    Hide Wikipost
Old 07-27-2017, 06:29 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC SCT410.3 Thread
Last edit by: Bob Barry
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8072 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree68Likes
Old 05-26-2015, 04:05 PM   #946
TheCore's Avatar
Trader Rating: 45 (100%+)
Originally Posted by qstorm777 View Post
Anyone successfully used proline body mounts on SCT410? If so, did you use the proline body posts or cutoff the top of the Tekno body posts? Just wondering. The angles on the proline mounts don't match the body angles.
i used them on my v1. i cut the top of the post then drilled and tapped the stud.
i don't like how the "official version" has straight posts and doesn't carry the same offset or angles as the tekno front posts. it only takes a few minutes to make them and they work great. i have an extra set or two if you don't want to be bothered, pm me if you're interested in them.
TheCore is offline   Reply With Quote
Old 05-26-2015, 04:53 PM   #947
Originally Posted by Orion_2kTC View Post
Yeah rubbing the arms. I can't post pics right now but I will when I can
Change the 20mm cap head on the steering knuckle for a 20mm round head and problem solved.
tntpower is offline   Reply With Quote
Old 05-26-2015, 05:20 PM   #948
Barillms's Avatar
Please tell me you don't use those tires for racing?
RC Juice
Dialed RC Hobbies
HobbyStar
Savox Servos
HRP - Hobby & Recreation Products
Barillms is offline   Reply With Quote
Old 05-26-2015, 06:20 PM   #949
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
one of the tracks I go to when it really go crazy with the watering that are very close to that look work excellent.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 05-26-2015, 07:01 PM   #950
Barillms's Avatar
Those are play tires, rock crawler tires... "Run in mom's yard" tires. Definitely not made to race with.
RC Juice
Dialed RC Hobbies
HobbyStar
Savox Servos
Old 05-26-2015, 07:27 PM   #951
Tech Legend
Cain's Avatar
race tires are relative to the conditions you run on. There are tire types we have hard time finding that are excellent out here for racing but are not the popular race tire here.
Old 05-26-2015, 07:39 PM   #952
What if the track you're racing on has a surface that's similar to "mom's yard"? Not everyone has the luxury of blue groove or clay tracks to run your semi-slicks.
If you turned up at a loose dirt track with your chainlinks or dirtwebs, they're be laughing at you going "definitely not made to race with ... for this track"
On-Road - Xray T4'17 / Serpent 4-X / Tamiya Exo6 / Roche P10 & P12 & F1
4WD - Kyosho ZX6 / Yokomo YZ4 *** eBuggy - Tekno EB48SL
2WD - AE B5M (XFactory Chassis) / Kyosho RB6 / TLR 22 2.0 / Yokomo YZ2
SCT - Tekno SCT410 / Losi 22SCT 2.0
ST - Losi 22T 2.0
WagwanBumba is offline   Reply With Quote
Old 05-26-2015, 07:54 PM   #953
Moderator
bds81175's Avatar
Trader Rating: 20 (100%+)
I talked to him about his posts already. Please let it be and move on.
Current Racers: AE B6D, Tekno SCT410, Tekno EB48.3
Full Throttle R/C Raceway www.ftrcr.com, Psycho Dog Racing Team, Team Holy Rollers - Greatest RC race team on the planet. Well, at least the team with the best sponsor.
Tekno RC
bds81175 is offline   Reply With Quote
Old 05-27-2015, 05:56 AM   #954
Thanks. I have about 3 or 4 sets of posts so I'll give that a try. On your fronts, does the set screw go thru the body rests? If so, no problems if you crash?
qstorm777 is offline   Reply With Quote
Old 05-27-2015, 06:04 AM   #955
Trader Rating: 32 (100%+)
Got snap many times when a large jump. Make sure you have spare i lost 3 proline nut.
raved007 is offline   Reply With Quote
Old 05-27-2015, 06:41 AM   #956
What size drill bit did you use to drill the stud holes?
MaX-D is offline   Reply With Quote
Old 05-27-2015, 07:23 AM   #957
TheCore's Avatar
they don't go all the way thru, only half the length of the set screw. they've held great so far, altho the truck hasn't seen much abuse. the screws have a tendency to pull out (based on having them on my slash 4x4s) which is why i made a couple spares. the tekno plastic isn't as flexible as the proline plastic so they should hold better.
i don't remember if the set screws are 2.5 or 3mm. i probably just dug thru my bit box for something that was a tad smaller than the screw, then marked it at 1/2 the length for depth.
Shark's original post at rcshortcourse when he used the proline caps.
lol, my badlands... <3
Old 05-27-2015, 07:52 AM   #958
Ok so I'm almost done my sct410.3 build. Just installing my electronics. I'm running a tekin 2650 1/8 motor and I can't get it to fit. The can seems to be hitting the servo wire retainer right under the motor before I can get it into place. Does the 1/8 motors not fit? Or am I missing something
Horby32 is offline   Reply With Quote
Old 05-27-2015, 07:53 AM   #959
Trader Rating: 18 (100%+)
for a 1/8 motor you will need the regular non-lcg style motor mount insert
TEKNO SCT410.3; Hobbywing Sct-pro; Hobbywing 3656 4000kv; Protek 130S; SPC 70C 7200mAh 2s
TEKNO EB48.3; Hobbywing Xerun 150a; SMC 1900kv; Savox 2274SG; ECO Power 35c 4100mAh 4s
Associated B5R; Trackstar 120a turbo; Trackstar 8.5t; Solar D771; Reedy 65C 5800mAh 2s square
kyleman7 is offline   Reply With Quote
Old 05-27-2015, 08:23 AM   #960
Lowe's48's Avatar
.3 Race report
With only a couple of hours of practice on stock set up,the truck handles well on all aspects.Qualified 6 in the first heat , after more changes ended up 2nd on the second heat. Started 3rd in the main , after a few racing incidents felt back to 5th but fought back up to 3rd.
Summary: Great platform,tons of potentials. Need more time to tune and track time and this truck is for sure podium material day in day out!!
This coming from a Losi guy !!
Tekno Sct410.3-VRP,HW120 SCT-PRO,Pro4-4300kv,Hitec,LRP 8000/2s
Tekno SL.3-VRP,HW120 SCT-PRO,T8i-1950,Hitec,LRP 5000 4s
Weapon of choice : Airtronics M12
Home track : Coyote Hobbies,Ca
Lowe's48 is offline   Reply With Quote
Tags
sct410, sct410.3, short course, short course 4x4, tekno
