    Hide Wikipost
Old 07-27-2017, 06:29 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC SCT410.3 Thread
Last edit by: Bob Barry
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8072 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree70Likes
Old 06-15-2015, 09:59 AM   #1156
Barillms's Avatar
Originally Posted by Cain View Post
Is there a driver setup out now that is truly for big 1/8 tracks that is loose in conditions and rough?
This truck is brand new. Most people have just gotten them within the past month. People that have set ups are pretty tight lipped about it. You just need to experiment on your own. Rule of thumb is never make multiple changes at once, change 1 thing at a time and make note of the results. Basically keep making Small changes until you feel its where you want it.
For a big track you'll want at least an 18T pinion, and keep the body mounted low & vented so it doesn't catch too much air on the large 1/8 scale jumps. There's a Tekno PDF file on their website called "Set_Up_Guide.PDF" that you can download that will help you understand what changes are good for Bumpy vs. Smooth. The set up guide is an invaluable resource across the board.
RC Juice
Dialed RC Hobbies
HobbyStar
Savox Servos
HRP - Hobby & Recreation Products
Barillms is offline   Reply With Quote
Old 06-15-2015, 10:10 AM   #1157
Barillms's Avatar
Originally Posted by Brandon Powell View Post
looking for a small pin tire to use on my sct410.3. holeshots work during the day, the outdoor track gets tacky, loamy after sunset.
There are so many tires to choose from that all work well. You might want to check out City Block 2s, Gridiron 1s, Calibers, Subcultures... Something with a deeper tread. Even Enduros work well in many conditions.
RC Juice
Dialed RC Hobbies
HobbyStar
Savox Servos
Old 06-15-2015, 10:11 AM   #1158
Where on the website is the set up guide located?
ba4ma is offline   Reply With Quote
Old 06-15-2015, 10:34 AM   #1159
Gertsch's Avatar
Hello,
this is my first post in the forum.
Im from Austria/Europe and Im in RC racing almost 4 years.
I joined the hobby really late, Im 37 right now.
Im a club racer in a 1:10 scale racing club and run a HB D413 and now Im interested in a 410.3, cause the distributor is just around the corner at my house.
I really like this forum and I got a lot of informations from here, thanks a lot for that.
Now I hope I can give something back over the time.
Sorry for my english, its not the best - but ill try to do (write) the best I can.
so long
cheers
Gertsch
same question here, cant find it on there website and cant find it trough google neither.
thank in advance!
Gertsch is offline   Reply With Quote
Old 06-15-2015, 10:34 AM   #1160
Trader Rating: 17 (100%+)
Send a message via AIM to Kave
I ran the stock setup with the following changes this weekend.
Pink/pink springs, 6x1.5 pistons, 32.5f/27.5r
wheelbase all the way short
7/5/5 in the diffs
3deg of rear toe
2.4 swaybar in the front with neither front or rear bar tightened down with the setscrews on the diff cases
Car was really good, I want to play around more with the rear pills to see what kind of changes they will make but to be honest they are confusing as hell to know what your final values are with each pill setup.
The above changes to the stock setup will get you in the ball park. I ran AKA Enduros to give you an idea what the track was like. I would like to get a bit more high speed steering out of the truck but that's all I really felt it needed, I might try more kickup in the front this week to see if that gives me what I want.
Kevin Van Ert | RC^2 | CRC Racing | Team Scream Racing | Dumpers Speed Shop | Genesis RC | Race Rewards | Lake Superior RC Car Club | www.lsrcc.com
Kave is offline   Reply With Quote
Old 06-15-2015, 04:50 PM   #1161
Look on the tekno web page it is under support tab
http://www.teknorc.com/setup-sheets/
Aswild is offline   Reply With Quote
Old 06-15-2015, 05:13 PM   #1162
Dan.J's Avatar
Trader Rating: 21 (100%+)
I see setup sheets from various guys at different tracks but don't see a set up "guide" thats being talked about.
Tekno EB48.3/Tekno EB48SL/Tekno SCT410.3
Dan.J is offline   Reply With Quote
Old 06-15-2015, 06:23 PM   #1163
Oh ,i thought he wated blanks to use
Old 06-15-2015, 07:15 PM   #1164
Default Motor
Anybody running or ran lrp dynamic 10L 4700? Im wondering how good they are and what pinion to run.
qstorm777 is offline   Reply With Quote
Old 06-15-2015, 08:31 PM   #1165
Barillms's Avatar
**POST REMOVED**
Old 06-15-2015, 09:32 PM   #1166
found it!
Well I guess they don't have it finished yet
Old 06-15-2015, 09:58 PM   #1167
Hoese37's Avatar
This is not public use material at the time, since it is unfinished.
Tekno R/C
FTR 510 Raceway
Team FTR
REX Engines USA
RW Mods
Hoese37 is offline   Reply With Quote
Old 06-16-2015, 02:58 AM   #1168
Dan.J's Avatar
Error 404 - Page not found!^^^^
Dang this thing is like trying to find a unicorn or something
Old 06-16-2015, 03:44 AM   #1169
I think they removed it since it wasn't finished. I could get to it last night.
Old 06-16-2015, 04:38 AM   #1170
portyansky's Avatar
Trader Rating: 54 (100%+)
All Canadians that own a Tekno please join here... I'm just trying to get an idea of the number of Tekno owners.
https://www.facebook.com/groups/698636993613372/
Team Tekno Canadian Team Manager
Team Hitec
portyansky is offline   Reply With Quote
Tags
sct410, sct410.3, short course, short course 4x4, tekno
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
