    Hide Wikipost
Old 07-27-2017, 06:29 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC SCT410.3 Thread
Last edit by: Bob Barry
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8072 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree68Likes
Old 06-29-2015, 05:18 PM   #1441
JAE
Trader Rating: 26 (100%+)
Default spectrum 6040 or Savox 1258
I have both servos. Which should I install in my new 410.3? All comments most helpful!
JAE is offline   Reply With Quote
Old 06-29-2015, 06:33 PM   #1442
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
They are pretty much identical spec-wise. My other son ran a 6040 in his B5M. It was pretty decent for the buggy. I've had 1258's in pretty much all my rides for a long time now. The 1258 is a noisy buggar but it seems to perform well. I've also heard the Savox servos are power hungry so if you have a wimpy BEC in your ESC (Castle) that might create a problem.
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 06-30-2015, 06:16 AM   #1443
Does anybody else have play in the steering bellcrank? It seems to be coming from the part opposite the servo saver, the part on the top of this picture: EDIT, can't post pictures yet!
captain spauldi is offline   Reply With Quote
Old 06-30-2015, 09:06 AM   #1444
Hoese37's Avatar
Check the original 410 thread. You may have a bad saver assembly.
Tekno R/C
FTR 510 Raceway
Team FTR
REX Engines USA
RW Mods
Hoese37 is offline   Reply With Quote
Old 06-30-2015, 10:12 AM   #1445
Thanks, I'll give it a go.
Old 06-30-2015, 10:29 AM   #1446
Anyone try a castle 3800 motor in this? I usually use their 2400 but it's just not enough kv on 3s
Dragonfueled is offline   Reply With Quote
Old 06-30-2015, 11:14 AM   #1447
Matthew_Armeni's Avatar
Trader Rating: 31 (100%+)
What were you geared at? 2400kv either needs a lot of gear on 3s or very little on 4s.
Having said that, the 3800 is plenty powerful for this truck, but like the 2400, it's kinda in between the ideal kv spots of 2s and 3s. So either run a big pinion on 2s or a small one on 3s.
Tekno RC
Matthew_Armeni is offline   Reply With Quote
Old 06-30-2015, 11:30 AM   #1448
I like using 3s. The 2400 geared 23/44 just isn't fun yet lol. I might try 3800 on 3s and see what happens
Old 06-30-2015, 06:06 PM   #1449
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Hobbywing has a 3400kv 4 pole motor that will work with 3s.
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 06-30-2015, 07:41 PM   #1450
Barillms's Avatar
If anyone is looking for a tough body... The JConcepts Nissan Titan is a really good body. Reinforce the front clip with dry wall tape & shoe goo, and the rear corners. I have lots of hard crashes on mine, endos, cartwheels... You name it. It's holding up great.
My last body was the JConcepts Manta. It broke in 7 places in my first 2 races. It was BAD. JConcepts sent me this Titan for free, and its night & day stronger than the Manta. The bodies with more detail, more creases, more lines seem to be weaker than the more simplistic body designs. This is simply my opinion, but I do believe the added creases create weak points.
RC Juice
Dialed RC Hobbies
HobbyStar
Savox Servos
HRP - Hobby & Recreation Products
Barillms is offline   Reply With Quote
Old 06-30-2015, 10:59 PM   #1451
So will the shock towers off the new eb48.3 fit the sct?
Old 07-01-2015, 01:12 AM   #1452
JAE
Default Hobbywing
Can you elaborate on the performance of the 3400 on 3s vs 4000 on 2s? What is the optimal pinion size on 3s?
Old 07-01-2015, 05:37 AM   #1453
Tekno told me it would change the geometry.
qstorm777 is offline   Reply With Quote
Old 07-01-2015, 07:43 AM   #1454
Hoese37's Avatar
It will fit, but will throw off the geometry of the truck, and you will need to order Truggy shocks to get the droop back in the rear.
Tekno R/C
FTR 510 Raceway
Team FTR
REX Engines USA
RW Mods
Old 07-01-2015, 08:20 AM   #1455
Hoese37's Avatar
Id be interested to see how the 4x1.8 pistons will make the truck handle.
Tekno R/C
FTR 510 Raceway
Team FTR
REX Engines USA
RW Mods
Tags
sct410, sct410.3, short course, short course 4x4, tekno
