    Hide Wikipost
Old 07-27-2017, 06:29 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC SCT410.3 Thread
Last edit by: Bob Barry
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8072 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree69Likes
Old 05-13-2015, 01:42 PM   #796
TheCore's Avatar
Trader Rating: 45 (100%+)
Originally Posted by Aswild View Post
So run the screws first before you even put any parts on the diff and then take them out an put together ?
yeah, that's what i did when i built my second v1, you're basically just cuttin' threads into the diff case. i also used non stock screws since i didn't like the way my driver seated in a few of the stock heads.
TheCore is offline   Reply With Quote
Old 05-13-2015, 01:51 PM   #797
FastPete's Avatar
Trader Rating: 44 (100%+)
Originally Posted by TheCore View Post
much appreciated. i grabbed one of pete's upgrade packs and just wanted to be sure it was everything i needed.
Yes sir basic upgrade 410.0 kit has everything you need to get the shock geometry, arms, front spindles, rear hubs with the larger bearings, and rear truggy swaybar.
The rest are options.
Authorized Dealer for /Agama / Tekno / Team Associated / Schelle / Hobbywing / PT Racing Shock & Diff oil / Serpent / Tekin / JConcepts / AKA / Proline / Savox / M2C / Picco / www.fiercercsolutions.com Like us on facebook www.facebook.com/FierceRCSolutions
FastPete is offline   Reply With Quote
Old 05-13-2015, 02:09 PM   #798
where do you find this kit on your website Pete?
ba4ma is offline   Reply With Quote
Old 05-13-2015, 02:26 PM   #799
Lowe's48's Avatar
Just got it done yesterday. ...Pretty stoked. This is my first brand-new car and first build. Very impressed with the quality and how nice everything fit. Ran a couple of batteries on the street to make sure everything is good to go and then truck drove amazing with 45wt fr/35 rr. Its about 62 grams heavier than my Mip Losi scte but I think the
weight are in the right places. Going to do club racing/tuning this weekend and going to the third race of the Jbrl next weekend. Will report back with more feedback.
Lowe's48 is offline   Reply With Quote
Old 05-13-2015, 02:38 PM   #800
TheCore's Avatar
LINKY
don't forget to get your coupon code from the first page of his website before you order.
Old 05-13-2015, 02:42 PM   #801
LINKY
thank you
Old 05-13-2015, 07:57 PM   #802
Looks good Lowes48. I should turn my battery straps that way.
qstorm777 is offline   Reply With Quote
Old 05-14-2015, 04:34 AM   #803
Man i cant wait to finish ,,,,,,,,,,
Aswild is offline   Reply With Quote
Old 05-15-2015, 03:26 AM   #804
Looks great lowes any tips u recomend?
Old 05-15-2015, 05:06 AM   #805
Lowe48, what type of body mounting system are you using? The post look like screws. Thanks.
Old 05-15-2015, 05:33 AM   #806
[QUOTE=Lowe's48;14007387]Just got it done yesterday. ...Pretty stoked. This is my first brand-new car and first build. Very impressed with the quality and how nice everything fit. Ran a couple of batteries on the street to make sure everything is good to go and then truck drove amazing with 45wt fr/35 rr. Its about 62 grams heavier than my Mip Losi scte but I think the
[.QUOTE]Any special reason your shock oil is so far from the book set-up?
Whosold is offline   Reply With Quote
Old 05-15-2015, 07:19 AM   #807
Lowe's48's Avatar
I lubed all the ball links and do not over tighten period!!!(especially the nut for the shock pistons)
Take your time and make sure everything are free and no bind !
Tekno Sct410.3-VRP,HW120 SCT-PRO,Pro4-4300kv,Hitec,LRP 8000/2s
Tekno SL.3-VRP,HW120 SCT-PRO,T8i-1950,Hitec,LRP 5000 4s
Weapon of choice : Airtronics M12
Home track : Coyote Hobbies,Ca
Old 05-15-2015, 07:33 AM   #808
dirtbikekid33's Avatar
just be careful and not let the plastic loop slide down it will rub on your driveline.
Tekno Eb48.2 tekin Rx8 tekin 1900 savox
Tekno SCT410 tekin Rx8 HW 4700 savox
RC10 b44.2 Tekin RS PRO tekin 6.5 savox
Rc10 b4.2 Tekin RS trinity 17.5 savox
dirtbikekid33 is offline   Reply With Quote
Old 05-15-2015, 08:06 AM   #809
Trader Rating: 20 (100%+)
Hi All, I am about to build my 410.3, any advice? its going to be for indoor clay track (norcal Hobbies, san jose Ca)
any upgrades I should have that won't cost me a lot? I have the alum hexes from the orig 410 that I bought that I never used, so hopefully they will just fit this one.
Just wondering if there was any part I should get that I can install when I build the kit so I don't have to tear the whole truck down later to install it.
Nissanguy8 is offline   Reply With Quote
Old 05-15-2015, 09:13 AM   #810
Hoese37's Avatar
Proline Secure Loc system.
Metal servo horn. The new kit includes steel hexes. They seem to be ok if you snug the set screw rather than torqueing it down.
Tekno R/C
FTR 510 Raceway
Team FTR
REX Engines USA
RW Mods
Hoese37 is offline   Reply With Quote
Tags
sct410, sct410.3, short course, short course 4x4, tekno
