    Hide Wikipost
Old 07-27-2017, 06:29 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC SCT410.3 Thread
Last edit by: Bob Barry
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8072 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree67Likes
Old 05-08-2015, 06:11 PM   #721
jhautz's Avatar
Trader Rating: 85 (100%+)
Originally Posted by Mikeand22 View Post
Could you expand a bit on the springs "settling in"? Thanks
I usually compress new springs 15 or 20 times all the way down before installing them. If you don't break them in the ride height tends to settle a bit over the first dozen or so runs.
Take the springs off and squees em down some and it will settle the ride height in.
jhautz is offline   Reply With Quote
Old 05-08-2015, 07:01 PM   #722
Jordan Anderson's Avatar
Originally Posted by Wease View Post
I did a search on here and saw one person asked this question, but I don't think it was ever answered. I've built more kits than I can remember including my last SCT410, but I'm feeling like I did something wrong here and can't figure it out.
The lowest front ride height I'm able to attain with the kit set-up is 27mm and that's with the front shock collars all the way up. The kit set-up sheet says the front ride height should be 25mm. I must be missing something, but I can't figure it out. The new locking shock spring perches have the knuckles pointing to the outside of the vehicle, and I verified I'm using the correct springs.
Thanks . . . Matt
I had the same problem. Assumed springs would settle a bit?
JORDAN // EVAN RC8.2e, B5, B5M, EB48SL, SCT410.3
R/C GEARS , TRUKZ/KARZ , VRC PRO
We're not sponsored, but would recommend:
Team Associated, Tekno, A Main, Action, PM
Futaba, Schelle, Avid, Proline, Lunsford
Jordan Anderson is offline   Reply With Quote
Old 05-08-2015, 07:15 PM   #723
Hoese37's Avatar
This ^^^
After a few runs the springs do tend to soften a bit as they lose some tension. When a spring like this compresses, it actually is twisting the wire. Its like a torsion bar setup in a real car.
Tekno R/C
FTR 510 Raceway
Team FTR
REX Engines USA
RW Mods
Hoese37 is offline   Reply With Quote
Old 05-08-2015, 10:15 PM   #724
Default Run Time
I finally got mine on the track today. I really didn't want to...last car I ran. It looked too pretty to scratch the chassis and get dirt on. Anyway, the car handled great. It was easier to drive than 1/8 bug and trug (until I got used to trug) and I thought it handled a noticeably better than v1. The nose dive is less severe. You will still get it if you decel at the top of a jump but you can correct it if you catch it early enough. The rear end is soft to touch, but I can't say it presented any problems on the track. It handled the whoops pretty good. It is still plenty tough. I had my share of mishaps as expected running on a track you never ran on before. I like this truck and I'm glad I upgraded. I'm ready to race tomorrow. May get video if I have time to figure out gopro.
qstorm777 is offline   Reply With Quote
Old 05-09-2015, 06:36 AM   #725
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
looking forward to some vids
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 05-09-2015, 05:14 PM   #726
HSV427's Avatar
Trader Rating: 21 (96%+)
I just pulled the trigger on one off these, can someone tell me what bodies people are using to get the best performance and durability, also do losi sct rims fit. Thanks
XRAY XB4 15, XRAY XB4 16, XRAY XB2, YOKOMO B-MAX4 III FACTORY KIT, YOKOMO YZ4, YOKOMO YZ2,KYOSHO RB6, TAMIYA TRF503, TAMIYA TRF201XMW, TAMIYA TRF 211XM
HSV427 is offline   Reply With Quote
Old 05-09-2015, 06:37 PM   #727
FastPete's Avatar
Trader Rating: 44 (100%+)
The Losi rims fit yes. Bodies theres many I will let others chime in.
Authorized Dealer for /Agama / Tekno / Team Associated / Schelle / Hobbywing / PT Racing Shock & Diff oil / Serpent / Tekin / JConcepts / AKA / Proline / Savox / M2C / Picco / www.fiercercsolutions.com Like us on facebook www.facebook.com/FierceRCSolutions
FastPete is offline   Reply With Quote
Old 05-10-2015, 08:29 AM   #728
loloscorsa's Avatar
Look this video I found on youtube.
https://www.youtube.com/watch?v=apwnlfXSUVI
>>> Team Associated B5M <<<
>>> Tamiya F104 Exotec <<<
loloscorsa is offline   Reply With Quote
Old 05-10-2015, 09:05 AM   #729
Looks like it was working good in this video especially with the tires he was running, pinpoints are for carpet!
Showtime90 is offline   Reply With Quote
Old 05-10-2015, 03:53 PM   #730
Shawn_S's Avatar
Trader Rating: 18 (100%+)
Had a great first race with the .3 yesterday. I had yet to setup droop and ride height till I got to the track, so unfortunately I had to make due with a front riding too high. I am running box stock setup except for pistons and shock oil. Pistons are Imbue V2 5-hole, and started off with 32.5f/27.5r. Imbue pistons need some time to break-in, so that's why I went a little too soft.
As far as the truck, totally impressed. Track was a smaller outdoor, that's normally grooved, but slick. Yesterday the traction was way up. Truck was a little loose, due to the front springs no doubt. There are several smaller jumps, almost kickers that I was fearing due to previous experience with the original 410. No problems at all, the truck jumps great, no nose-down tendencies. I was most impressed with the correctability in the air, able to bring the nose up or down.
Unfortunately the other real fast guy had some issues all day, so it was an easy sunday drive to TQ and win. Looking forward to the next one!
Tekno NT48.3 | NB48 | EB48.4 | SCT410.3
Team Durango DEX410v5 | DEX210v3
Mugen MBX-GT8 | GT8-E
Shawn_S is offline   Reply With Quote
Old 05-10-2015, 06:51 PM   #731
I'm almost done with mine. Had 2 of the .1 versions. Anyone find the stock spring selection a little strange? Green front with Black rears? I normally run high bite indoor clay & run green front and rear. Seems strange to run 2 step stiffer in the front than in the rear.
Outdoor i normally run the old stock springs --black front, pink rear. The quality is top notch & several minor improvements make this kit even better to assemble than the previous version.
Thanks Tekno, now please make a 4wd buggy
JASF4I is offline   Reply With Quote
Old 05-10-2015, 07:10 PM   #732
Buy a D413: close enough . Tough little buggy!
PetRock is offline   Reply With Quote
Old 05-10-2015, 09:24 PM   #733
Carter Flotron's Avatar
The geometry of the .3 has been changed quite a bit over the original, which is why it is setup this way. Although, in the future you may want to go up on your springs if your track has enough grip.
A lot of guys are just switching the stock pistons out for 6x 1.6 or 6x 1.5 s and running something like 35/30 for oil, and running the rest of the stock setup. That's probably the best place to start
Thanks to all my sponsors for 2016!
|Pro-line Racing|Hobbywing North America|Highest Servos|Fierce RC Solutions|
Carter Flotron is offline   Reply With Quote
Old 05-11-2015, 02:54 AM   #734
karbroSCT's Avatar
Is the Bittydesign "Black Hawk" body a good fit on the Tekno SCT410.3?
karbroSCT is offline   Reply With Quote
Old 05-11-2015, 12:20 PM   #735
How much of a necessity is the aluminum servo horn? I've never needed one on any other 2wd 1/10 car.
Everybody79x is offline   Reply With Quote
Tags
sct410, sct410.3, short course, short course 4x4, tekno
