    Hide Wikipost
Old 10-10-2017, 01:54 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC SCT410.3 Thread
Last edit by: DirkW
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8702 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree83Likes
Old 04-01-2015, 01:51 PM   #166
Orion_2kTC's Avatar
Personally I'm going with either the Hitec 9360 or 9370. I like newer stuff regardless of price. Plus these are designed to run @ 7.4 and have hardly any pull on your battery. I don't recall who but they did a strain test by hanging a weight on a servo horn and went full turn. An attached volt me registered barely any draw.
http://hitecrcd.com/products/servos/...-servo/product
Orion_2kTC is offline   Reply With Quote
Old 04-01-2015, 03:15 PM   #167
TheCore's Avatar
Trader Rating: 45 (100%+)
[QUOTE=wreckya;13937910Running the M2C chassis with the battery mod and don't have the nose down issue.[/QUOTE]
is this due to the battery mod chassis or have you found the magical rear end set up for your track ?
TheCore is offline   Reply With Quote
Old 04-01-2015, 03:34 PM   #168
justpoet's Avatar
Trader Rating: 16 (100%+)
I think the rear and nose diving is highly driver dependent. I had the opportunity at the dirt nitro challenge to have both Danny of Tekno and than lutz drive my truck. Danny immediately drove it and liked it as I do. Ryan had nosediving issues and wanted more cornering ability (my truck is set up more stable and less aggressive). After a couple laps Ryan still drove the heck out of my truck and was able to stop diving, but for him it required a change to using more throttle up the face of a jump. For me, I let off up the face and still don't dive. That middle where you basically stay constant is where it was a problem. Different setups and mods will change how it works for you and your driving style. For the stay the same speed folks, the battery mod is probably reasonable. My truck has ALL the weight forward though, including receiver and transponder and the back missing some plastic.
"We do not act rightly because we have virtue or excellence, but we rather have those because we have acted rightly. We are what we repeatedly do. Excellence, then, is not an act but a habit." -Aristotle
My wallet supports: TeknoRC.com, NorCalHobbies.com, SMC, Tekin, and several tire/servo companies.
justpoet is offline   Reply With Quote
Old 04-01-2015, 03:39 PM   #169
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
I have to agree. I personally have not had any nose-diving issues but I can't discount the testimony of so many others. Pretty much with any car, if I have jumping attitude issues I look at my driving and approach to the jump first.
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 04-01-2015, 03:50 PM   #170
Tech Legend
Cain's Avatar
Trader Rating: 235 (100%+)
for me it may be that since I am going between the EB48 and the ET48 now, my driving style is such with those vehicles that when I got to the SCT410, it comes up.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL | Yokomo YZ-2 DTM x 2>
Old 04-01-2015, 05:24 PM   #171
mvrk28's Avatar
Preorder: CHECK
Team Durango DESC10 - Tekin Pro 4 HD 4300, Protek, VRP, Proline, Sanwa
TLR 22t 3.0 - Tekin Gen 3 8.5t, Protek, VRP, Proline, Sanwa
VANT LIPOS
mvrk28 is offline   Reply With Quote
Old 04-02-2015, 07:28 AM   #172
Originally Posted by Hoese37 View Post
Must want it to drop trannys and break driveshafts a lot.. LOL
Love this, Your my kinda guy!!!
The off-road Tekno 3some-> EB48.4 - ET48.3 - SCT410.3 ---Soon eb410
The oval 3some -> Tekno SCT410.3 - Tekno SCT210.3 - Blitz
Sponsors: Fiercercsolutions.com, AKA, jtbearingco.com, CowRC, Walden Designs, Leadfinger Racing, And BoomRC.net
ezlight is offline   Reply With Quote
Old 04-02-2015, 10:41 AM   #173
Jordan Anderson's Avatar
I'm curious how some of the composite parts (hinge pin braces, diff cross pins, split center diff mount) will hold up. Durability and wear has been such a strong point for Tekno on their previous kits. Hopefully that's still the case here.
My 9 year old son will be the one racing it; I'm certain he'll thoroughly test the durability...
We're looking forward to getting this truck, it'll be our first Tekno!
JORDAN // EVAN
R/C GEARS , TRUKZ/KARZ , VRC PRO
Jordan Anderson is offline   Reply With Quote
Old 04-02-2015, 03:17 PM   #174
justpoet's Avatar
The only part that is newly plastic are the cross pins and front most hinge pin holder. They should both hold up well, but all can be upgraded to aluminum if by chance you break something. Expect to see all those parts on the Tekno store website shortly after the truck ships.
Old 04-02-2015, 03:27 PM   #175
platgof's Avatar
I have seen things done to a Tekno that were amazing, and it still raced. I have never seen anything in this hobby as tough, nothing.
platgof is offline   Reply With Quote
Old 04-03-2015, 05:11 PM   #176
Is there anymore news on how these trucks are doing with some of the Tekno drivers using them?Are there any setups for this truck yet?
ba4ma is offline   Reply With Quote
Old 04-04-2015, 05:07 AM   #177
Trader Rating: 32 (100%+)
http://hotlaprc.com/products.html
Does anybody if they still selling this air guard?
raved007 is offline   Reply With Quote
Old 04-04-2015, 05:36 AM   #178
jmkalt's Avatar
From my understanding, they are basically defunct, but if you place an order, your Paypal will still be charged. Stuff will never come and you will have to go through Paypal to get your money back.
jmkalt is offline   Reply With Quote
Old 04-04-2015, 06:37 AM   #179
TheCore's Avatar
this was not the case for me at all 3 months back. the order sat pending in my paypal for about 2 weeks, then was credited back to my account, no issues no hassles. i attempted to reach out to hotlaps a few times via email only to get no response.
Old 04-04-2015, 07:25 AM   #180
jmkalt's Avatar
Well, I had to call paypal to get my money credited back. In fact, Paypal called the guy from hotlaps and, according to them, actually spoke to him. If I never called, I would have been out the money with nothing to show for it.
Point still being, that orders go through and then no further response from hotlapsrc.
AVOID.
Tags
sct410, sct410.3, short course, short course 4x4, tekno
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
