    Hide Wikipost
Old 07-27-2017, 06:29 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC SCT410.3 Thread
Last edit by: Bob Barry
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8072 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree70Likes
Old 07-02-2015, 12:05 PM   #1471
Originally Posted by ezlight View Post
which pro4 motor?
Short Course 4x4
Riflebuilder is offline   Reply With Quote
Old 07-02-2015, 12:50 PM   #1472
Hoese37's Avatar
Originally Posted by Riflebuilder View Post
Short Course 4x4
Think he means what kV?
Tekno R/C
FTR 510 Raceway
Team FTR
REX Engines USA
RW Mods
Hoese37 is offline   Reply With Quote
Old 07-02-2015, 01:00 PM   #1473
Short Course 4x4
Definitely meant KV.
The off-road Tekno 3some-> EB48.4 - ET48.3 - SCT410.3
The oval 3some -> Tekno SCT410.3 - Tekno SCT210.3 - Blitz
Sponsors: Fiercercsolutions.com, AKA, jtbearingco.com, CowRC, Walden Designs, Leadfinger Racing, And BoomRC.net
ezlight is offline   Reply With Quote
Old 07-02-2015, 01:05 PM   #1474
Oh, 4600
Old 07-02-2015, 01:07 PM   #1475
Hoese37's Avatar
Second best motor there is IMO.
Tekno R/C
FTR 510 Raceway
Team FTR
REX Engines USA
RW Mods
Old 07-02-2015, 01:51 PM   #1476
youwish16's Avatar
Trader Rating: 19 (100%+)
What is the first?
Allen Krier - Dialed RC Hobbies
Tekno ET48, Protek 130T, Tekin 2050kv, Tekin RX8 Gen2 ESC, James Tires
Tekno EB48.4, Protek 100T, Tekin 2050kv, Tekin RX8 Gen2 ESC, James Tires
Tekno NB48.3, Protek 100T, Protek 100SS, Werks B2, Dynamite Pipe, James Tires
youwish16 is offline   Reply With Quote
Old 07-02-2015, 04:39 PM   #1477
Trader Rating: 36 (100%+)
Originally Posted by youwish16 View Post
What is the first?
4300?
mxturd is offline   Reply With Quote
Old 07-02-2015, 06:20 PM   #1478
Originally Posted by Jvcaniggia View Post
I'm getting conflicting info regarding a 3s setup with this motor/esc combo and low pinion. Is it a consensus 3s is too much on the 4000 kv at a low 11 tooth pinion?
I'm running a tekin prohd 3000kv on 3s and love it. Im using smc 4300 battery and getting more then enough running time. I'm running a 14t pinion which is the smallest that will fit. I would stick to 3000kv or lower on 3s
Horby32 is offline   Reply With Quote
Old 07-02-2015, 06:36 PM   #1479
Dan.J's Avatar
Trader Rating: 21 (100%+)
Originally Posted by mxturd View Post
4300?
There is no BEST motor, all depends on a persons wants/needs/abilities. I run on a medium/large sized high bite indoor track most of the time and I see so MANY guys that can't even come close to handling the power they are trying to put down, its funny to watch them keep going to more powerful motors and cranking up the punch/current limiter etc. thinking they are gonna crush people now cause they are FAST! The 4300HD is a great motor but was too much for me personally, I actually prefer my Novak vented Ballistic 4.5T 550 2 pole on my track, zero boost but with a bunch of turbo timing in the ESC, smooth and controllable and faster then most down the straight, real easy on the battery and temps are good. I run a Orion R10.1 in my Tekno with the above motor, get alot of guys looking at my stuff and scratching there heads trying figure out how my little baby ESC and wimpy 2 pole out runs most of them. I would like to give a Hobbywing Xerun 4000KV some testing though, have try'd the 4700KV version and its a beast (too fast for me) but a serious battery hog, the 4000 may be the ticket though.
Tekno EB48.3/Tekno EB48SL/Tekno SCT410.3
Dan.J is offline   Reply With Quote
Old 07-02-2015, 06:47 PM   #1480
I have the 4000 right now in my .1, but bought the 4300 for my new build. I'm gonna give it a try and can always turn it down
Old 07-02-2015, 07:21 PM   #1481
Barillms's Avatar
I have a Turnigy TrackStar SCT 4150kv motor with a HobbyWing SCT Pro ESC. It's so fast I can barely control it, and I have the Punch on 1.
RC Juice
Dialed RC Hobbies
HobbyStar
Savox Servos
HRP - Hobby & Recreation Products
Barillms is offline   Reply With Quote
Old 07-03-2015, 03:52 AM   #1482
Hoese37's Avatar
What is the first?
4300?
Hobbywing 4700. I ran the 4300 for a few races and hated it. Too much low end TQ. By the time you put enough current limiter in it to make it drivable, you are still at the same top end as the 4600. Then at the same time you start draining your battery quicker. The HW is much more smooth through the power band, its easier on batteries, runs much cooler. When local guys are running 16T on the 4300 and temping 170, I run a 18T and temp at 130.
Tekno R/C
FTR 510 Raceway
Team FTR
REX Engines USA
RW Mods
Old 07-03-2015, 04:55 AM   #1483
I replaced mg HW SCT Xerun combo (4000kv) with this Tekin set because I was wanting to get more serious about racing. I kept the motor, but the esc is not that great in my opinion. I still can't get it to link up with my pc, it kept shutting down at the end of 5 minute heats and the castle BEC didn't fix it. I also don't like how you have one stroke of the throttle forward for a brake, the second one goes into reverse.
Lastly it kept going in and out of sensors mode.
Old 07-03-2015, 05:16 AM   #1484
Hoese37's Avatar
You have something else going on. Contact Tekin about the issue. You may just have a dud. It happens with every mfg.
If you have a Dell computer, you may need to restart it in safe mode to get the hot wire to connect.
Tekno R/C
FTR 510 Raceway
Team FTR
REX Engines USA
RW Mods
Old 07-03-2015, 07:16 AM   #1485
TheCore's Avatar
Trader Rating: 45 (100%+)
Hobbywing 4700
i completely agree. i liked the xerun 4000 kv motor, i absolutely LOVE the 4700. fast, smooth and cool. i even got a lucky one and to swap between my 4000 and 4700 all i had to do was swap the solder posts connected with the cap screws. i've seen these posts as non removable, cone/dish connection and the slotted connection, i'm not sure if there if there's a method to their madness as far as what solder connectors they use, but it's a nice little bonus when you can swap out a motor without having to resolder anything.
TheCore is offline   Reply With Quote
Tags
sct410, sct410.3, short course, short course 4x4, tekno
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
