    Hide Wikipost
Old 07-27-2017, 06:29 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC SCT410.3 Thread
Last edit by: Bob Barry
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8072 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree70Likes
Old 05-20-2015, 07:22 AM   #886
Originally Posted by Tijuana_Taxi View Post
I would try lowering the center diff weight to allow the front to pull a little more. All depends on driving style but 10/10/7 might be a little high all the way around for anything except high bite stuff.
A Tekno driver recommended that to me and has been running those weight oils at the same tracks as me and he is planted.... So that is why I've been looking to other areas of my setup.
louie8269 is offline   Reply With Quote
Old 05-20-2015, 11:44 AM   #887
Lowe's48's Avatar
Originally Posted by Everybody79x View Post
I'm having nose down jumping issues. Running stock setup with emulsion shocks. Any recommendations? (besides moving the battery back)
Check your drag break setting. Also try not to get off the throttle too soon before the lip of jumps.
Lowe's48 is offline   Reply With Quote
Old 05-20-2015, 06:02 PM   #888
Trader Rating: 17 (100%+)
Send a message via AIM to Kave
So the manual says to run like 25mm of front ride height and even with my springs collars all the way backed off the lowest I can get is like 30mm. What am I missing here guys?
Kevin Van Ert | RC^2 | CRC Racing | Team Scream Racing | Dumpers Speed Shop | Genesis RC | Race Rewards | Lake Superior RC Car Club | www.lsrcc.com
Kave is offline   Reply With Quote
Old 05-21-2015, 03:59 AM   #889
Weird i got mine set to stock an it is 25 but i have the droop screws all the way up
Aswild is offline   Reply With Quote
Old 05-21-2015, 04:31 AM   #890
Default Body
What body had the wing on the back ?
Old 05-21-2015, 05:02 AM   #891
TheCore's Avatar
Trader Rating: 45 (100%+)
JConcepts F250
TheCore is offline   Reply With Quote
Old 05-21-2015, 05:50 AM   #892
I had the same problem out of the box. I believe somewhere on here it was said that the ride height would settle down after the springs are put thru some compression/rebound cycles. Someone even said they did this manually with their hands. That reminds me, I need to go back and see if my car has settled now.
qstorm777 is offline   Reply With Quote
Old 05-21-2015, 06:33 AM   #893
Evo X Revo's Avatar
make sure the shock ends and shock lengths are correct. and that the springcups are seated correctly. all could affect ride height..
Tekno ET48
Tekno SCT410.3
Tekno EB48.2, .3
Tekno Nb48 (coming soon)
Evo X Revo is offline   Reply With Quote
Old 05-21-2015, 07:44 AM   #894
I had the same issue, after a pack or two, the springs settled. Was at 24.
Everybody79x is offline   Reply With Quote
Old 05-21-2015, 08:05 AM   #895
Why is this truck on back order or out of stock at the big online shops?
diamonddawg21 is offline   Reply With Quote
Old 05-21-2015, 08:23 AM   #896
Check out fiercercsolutions.com I believe he has them if not gets them quick
iceman_bigb is offline   Reply With Quote
Old 05-21-2015, 08:25 AM   #897
rjohn929's Avatar
Because it is new and they are having trouble keeping up with demand.
SCT410.3, SCT410, ET48, SCTE 1.0, SC10 4x4, SC10, B44.1, B44.2, Yeti, Yeti XL, Wraith, SCX10 JK, Gold pan/repro, Worlds Car/repro, Rival, Emaxx, Tmaxx, assorted Ofna's, 6 Big Bears, MERV, 3DR Solo, DMG DRIII, Vanquish, Avante, mixed bag of crawlers/scalers and the list goes on and on and..........
rjohn929 is offline   Reply With Quote
Old 05-21-2015, 08:29 AM   #898
Evo X Revo's Avatar
if you want one and know where to look they are available in multiple places..
Tekno ET48
Tekno SCT410.3
Tekno EB48.2, .3
Old 05-21-2015, 08:47 AM   #899
Hoese37's Avatar
Both the Titan and Armada have a similar feature, But both those bodies are known to have front end durability issues.
Tekno R/C
FTR 510 Raceway
Team FTR
REX Engines USA
RW Mods
Hoese37 is offline   Reply With Quote
Old 05-21-2015, 11:58 AM   #900
dirtbikekid33's Avatar
Any update on the eta on the cnc towers?
Tekno Eb48.2 tekin Rx8 tekin 1900 savox
Tekno SCT410 tekin Rx8 HW 4700 savox
RC10 b44.2 Tekin RS PRO tekin 6.5 savox
Rc10 b4.2 Tekin RS trinity 17.5 savox
dirtbikekid33 is offline   Reply With Quote
Tags
sct410, sct410.3, short course, short course 4x4, tekno
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Bburns
