    Hide Wikipost
Old 07-27-2017, 06:29 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Official Tekno RC SCT410.3 Thread
Last edit by: Bob Barry
Welcome to the SCT410.3 Wiki!
7.26.17 - BB
In order to run the recommended team setup, you need the following optional parts:
TKR6106 Orange LF Springs
TKR6114 Green LF Springs
TKR6018 composite shock caps (built to emulsion) OR TKR8072 Aluminum Emulsion Shock caps
TKR8027 Shock Stand Offs
TKR6051 8x1.3 pistons(drilled to 1.4mm)
TKR8104 .4 bellcranks
TKR8100 .4 ackerman
TKR5545B HRC Hubs
You also need the Aluminum C Block (others can stay composite)
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
TKR5161 V2 Adjustable Hinge Pin Brace A block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5163 V2 Adjustable Hinge Pin Brace C block, 7075 CNC, EB/NB/ET/NT/SCT) - Helps to improve durability on hard crashes.
TKR5545B HRC Rear Hubs (L/R, CV or uni, SCT.3/SL) - Improves stability of the rear on mid to corner exit. Allows harder acceleration on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6004T (front)
-TKR6017T (rear)
What spare parts should I keep on hand?
TKR5020 Hinge Pins (inner, front/rear)
TKR5516 Front Suspension Arms and TKR5515 Rear Suspension Arms
TKR5542 Spindle Carriers - TKR5541B Spindles
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here. Please be sure to try our recommended setup. It works very well on most tracks.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree68Likes
Old 04-27-2015, 11:11 AM   #586
Originally Posted by justingt5 View Post
Has anyone had issues mounting wheels to the 10.3, I have jc hazard scte offset. The problem is I had to drill out the centres to fit over the new stub axles? Also the inside of the wheel rubs the cap head screw on the steering link where it attaches to the steering knuckle? Any ideas of foxes guys??
Haven't had any issues as far as wheels,but the screw rubbing is simple,just change it to a button head the same size and length.
ba4ma is online now   Reply With Quote
Old 04-27-2015, 11:29 AM   #587
Originally Posted by Hoese37 View Post
I feel that the stock package is a bit light, but I found it to handle great with 6x1.5 piston.
Originally Posted by Matthew_Armeni View Post
The .3 suspension setup will feel soft on the bench but will work fine on the track. With the shocks mounted as far out as they are, it needs to be softer so as not to pack too much on the high speed bumps and landing big jumps.
Thank you both, I think I may assemble to box spec, and find out for myself.
The off-road Tekno 3some-> EB48.4 - ET48.3 - SCT410.3
The oval 3some -> Tekno SCT410.3 - Tekno SCT210.3 - Blitz
Sponsors: Fiercercsolutions.com, AKA, jtbearingco.com, CowRC, Walden Designs, Leadfinger Racing, And BoomRC.net
ezlight is online now   Reply With Quote
Old 04-27-2015, 11:53 AM   #588
[QUOTE=Hoese37;13981419] I feel that the stock package is a bit light, but I found it to handle great with 6x1.5 piston. QUOTE]
Was that on stock weight Shock oil?
I just ordered 6x1.5 to use when my .3 arrives and looking to see what I should start with at least. Ran the 8x1.3 on the first gen trucks.
Sponsored by Tekno
Tekno SCT410.3 - Hobbywing 4000k, RX8Gen2, Savox 1258, Vant Batterys
Tekno EB48.3 - Hobbywing 1800k, RX8Gen2, Savox 2274SG-TE, ProMatch Batterys
B5M - Tekin Gen 2 8.5/Express Motorsports 17.5, RS Gen2, Savox 1257, ProMatch Batterys
s14det is offline   Reply With Quote
Old 04-27-2015, 01:00 PM   #589
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
any current news on the nose down issue, if any, with the new truck?
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 04-27-2015, 03:48 PM   #590
Guch's Avatar
Hey Justingt5, I really think that yellow and black body next to the white, black, and yellow one is really slick. Any chance you could post more pics of that one?
