1968
teknorc's Avatar
Hi guys,
http://www.teknorc.com/tekno5/wp-con...Lewis_SDRC.pdf
Here's a new setup sheet for indoor clay that should also work for various outdoor conditions (go up in ride height).
We have heard about some customers having 'nose down' issues. A lot of this is track dependent, power dependent, body dependent, etc. And of course SC trucks tend to do this naturally anyway. In any case, if you are experiencing nose-diving, one of the best changes to make is less anti-squat.
Anti-squat loads the rear suspension on power and unloads off power. This 'throws' the vehicle all over the place. Through the years we have found that all of our vehicles do not respond well to anti-squat since our weight distribution is further forward than just about any other vehicle. Anti-squat is kind of a band-aid setting IMO and is better used on vehicles with more weight over the rear wheels.
Less anti-squat will allow you to enter corners at a higher speed without the rear end coming around as much when you let off the throttle. Additionally, it helps the trajectory immensely by not unloading the rear and throwing it forward.
We've seen a lot of discussion about springs, oil, etc. This matters too, but it won't help if you are running a lot of anti-squat. The stock setup has 3 degrees of anti-squat and works on smoother tracks with tighter turns. I have included a link to a new setup sheet that I encourage you to try if you are still having issues.
Other suspension things to consider if you are having nose down issues:
stiffer front spring
lighter rear spring (assuming you aren't chassis slapping)
thicker front oil
thinner rear oil (assuming you aren't chassis slapping)
less rear droop
Try out less anti-squat - Post your results here!
Tekno RC
www.teknorc.com
teknorc is offline   Reply With Quote
Old 08-20-2015, 12:18 PM   #1969
Dan.J's Avatar
Thanks will give it a try although mine is really good as long as I'm running other companies springs on front. Will the different shock locations on tower on this setup help me get the ride height down in front? I'm at 28mm in front with Tekno pinks so a long way from the 22mm that setup calls for, suspension is free and shocks are built right and springs have many packs on them and shock ends are all the way on till ball binds then back off a touch . Love this truck and my SL buggy but spring issues on both.
Old 08-20-2015, 12:29 PM   #1970
Josh L's Avatar
Originally Posted by teknorc View Post
one of the best changes to make is less anti-squat.....
I am so glad to see you post this. I own an scte 2.0 and race on loose tracks mostly. When I built my truck I immediately reduced anti squat to half and moved my esc rearward to get a further back CG. My truck never has a nose dive issue and can actually "nose high" easily if the throttle isn't backed off of oncen airborne. I credit that mostly to a lower anti squat.
I have been trying to tell people this for a while now, but since I am not a pro, few listen and mostly argue the opposite.
Soon as my girlfriend's tekno comes in that will be one of the first things I suggest she do from initial build.
Josh L is offline   Reply With Quote
Old 08-20-2015, 03:40 PM   #1971
That set-up says 0 anti squat. ! degree down on the C block and 1 degree up on the D block leaves 1 degree squat or am I confused?
Whosold is offline   Reply With Quote
Old 08-20-2015, 03:48 PM   #1972
teknorc's Avatar
That setup uses the aluminum C block (TKR5163) to achieve 0 degrees anti-squat. If you use the composite block, you will have 1 degree.
Tekno RC
www.teknorc.com
Old 08-20-2015, 05:35 PM   #1973
Got it, Thanks
Old 08-20-2015, 05:42 PM   #1974
So i built it to spec ,what do i need to do ,if u would let me no, also I'm a super newb first rc ,thanks
Aswild is offline   Reply With Quote
Old 08-20-2015, 06:07 PM   #1975
Trader Rating: 36 (100%+)
I'm in the same boat. I built my truck box stock, but it sounds like less antI squat is needed for my track. I'm a little confused on the pills, like how it equals 3 degrees of anti squat from box, and what to change to get it to 1 degree
mxturd is offline   Reply With Quote
Old 08-20-2015, 06:12 PM   #1976
Default Book
The book has the dots in the center for 3 degrees anti squat what pills do i need to use i have the ones that came with the kit?
Old 08-20-2015, 07:28 PM   #1977
jmkalt's Avatar
Wait. Composite vs aluminum blocks yield differing positions? Please explain in detail. I am installing all 4 aluminum hinge pin braces at the moment. Do they all difffer from the composite ones, and by how much?
Also, do the rear hubs themselves provide a degree of toe in as was the case in the original 410?
jmkalt is offline   Reply With Quote
Old 08-20-2015, 08:10 PM   #1978
Somehow I got myself confused to...so with the composite blocks what inserts do I want to have less anti squat? The book setup has the downward ones and I went to the center ones. Don't have the manual with me at moment to check. Thanks to everyone on this thread. I get alot of useful info from it. Love the truck.
4s losi is offline   Reply With Quote
Old 08-20-2015, 08:23 PM   #1979
rcgod's Avatar
Trader Rating: 27 (100%+)
Less anti squat means the rear arms are flatter front to back when viewed from the side of the truck. So for the minimum anti squat use the lowest front hinge pin location and the highest rear location.
From what I can tell the only aluminum block that is different than the composite is the "D" block. It is 1mm higher than the composite.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 08-20-2015, 08:59 PM   #1980
Josh L's Avatar
Hope this helps some of you beginners for a good visual reference of pro/level/ and anti-squat.
As rcgod said, you will want to drop the front of the hinge pin with the pills to reduce anit-squat to achieve a more level attitude of angle.
I don't own a tekno yet, but on my losi there are numbers printed on the pills that indicate the degree difference. But as a layman way to do things, just lower the pin end toward the front of the vehicle. By doing this however, you will be reducing forward traction from the rear tires, as you are losing torsional rise which slows the rate at which the force will be applied downward by the tires under acceleration. But you will gain more stability as the shocks can be compressed easier over the bumps, thus improving over all ride and absorption. Once you get the ride and jump handling your after, you may consider raising diff fluid weights a bit to negate the acceleration loss.
Just as anything you do, there will be trade off's that you will have to determine to be worth it over all. Don't just go out and take away all of your anti squat. There will be a fine medium that can be found with gradual increments. But you will have to run the truck each time you make a change to find out to what degree.
The best thing to do with things of this nature in general is to only take away as much as you can live with on the track you are frequenting instead of dialing everything out all the way and then coming back in.
Tags
sct410, sct410.3, short course, short course 4x4, tekno
