    Hide Wikipost
Old 10-10-2017, 01:54 PM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC SCT410.3 Thread
Last edit by: DirkW
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8702 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree86Likes
Old 07-28-2015, 09:51 PM   #1741
GIHOSU's Avatar
My SCT410.3 plans just moved ahead substantially. I was willing to wait for new Viper stuff until I acquired a new Viper VTX8 ESC from a gracious RC Tech member. Thank you...
So now I have to buy a servo and Al horn and some hinge pin braces and of course a chassis at my LHS. I am getting beat bad enough now to make this happen in the next few weeks.
The good old dog will get upgraded with .3 arms, hubs, towers, a truggy swaybar and I will try green/black with lighter oils with my CNC F 8x1.3 & R 8x1.4s. Can you think of a better backup truck? Thanks for all the good reading so far.
Cruizin with RC's in Waldwick, NJ... check it out!
KYOSHO - RB6.6 17.5 Turf ~ RB6 17.5 ~ RB6 ~ RZ6 Turf ~ RT6 Turf ~ SC6 17.5 ~ SC6 ~ SC6 Turf ~ ST-RR Evo.2E
TEKNO - SCT-410 ~ SCT-410.3
GIHOSU is offline   Reply With Quote
Old 07-28-2015, 10:56 PM   #1742
Backyard RC's Avatar
Just finished my SCT 410.3. Fun kit to build, except for threading the links of course. I'd gladly pay extra for a pre-linked kit.
I'm running the Hobbywing SCT Pro combo 4700kv and the Turnigy 1258tg servo.
I mounted the Parma 68 Muscle Baja body (68 Camaro). Great body with a lot of detail. It amazingly fits over both the front and rear bumper.
Here's a shot of it with some Sweep GT tires.
[IMG][/IMG]
Backyard RC is offline   Reply With Quote
Old 07-29-2015, 11:26 AM   #1743
Carter Flotron's Avatar
Originally Posted by mxturd View Post
When would removing the center and rear chassis braces be effective?
Honestly there is almost never a time I would put on the rear brace. I go back and forth with keeping the center on, but having the rear off is almost always a good idea just for the grip increase
Thanks to all my sponsors for 2016!
|Pro-line Racing|Hobbywing North America|Highest Servos|Fierce RC Solutions|
Carter Flotron is offline   Reply With Quote
Old 07-29-2015, 12:42 PM   #1744
Trader Rating: 67 (100%+)
Originally Posted by Aswild View Post
Yea i am having same issuie all it does is open a blank sheet an no option i can only see the last one ?.
Yes, you must open with Adobe in order to see the info. Apple products just show a blank sheet when you open it. Get Adobe at the App Store.
"Wow he's really fast isn't he????.....Yeah but he's Stupid"
lyork is offline   Reply With Quote
Old 07-29-2015, 04:01 PM   #1745
Trader Rating: 488 (100%+)
I've been looking around for a set up before I build my new .3. Anybody have one for high traction sugared blue groove....maybe an HRH Shootout setup. I haven't found anything that is close enough. If you do, please PM me.
Now that I've discovered the ignore list I plan to use it.....17 and counting!
QDRHRSE is offline   Reply With Quote
Old 07-29-2015, 04:02 PM   #1746
[IMG][/IMG]
I like it!
Old 07-29-2015, 06:35 PM   #1747
Trader Rating: 16 (100%+)
Send a message via AIM to Fuzzchop
Default nose down problems
Originally Posted by Matthew_Armeni View Post
For the guys still having some nose down issues, can you please list the motor/pinion combo you're currently running? I think some people (not all) may simply be undergeared.
have you heard of doing battery mod to move battery back it helps alot.
Fuzzchop is offline   Reply With Quote
Old 07-29-2015, 07:37 PM   #1748
walterheard's Avatar
Trader Rating: 30 (100%+)
Anybody experiencing the front end of the truck wanting to raise under acceleration?
Walt29
walterheard is offline   Reply With Quote
Old 07-29-2015, 08:22 PM   #1749
Trader Rating: 32 (100%+)
I did mod to my battery move back it help a lot nose dive issue. Before you mod your battery put some rubber and glue it side of center differential.
Here is tekno.
raved007 is offline   Reply With Quote
Old 07-29-2015, 09:45 PM   #1750
Barillms's Avatar
Just go on the Tekno website and download a PDF set up sheet from one of the pros.
RC Juice
Dialed RC Hobbies
HobbyStar
Savox Servos
HRP - Hobby & Recreation Products
Barillms is offline   Reply With Quote
Old 07-29-2015, 09:47 PM   #1751
Barillms's Avatar
No, I wish. I don't think 4x4s do much wheelieing.
RC Juice
Dialed RC Hobbies
HobbyStar
Savox Servos
Old 07-29-2015, 09:49 PM   #1752
Barillms's Avatar
Here is tekno.
Where can I buy a carbon fiber center Diff top brace?? I keep seeing them, but don't know where to purchase one?
RC Juice
Dialed RC Hobbies
HobbyStar
Savox Servos
Old 07-30-2015, 06:28 AM   #1753
A2Racing's Avatar
That one is the sumo racing fan mount. You get purchase the mount and fan on eBay for $39.99.
A2Racing is offline   Reply With Quote
Old 07-30-2015, 01:38 PM   #1754
FRONTI3R's Avatar
Reduce your front droop to have less of that... this truck has lots of travel, that would be good for outdoor racing
Sponsors: Tekno RC, GFX Designs, RCOttawa.com/forum/
www.teknorc.com
FRONTI3R is offline   Reply With Quote
Old 07-30-2015, 05:36 PM   #1755
Get in here
http://www.sumo-racing.com/
Tags
sct410, sct410.3, short course, short course 4x4, tekno