22 3.0,Orion R10/DPS 7.5,Orion 4600 shorty, Airtronics M12,Spektrum S6270
SCT410.3,RX8.2/Pro4 4600,XP DS1015,SMC 7200
If guns are ever outlawed, then I'll be an outlaw!
Guch is offline   Reply With Quote
Old 04-27-2015, 05:24 PM   #591
Slotmachine's Avatar
Send a message via MSN to Slotmachine
mine jumped nose up all day, I had to keep off the throttle to keep the truck flat in the air.
Take the washers off of the top , I believe they say store 2 washers under the head of the bolt.
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 04-27-2015, 05:24 PM   #592
Trader Rating: 18 (100%+)
looks like tower went from mid may to early may. they must have a shipment coming in.
TEKNO SCT410.3; Hobbywing Sct-pro; Hobbywing 3656 4000kv; Protek 130S; SPC 70C 7200mAh 2s
TEKNO EB48.3; Hobbywing Xerun 150a; SMC 1900kv; Savox 2274SG; ECO Power 35c 4100mAh 4s
Associated B5R; Trackstar 120a turbo; Trackstar 8.5t; Solar D771; Reedy 65C 5800mAh 2s square
kyleman7 is offline   Reply With Quote
Old 04-27-2015, 06:43 PM   #593
The manual calls for 2 washers above and 2 below the steering ball link for initial bumpsteer.
Old 04-27-2015, 07:54 PM   #594
Hoese37's Avatar
I had a similar issue when first using the 5mm axles. My quick fix is to take a body reamer and just skim the edges of the wheel bore. The issue is that the axle bore in the wheel is getting slightly mushroomed out when you tighten the nut.
Yes on stock oils. The 6x1.5 pistons have the same surface area as the8x1.3, but work better when the shock speeds increase.
You can take the 2 off the top end of the screw, they do nothing but give you a place to keep the extra washers/shims.
Tekno R/C
FTR 510 Raceway
Team FTR
REX Engines USA
RW Mods
Hoese37 is offline   Reply With Quote
Old 04-28-2015, 07:54 AM   #595
Orion_2kTC's Avatar
I've yet to get the truck under full power on a track due to time however I'm curious about a sound I'm hearing while pushing the truck back and forth by hand. When the motor isn't installed, everything is very smooth however when I line up the pinion and move it by hand I hear a noticeable rattle. Now is this just the pinion interacting with the spur gear? Perhaps I'm too loosely aligned?
Orion_2kTC is offline   Reply With Quote
Old 04-28-2015, 09:17 AM   #596
Are you using a mod 1 pinion? When I got my first tekno a couple years ago I didn't know what a mod 1 size pinion was and I tried to use my 32 pitch from my sc10 4x4 and that sounded terrible. It made the truck "go" but was definitely not right.
mikeinsocal is offline   Reply With Quote
Old 04-28-2015, 09:33 AM   #597
Orion_2kTC's Avatar
Yeah a 15t Mod 1 Losi pinion.
Old 04-28-2015, 11:02 AM   #598
rcgod's Avatar
Trader Rating: 27 (100%+)
It's normal. You're hearing the lash between the pinion and spur when the motor passes through each magnetic field when turned. If you spin the motor it will feel notchy. No big deal that's the way most motors feel, some more than others depending on design. The noise can get better if you adjust the pinion closer to the spur but will always be there.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 04-28-2015, 05:33 PM   #599
Firstly thanks for info on the wheel issues guys
You mean the Battered one that is all black base with fluro yellow and a little grey. That was the 2014 livery:
Or if you meant the other one which I just did for this season, see video. For more info just google "team kirk rc" or go to www teamkirk .co.uk (cant paste a link??)
+ YouTube Video
justingt5 is offline   Reply With Quote
Old 04-28-2015, 08:52 PM   #600
What shock spring combos are some of you guys running?
Tags
sct410, sct410.3, short course, short course 4x4, tekno
