    Hide Wikipost
Old 10-10-2017, 01:54 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC SCT410.3 Thread
Last edit by: DirkW
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8702 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree86Likes
Old 08-13-2015, 12:18 PM   #1906
Jason Baliban's Avatar
I have a question on drilling for vented setup.
I know i have to drill the bleeder hole. What i am confused about is where to drill the vent? Does the hole go out the bleeder for emulsion or does it go straight up into the cap?
Thanks so much!
jB
High Sundry Productions
B5M | MBX-7Re | T5M | TC3 | RC10 "Graphite"
Jason Baliban is offline   Reply With Quote
Old 08-13-2015, 01:20 PM   #1907
Thanks so much!
jB
Hole goes out through where the bleed screw goes (leave screw out for vented).
Sofa King Racing
Sofa King is offline   Reply With Quote
Old 08-13-2015, 01:31 PM   #1908
I thought that made the most sense, because i suppose you could close it up if you wanted with a screw for non vented. The manual isnt super clear about it though.
Thanks!
jB
Old 08-13-2015, 05:32 PM   #1909
Does anyone have any tips on how to free up the aluminum pivot balls for the sway bar assembly? My new ones are pretty stiff.
red100076 is offline   Reply With Quote
Old 08-13-2015, 07:04 PM   #1910
Josh L's Avatar
Just do what the heli guys do and put the pivot ball In a drill chuck and blip the drill a few times while holding the ball link stationary as to spin the ball inside the end a few times. Be careful not to over do it though as it will rapidly heat and can over melt the plastic making it to loose permently. It works awesome though and it beats doing the pinch method with pliers because it perfectly seat the ball in the exact shape it needs. Just make quick fast blips, do not keep spinning it.
Here I found a video ball link sizing
Josh L is offline   Reply With Quote
Old 08-13-2015, 10:57 PM   #1911
Barillms's Avatar
Just put some oil lightly on them when you ckean/ tear down.
I use synthetic fishing reel oil.
RC Juice
Dialed RC Hobbies
HobbyStar
Savox Servos
HRP - Hobby & Recreation Products
Barillms is offline   Reply With Quote
Old 08-14-2015, 04:42 AM   #1912
Default Thanks for the spring and pinion recommendations.
I am putting the kit together now. Don't know if I'll have it ready for this weekend but I'm not going to rush it.
Rich
FunStuff is offline   Reply With Quote
Old 08-14-2015, 10:07 AM   #1913
I take it as most people are using a 17-19t pinion gear?
I will be using a turnigy 4850kv 4 pole motor with Hobbywing XERUN SCT PRO Brushless Sensored ESC 120a so I should get something similar for the pinion gear?
also, my shocks seems to be leaking oil. the threaded areas are coated with a thin layer of oil. any recommended brands/viscosity to refill it?
novaris is offline   Reply With Quote
Old 08-14-2015, 07:51 PM   #1914
Default Turnbuckles
Do the Team Durango turnbuckles have to be modified or are they a direct fit to the sct410.3?
Part# TD310215
Silvergoat06 is offline   Reply With Quote
Old 08-14-2015, 08:00 PM   #1915
rcgod's Avatar
Trader Rating: 27 (100%+)
4850kv should be in the 15 to 16 range.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 08-14-2015, 10:42 PM   #1916
thanks
what kind of motors are using the 17-18t pinions?
Old 08-14-2015, 10:49 PM   #1917
rcgod's Avatar
thanks
Pro4 4300HD and hobbywing 4000. On the 4000 I've seen guys run a 19t.
Dialed RC Hobbies
Old 08-15-2015, 12:07 AM   #1918
Barillms's Avatar
thanks
The 4000kv motors run around a 17 or 18t. I ran on big outdoor track and an 18 wasn't necessary with my old motor which was a 4150kv. I now run a 4400kv with a 15t. I temped it at 152 last race and that's with a motor fan.
RC Juice
Dialed RC Hobbies
HobbyStar
Savox Servos
Old 08-15-2015, 11:36 AM   #1919
any comments on savox 1258tg?
the lhs does not have the 1256 and says 1258 is newer and better
plus it's the only one with a decent price tag there
Old 08-15-2015, 12:34 PM   #1920
Dan.J's Avatar
Trader Rating: 21 (100%+)
Speed is fine but not really enough torque IMO. I would want 200+on the torque for this truck, the ones I run are over 400, overkill yes but..........
Tekno EB48.3/Tekno EB48SL/Tekno SCT410.3
Dan.J is offline   Reply With Quote
Tags
sct410, sct410.3, short course, short course 4x4, tekno
