    Hide Wikipost
Old 10-10-2017, 01:54 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC SCT410.3 Thread
Last edit by: DirkW
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8702 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree86Likes
Old 08-02-2015, 05:49 PM   #1786
Thank you. I just put on the pink springs today actually, and the only other thing I did not do was to screw in the rod ends all the way. I just screwed them in until they were flush with the threads.
darren509 is offline   Reply With Quote
Old 08-02-2015, 08:07 PM   #1787
JEFFs SC10's Avatar
Trader Rating: 14 (94%+)
looking to buy one, so if anybody has a lightly used one for sale let me know.
XRAY T4 17' //CRC Gen X SE- 17.5 GT//Xray X12-17' GT12//Xray X12-18' 17.5
check out the new 12th scale GT class!
https://www.facebook.com/groups/148391312353349/
JEFFs SC10 is offline   Reply With Quote
Old 08-02-2015, 10:30 PM   #1788
Barillms's Avatar
Yeah, that's correct. Stop when the last thread is not visible.
RC Juice
Dialed RC Hobbies
HobbyStar
Savox Servos
HRP - Hobby & Recreation Products
Barillms is offline   Reply With Quote
Old 08-02-2015, 10:39 PM   #1789
Barillms's Avatar
Originally Posted by theboss13 View Post
What size wheel nuts fit on this car?
The stock Aluminum wheel nuts will strip eventually. You can buy Traxxas steel 5mm wheel nuts and they're much stronger and less prone to stripping.
RC Juice
Dialed RC Hobbies
HobbyStar
Savox Servos
Old 08-02-2015, 11:25 PM   #1790
Matthew_Armeni's Avatar
Trader Rating: 31 (100%+)
If you stop when the last thread is no longer visible you should still have more shaft to thread into the shock end. Keep threading until the rod bottoms out in the end. I like to constantly move the ball around and as soon as I feel the ball get tight in the plastic I back the rod off slightly.
Tekno RC
Matthew_Armeni is offline   Reply With Quote
Old 08-02-2015, 11:59 PM   #1791
Jva
Default Springs for stock setup
I have a stock setup. I see the fronts are green. Assuming the rear are black? No color so I assume it is black.
Without making a bunch of changes, what are the best springs for the rear (with green fronts)....? Just trying to minimize nosediving. Pushing the throttle full almost full whack at the jumps is getting old. Don't have a ton of time to fine tune this, shock rebuild rtf... Just the quickest easiest spring solution to improve.
Thanks!
Jva is offline   Reply With Quote
Old 08-03-2015, 01:02 AM   #1792
HSV427's Avatar
Trader Rating: 22 (96%+)
I honestly don't get this nose down problem people are having, i also don't understand this front ride height issue people are having, i built my car completely stock, the only thing i did was build my shocks emulsion style and i run on a large 1/8 scale track with huge jumps and i run the proline flo-teck body and my .3 flys perfectly level and from day one with out bedding in my shocks i had no problem with ride height, i guess long story short is all those people having problems i suggest building your shocks emulsion style and really put some re search into the body you choose as all kits leave tekno exactly the same and the only difference is the way you build the truck and its funny how it seems only a handful off people experience the 2 problems mentioned above. Just my 2cents.
GREAT TRUCK TEKNO UNSTOPPABLE.
Serpent 988, OS speed shimo edition, Serpent 977 35th anniversary. OS speed shimo edition Serpent 977 evo2, Novarossi Mito WC35 2017, Shepherd Velox, O.S Speed r2102, Motonica p81rs2, REDS Racing M7 WCS V3.0, , CM 1/8 INFINITY O.S Speed 2103.
HSV427 is offline   Reply With Quote
Old 08-03-2015, 04:12 AM   #1793
Dan.J's Avatar
Trader Rating: 21 (100%+)
So you are running the kit setup completely stock on " large 1/8 scale tracks with huge jumps" and the truck doesn't jump nose down at times? Weird I would think kit setup would be a MILE off on a big outdoor 1/8 track . The ride height issue and the nose down issue are real and don't just effect a "handful" of people . Its a great truck and I will get it sorted and the guys from Tekno are giving suggestions to fix it which is great. By the way mine personally doesn't nose over if I hit the jumps perfect BUT if I loose my focus things can get ugly. The ride height issue is real, EVERYONE at my local track is dealing with it, some worse then others. Guys are shaving there shock collars thin and running 0 preload on shocks and STILL sitting too high up front.
Tekno EB48.3/Tekno EB48SL/Tekno SCT410.3
Dan.J is offline   Reply With Quote
Old 08-03-2015, 04:29 AM   #1794
HSV427's Avatar
I have no doubt the issues are real to some people I'm just talking about my own personal experiences, what i have noticed is that out of seven of the trucks that run at our track, only 1 person had the ride height issue and I'm not sure if its coincidence or not but he is the only one that built his shocks bladder style, as soon as he built them emulsion style he found the ride height perfect, again this is only my experience and is purely only a suggestion to people having the issues that it might be worth while checking the things i mentioned, now if you already run the flo-tek body and built your shocks emulsion and are still having the problems i have no idea what your options are except the ones listed by tekno, and again here were i race the issues people go on about are non existent hense the coment these issues only effect a small number off people.
Old 08-03-2015, 04:45 AM   #1795
Yea same issuie but trying to work it out, i went with pinks all @ ,, i did want to no if any ones rear dog bones are rubing on the bottom of the arms right by the hubs ?
Aswild is offline   Reply With Quote
Old 08-03-2015, 05:04 AM   #1796
Dan.J's Avatar
Mine are built bladder style so maybe you are on to something with the emulsion build, sucks though as I prefer the bladder set up. Thanks and I hope I didn't come off wrong too you, sometimes typing on a forum doesn't sound the same as if we were face to face.
Old 08-03-2015, 05:35 AM   #1797
I built emulsion and still have the nose down issue
theboss13 is offline   Reply With Quote
Old 08-03-2015, 05:45 AM   #1798
Dan.J's Avatar
We are more talking about the ride height issue is worse depending on how the shocks are built.
Old 08-03-2015, 07:06 AM   #1799
Default sct
hi all...... have just got my tekno sct 410.3 running and its great, i'm looking for setup help for running it on astro in the uk, have been looking on all the forums but cant seem to find anything..... any help appreciated.....
it had its first run in the sun on bumpy astro last sunday and it was grip rolling like crazy.
with the kit springs i cant get the drive shafts level the shock collars are fully wound up.
running almost stock setup at moment with below changes
diffs 7-10-3
shocks.. 350cst front 300 rear kit springs
shumacher yellow mini spikes all round
ps...sorry i posted this in the wrong thread a little earlier but im hoping this is the right one
szymanski2oo1 is offline   Reply With Quote
Old 08-03-2015, 08:07 AM   #1800
I'm running bladder shocks and green springs and I can get the stock ride heights. I would go thru the check list Matthew laid out. I'm hoping that fixes it. If not, maybe Tekno will help you out to get this fixed.
qstorm777 is offline   Reply With Quote
Tags
sct410, sct410.3, short course, short course 4x4, tekno
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Aatimm87
