    Hide Wikipost
Old 07-27-2017, 06:29 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC SCT410.3 Thread
Last edit by: Bob Barry
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8072 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree69Likes
Old 06-08-2015, 10:58 AM   #1066
Hello, i've been looking at getting a 410.3 but I was wondering what 1/8 buggy tires would be like and how it would effect the handling? I'm only going to be doing club level racing and my club will let me run the 1/8 tires with no issues.
Millsy97 is offline   Reply With Quote
Old 06-08-2015, 11:28 AM   #1067
Barillms's Avatar
Originally Posted by Kave View Post
The situation with the Tekno springs is absolutely ridiculous. I have several packs on both my stock fronts and my pink fronts and neither lets me get a ride height below 30mm.
Yet the stock setup calls for a 25mm ride height. How does Tekno not see this as an issue?
100% exactly my thoughts. The green fronts are the right spring rate... They're just too long. My ride height in the front was like 33, and I seriously laughed out loud, because the rear was at like 15 box stock.
Once you put a battery pack in, and the springs settle a bit you'll be able to get it down to about 27mm up front. Or you can just run the softer Pink springs... The Black shorter fronts are too soft I think (I have them). Pinks are the way to go Front & Rear. Actually, Pink front and Rear should have came stock to be honest. Theyee a much better fit across the board. The black rears are ridiculously too soft.
Are you guys building them with the bladders?? Or emulsion?? I went emulsion and am curious to how the bladders feel.
RC Juice
Dialed RC Hobbies
HobbyStar
Savox Servos
HRP - Hobby & Recreation Products
Barillms is offline   Reply With Quote
Old 06-08-2015, 11:29 AM   #1068
Barillms's Avatar
You'll need to buy the 17mm adapters to run buggy wheels. I would just run normal SC wheels so people don't accuse you of being a cheater.
RC Juice
Dialed RC Hobbies
HobbyStar
Savox Servos
Old 06-08-2015, 12:02 PM   #1069
Trader Rating: 17 (100%+)
Send a message via AIM to Kave
I've built them with the bladders only so far. Might try the emulsion as people seem to get a lower ride height with them, not sure how but hey it's worth a try?
Kevin Van Ert | RC^2 | CRC Racing | Team Scream Racing | Dumpers Speed Shop | Genesis RC | Race Rewards | Lake Superior RC Car Club | www.lsrcc.com
Kave is offline   Reply With Quote
Old 06-08-2015, 12:26 PM   #1070
rjohn929's Avatar
I am trying emulsion on my .3. Seems pretty good so far. I also dropped the shock oil to 30/25 to soften it up a bit. 35/32.5 with the Trifex pistons seemed way too stiff. I'm still running the green front but I went with pink rear. I have my ride height set at 27.
SCT410.3, SCT410, ET48, SCTE 1.0, SC10 4x4, SC10, B44.1, B44.2, Yeti, Yeti XL, Wraith, SCX10 JK, Gold pan/repro, Worlds Car/repro, Rival, Emaxx, Tmaxx, assorted Ofna's, 6 Big Bears, MERV, 3DR Solo, DMG DRIII, Vanquish, Avante, mixed bag of crawlers/scalers and the list goes on and on and..........
rjohn929 is offline   Reply With Quote
Old 06-08-2015, 12:48 PM   #1071
TheCore's Avatar
Trader Rating: 45 (100%+)
Originally Posted by rjohn929 View Post
... 30/25 to soften it up a bit. 35/32.5 with the Trifex pistons seemed way too stiff. ...
how do you like the trifex pistons ?
i have a set i picked up a few months ago and haven't played with them yet.
TheCore is online now   Reply With Quote
Old 06-08-2015, 06:09 PM   #1072
Hoese37's Avatar
Have you tried fully compressing your springs? I have a first run .3 and built to kit specs with bladder shocks and have no problem getting the front low.
Tekno R/C
FTR 510 Raceway
Team FTR
REX Engines USA
RW Mods
Hoese37 is offline   Reply With Quote
Old 06-08-2015, 06:11 PM   #1073
Hoese37's Avatar
Ill be up there for the Electric Boogie. If you are there as well hit me up. Ive given some setup points to Jabber.
Tekno R/C
FTR 510 Raceway
Team FTR
REX Engines USA
RW Mods
Old 06-08-2015, 08:01 PM   #1074
Lowe's48's Avatar
Originally Posted by Brandon Powell View Post
I have upgraded to the SCT.3, but not updated my shock rod ends and retainers yet to the locking ones. any issues with them?
2 races and tons of practice and no issues.....just order some for my V1 superlite!!! Best innovation ever.
Tekno Sct410.3-VRP,HW120 SCT-PRO,Pro4-4300kv,Hitec,LRP 8000/2s
Tekno SL.3-VRP,HW120 SCT-PRO,T8i-1950,Hitec,LRP 5000 4s
Weapon of choice : Airtronics M12
Home track : Coyote Hobbies,Ca
Lowe's48 is offline   Reply With Quote
Old 06-08-2015, 08:07 PM   #1075
Lowe's48's Avatar
Originally Posted by HSV427 View Post
Finished building my sct410.3 yesterday and took it out for its first run today and all i can say is what a blast, ran 4 packs threw it and i was smiling the whole time this SCT has far exceeded my expectations, it drives exactly the same as my NT48 its absolutely amazing, best fun I've had in a long time. However the reason for my post is, after building the kit to book setup running the emulsion style shock i couldn't get the ride height under 28mm but exactly the way it has been suggested i ran 4 packs threw it then checked my ride height and it now sits at 23mm to get 25mm i actually have the shocks screwed down about 3 threads on the shock body, so I'm not understanding why some trucks can achieve 25mm ride height and some can't, i wonder if it has to do with emulsion vs vented, but like i said earlier i built it to book setup with the emulsion style shock and 0% rebound and have no problem getting 25mm.
Thanks TEKNO another awesome addition to my tekno fleet.
Emulsion here as well and i'm getting the 25mm ride height with no problems
Old 06-08-2015, 10:03 PM   #1076
Barillms's Avatar
Fully compressing the springs would raise the ride height? I'm talking collars all the up way, box stock set up... No batt, my front was way way higher than 25, more like 35mm. With battery it was at approx 32. After a few runs the springs have settled a good bit.
RC Juice
Dialed RC Hobbies
HobbyStar
Savox Servos
Old 06-08-2015, 10:27 PM   #1077
He meant compressing the springs by hand off the shock to break them in quicker so they will settle easier.
Showtime90 is offline   Reply With Quote
Old 06-09-2015, 12:58 AM   #1078
I'm able to get the box ride height. Running green in front and pink in rear. I have 3 or 4 race days on it now though.
qstorm777 is offline   Reply With Quote
Old 06-09-2015, 01:45 AM   #1079
Trader Rating: 16 (100%+)
carbon towers for sale on tecknorc
Tekno: NT48, ET48, EB48, SCT410
Xray: 2 XB9E, XB9, XT9 E, XB8 E 2014, 808E, 2 T4, XB4, XB4 2015
Losi: SCTE 2.0, 8T 3.0E, 2 8T 2.0E, Mini8T, 2 Mini8,
Mullet1 is offline   Reply With Quote
Old 06-09-2015, 06:48 AM   #1080
Hoese37's Avatar
This^^^
Tekno R/C
FTR 510 Raceway
Team FTR
REX Engines USA
RW Mods
Tags
sct410, sct410.3, short course, short course 4x4, tekno
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
