    Hide Wikipost
Old 07-27-2017, 06:29 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC SCT410.3 Thread
Last edit by: Bob Barry
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8072 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree82Likes
Old 05-06-2015, 10:28 AM   #706
Hoese37's Avatar
The body should come with a guide that will tell you which holes to drill. The truck was designed to have the same mounting points at the SCTE. There are 2 different front body posts included in the kit. Its to offer a different mounting location if the body has a feature that interferes with the normal hole location. SCTE bodies are direct fit.
Tekno R/C
FTR 510 Raceway
Team FTR
REX Engines USA
RW Mods
Hoese37 is offline   Reply With Quote
Old 05-06-2015, 12:32 PM   #707
Jordan Anderson's Avatar
Thanks!
JORDAN // EVAN
R/C GEARS , TRUKZ/KARZ , VRC PRO
Jordan Anderson is offline   Reply With Quote
Old 05-06-2015, 08:02 PM   #708
Mikeand22's Avatar
Trader Rating: 24 (100%+)
Very excited about mine shipping out today from Tower! Can't wait to race this thing!!!
Mikeand22 is offline   Reply With Quote
Old 05-07-2015, 12:53 AM   #709
FAO
FAO's Avatar
Location: Germany near famous clay track of RCRT Duisburg
Originally Posted by ezlight View Post
5200kv motor? Never heard of anyone running that high of a KV in this heavy truck. 4700kv has been the highest until now. I'd switch to something in the 3900kv-4700kv range.
Its cold here in Germany...(but sometimes wet).
Thought of using the Tenshock 411 5200kv with a small pinion (12, 13, ) to get more punch on the ramps for longer jumps.
I use the Tenshock 411 4600kv already. Power consumption changed to 4000mah in a 5 min race from 2000mah with the SC 10 4x4 driven by LRP 2-pole x12L 4,5.
The former seastar:
Tekno SC 410.3, Serpent Spyder SCT, dust, loomy, slippery, dirt
FAO is offline   Reply With Quote
Old 05-07-2015, 02:25 AM   #710
JsK
JsK's Avatar
Originally Posted by Jordan Anderson View Post
Thanks!
Check it first before you paint, with the mounts I chose to match the body angle
it didnt quite line up perfectly with the scte holes. I just drill a small pilot hole
before I paint.
JsK is offline   Reply With Quote
Old 05-07-2015, 06:57 AM   #711
Tech Legend
Cain's Avatar
Trader Rating: 234 (100%+)
so for the new vehicle, what appears to be areas of upgrade to get right away? So far looks like:
- Aluminum Servo Horn
- Aluminum Front hingepin brace
Hexes "might" be an issue but seems its more so not cranking them down. That about sum it up?
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 05-07-2015, 07:06 AM   #712
[QUOTE=FAO;13996033]Repairing my damaged car, i noticed that the smallest pinion to mount is the 14 teeth, you cant get the motor nearer to the spur gear. So, ordering 11,12 and 13 was sensless. (this may become a problem with a 5200kv motor)
17 and 18 may be critical concerning motor temperatures, so 15-16 are the right ones.
Can anyone else comfirm this?
I'm planning on running a hw 3400kv on 3s and wanted to gear for efficiency/power. I don't want to run into issues with pinion fitting. Anyone have a idea what pinion size I will be using? I was thinking 14 or lower? I will be racing med/large outdoor tracks.
Horby32 is offline   Reply With Quote
Old 05-07-2015, 08:43 AM   #713
TheCore's Avatar
Trader Rating: 45 (100%+)
this could be because the .3 comes with the lightened lowered motor mount. possibly with the regular mount this won't be an issue ?
TheCore is offline   Reply With Quote
Old 05-07-2015, 12:08 PM   #714
With just few ride's behind I'll think you have it right. I hope the second issue will be corrected by Tekno with new kitt's. Aluminium servo arm sure will not be in the box when it would not be a wise move ( should be many for all spiline's).
Tekno RC Team Driver
www.teknorc.fi
mamyllyn is offline   Reply With Quote
Old 05-07-2015, 02:30 PM   #715
Anybody running the rear hubs all the way forward on this truck?If so,what were the results?better traction,less traction?
ba4ma is offline   Reply With Quote
Old 05-07-2015, 05:03 PM   #716
Slotmachine's Avatar
Send a message via MSN to Slotmachine
More traction and tighter turning in 180s.
[QUOTE=Horby32;13997540]
14 is the smallest on the old mount. Maybe try flipping the new mount around to see if you can get smaller.
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 05-08-2015, 02:37 PM   #717
Trader Rating: 75 (100%+)
I did a search on here and saw one person asked this question, but I don't think it was ever answered. I've built more kits than I can remember including my last SCT410, but I'm feeling like I did something wrong here and can't figure it out.
The lowest front ride height I'm able to attain with the kit set-up is 27mm and that's with the front shock collars all the way up. The kit set-up sheet says the front ride height should be 25mm. I must be missing something, but I can't figure it out. The new locking shock spring perches have the knuckles pointing to the outside of the vehicle, and I verified I'm using the correct springs.
Thanks . . . Matt
Associated (2x)B6D, B64D, T5M, SC5M
TLR 22-4 2.0, SCTE 3.0
Mugen Seiki MBX7R Eco, MBX7R Nitro, MBX7T Eco, MBX7TR Nitro
XRAY 17 XB4
Yokomo YZ-2 CA
Wease is offline   Reply With Quote
Old 05-08-2015, 03:52 PM   #718
I've had my new truck for 2 weeks and tomorrow will be my first time to run it. I'm excited to get this one on the track.
losi b is offline   Reply With Quote
Old 05-08-2015, 05:32 PM   #719
Hoese37's Avatar
Thanks . . . Matt
You will need to run it a bit to get the springs to settle in.
Tekno R/C
FTR 510 Raceway
Team FTR
REX Engines USA
RW Mods
Old 05-08-2015, 05:45 PM   #720
Mikeand22's Avatar
Could you expand a bit on the springs "settling in"? Thanks
Tags
sct410, sct410.3, short course, short course 4x4, tekno
